Question about Kitchen Ranges
Ge grsr3920 finding replacement knobs for this old model
    Habit-Forming:
  • 119 Answers
WB03T10035 - Repair Clinic
Posted on Apr 21, 2014
Replace a GE 115 volt air conditioner knob
Hi Joyce
Google the Brand and model #. A listing should pop up for repair parts. You should the be able to find the part number for the knob and order on line or call a local appliance parts company.
Jul 30, 2016 | GE Heating & Cooling
G.E. Slower Cooker/Crockpot
Hi Krista, your model number should be located somewhere on the appliance, then try googling G.E. Slow cooker/crockpot model number XXXXXX parts manual pdf. You will need to install Adobe reader for free if you don't have it to read the pdf format. Good luck and have a nice day.
Sep 25, 2015 | Crock Pots & Slow Cookers
GE dryer model DCA3BC8776 'Start' knob has come
you should be able to replace the knob from the front of the panel without removing the control panelit has a "D" shaft on the knob and shaft also has a "D" configuration too? right?
Aug 18, 2011 | Major Ge Dryer Timer Knob We1x1263
The control knob is stripped & I removed that; also found that the plastic part with teeth that the control knob operates is also stripped. Where can I find both parts and what is involved in...
Used to be that you could buy the ratcheting coupler piece for 5 or 10 bucks for the old GE machines. Alas, no more. The newer GE timer must be replaced if the teeth are stripped.
Be careful not to damage the indicator dial when doing this repair as it is about $20 for a round piece of plastic and a tiny steel clip. Pry this off using opposite points of the dial (grab it at the 9 o'clock and the three o'clock positions with as many fingers as possible) and pull gently so as not to set up any fractures in the dial's hub.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Washer-Parts/Model-WCSR2090D1WW/0432/0153200/G0503026/00001?blt=06&prst=&shdMod=
Unplug machine, remove knobs, end panels. Remove remaining screws that hold the control panel and tilt forward. Removing the fascia will reveal the screws that hold the timer on.
Sears PartsDirect wants about $80 for the timer.
Good luck from Detroit, MI.
Jul 11, 2011 | General Electric WCSR2090D Top Load Washer
Hello: One of the five knobs on the top of our GE monogram stainless-steel gas cooktop Model # zgu385 broke, and needs to be replaced. Can you help? Thanks, Daryl D.
DARYL - GO ONLINE TO REPAIRCLINIC.COM AND YOU CAN FIND THE KNOB YOU NEED, THEY MAY SELL THEM SEPPERATLY I'M NOT SURE BUT THERE PRICES ARE THE BEST I'VE SEEN IN A WHILE
Aug 24, 2009 | GE Profile JGP636 Gas Cooktop
Washer control knob just spins
The knob is prob stripped, very common for this washer.
Get it off and look at the teeth. To remove the knob you need a pair of surgical pliers. Reach behind the knob and yank the retaining clip out. If the teeth are smooth you need to replace the knob. Oil the timer so it will be easier to turn by the way. To put the new knob you simply slide it in place with the clip on it. So easy you won't believe it.
Feb 03, 2009 | GE WBSR3140DW Top Load Washer
Kenmore washer 110.92292100..Washer Timer Control Knob is broken, just spins around..don't know how to get it off to replace it. Need a replacement part. Called a repair man, he wants $75.00 just to come...
If the knob is tight on the timer stem, then the timer has failed.
If the knob is loose, then maybe just the knob has failed.
You can order either of these from a number of places. One I recommend is searspartsdirect.com. YOu just enter your model number and find the exploded view for the controls. If it does not find it, drop a number off the end of the model number that you've given and try again.
They are easy to replace.
Reply back and I can give you more advice or instruction.
Old GE wal mounted oven Model J55BE-1
I have the same problem. Did you ever find the solution
Oct 05, 2008 | GE Ovens
Dryer replacement timer knob for GE NBR453EAOWW
Go to the junk yard or a used appliance dealer.
May 19, 2008 | Dryers
GE Profile Washer - Model WPS Q416OT2WW - Knob repair
Knob should have a small plastic cover in the middle that just pops off. From there you will see a nut or pin holding it in-place. Why are you replacing the timmer? (Timmer is a VERY last resort when working with washers) I'll check back later around 5pm
Jan 22, 2008 | Washing Machines
Kitchen Ranges Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
