Question about Lite On Spark Plug Lite Green LED
No spark I have a 1972 Winnebago with a 318 Industrial engine. An electronic ignition was in stalled. The camper was running last fall. I wen to start the camper with no luck. I swapped out the coil, and still no luck. What next?
    Master:
  • 435 Answers
Did you check the coil wire itself? A break in it will be hard to see. Get another one, or temporarily borrow one from one of your plugs, just for long enough to see if it gets spark. If it does, you know the rest, I'm sure. I'd check all plugs and be sure that little wire under the cap is on the tab. I've had a breaker plate wire fall of on me once, took forever to figure that one out. Even an electronic ignition needs to be grounded at the distributor. You've probably just got a connection issue.
Let us know if there's still a problem.
Posted on Apr 27, 2014
2 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: no spark at the spark plug
Check first if your battery got a full charge, or not drained...
Let me know..
Posted on Jul 18, 2008
318 engine stalls, shut key off completely and will start instantly and run just fine. any ideas whats wrong
Year,make and model? Since you said 318, Dodge. Older. Check the power and ground points(check for corrosion). Loose connections. Coils, wires and ignition modules won't cause this. Could be an ignition switch also, most likely not.
Nov 07, 2014 | Cars & Trucks
My 93 geo storm will run for a couple seconds with engine start then quit, is there an anti theft switch under dash.??
STORM = ISUZU.
Isuzu Impulse,
a very rare car. 70k made, 3k in Canada.
they hand 2 Isuzu engines, DOHC, 1.6 and 1.8L
is car a daily driver, when did it last run right?
is fuel fresh....
ever do a tuneup on it? spark parts, and filters.
can you keep engine running with a fast right foot, (a key answer)
the stock car drawings ,show no IMMO , nor any alarm.
but the operator guide can be had,......
the real question is why it stalls.
you crank it
it starts and stalls.
we do simple test to find this,
this car has very simple EFI so. is easy.
1: engine compression above 150PSI x4.
2: 12vdc running, if the voltage falls below 11vdc, running fix that first.
3: spark spark good at all cylinders, test it, get a tune up.
4: fueling, too much or too little and it stalls.
the fueling tests are a long story and ill wait till you get this far.
Jul 03, 2014 | 1993 Geo Storm
I have a 1975 winnebago from dodge Someone messed with the spark plug wires I need the fireing order and how the wires go on the cap Dodge winnebago 1975 v8
You could have 3 different engines in that rig.
The firing order is 1-8-4-3-6-5-7-2 for most Dodge 8 cyl engines.
And the odd cylinders are on the driver side.
The small block engines ( 318 ) have the distributor in the back, and the big block engines ( 360 440 ) are in the front.
The rotor on the big blocks turn counterclockwise. The dist cap is usaully stamped with cyl 1 as a starting point.
Jul 22, 2013 | Cars & Trucks
How to install headers on 1972 (A body) plymouth duster
if i knew what a header was in english and what a plymouth duster was i would help no qualms their honest ,is this vehicle a industrial vehicle ?? If you give me some information i can advise even if its a vehicle i have never seen in my long life before .got a engine i will fix it
Jul 09, 2011 | Plymouth Scamp Cars & Trucks
My 1996 f250 stalls in the afternoon on hot days. it does not seem to be related to how hot the engine is. I have tried replacing the fuel filter with no change. this model is fuel injected which I think...
What engine ? .Electronic Ignition Modules are good for causing that type problem . When the problem happens , pull a plug wire an see if there is spark ,no spark ,i would think ignition module . Videos on youtube showing how to test ignition modules .
1996 Ford 150 No Start with ScannerDanner EricTheCarGuy
Jul 30, 2017 | Ford F-250 Cars & Trucks
I get one spark on plug, then nothing. It is a
hi y could have a sticking float in your carb causing it to flood
Nov 14, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
My nissan 350z sometimes stalls after starting
after i replaced the battery in my 2003 350z, it would stall immediatly after i cranked it on unless i gave it a little gas. I fixed this by cleaning the MAF and throtle body valve. Total supply costs were $15 and took about 20 minutes. My Z is not only fixed but runs smoother and cleaner.
Jul 11, 2009 | 2003 Nissan 350Z
Stalls when warm and electronics are used
Check your charging system if output falls below level needed to run the ignition system it will not function properly...Quick check: Put a volt meter across the battery with engine running. turn on all accessories and lights. Voltage should not drop below high 12's to low 13's. If it does, likely the alternator has at least one bad diode and is "marginal"
Jun 11, 2009 | 1995 Pontiac Bonneville
Computers & Internet Logo
77 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
