Question about Panasonic PT-LB50U Multimedia Projector
I push the power button it looks as if its going to start up then suddenly its stars blowing really hard and all 3 lights ( power, lamp , and temp) start blinking red
premtech
  • 934 Answers
SOURCE: PT54DL50
There is a problem in your 3.3v main line and until corrected it will not power the lamp. This isn't usually an expensive repair but one that a shop will need to do since most of the work will be in trace testing voltage and signal using a scope.
For future information only here are the blink codes for this unit:
1 | Load Shortage
2 | Over Volage
3 | Fan Sos
4 | Main 3.3v
5 | Lamp Disable
6 | Gc3fm-Iic
7 | Gc3fs-Iic
8 | Gc3i-Iic
9 | Color Wheel Stop
Hope this helps!
Bill
Posted on Dec 01, 2007
SOURCE: Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Posted on Jan 12, 2008
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
SOURCE: Power indicator light blinks orange times
sounds like the lamp faceplate is not screwed back in properly
Posted on Aug 06, 2008
SOURCE: replacement lamp not working
It seems there could be a number of problems causing this. For the PT-LB10 series, there's a service manual at
http://owa.mellafeysalas.cl/dscgi/ds.py/Get/File-3457/PT-LB10_SvcMnls.pdf
You'll need to be handy with electronics, or know someone who is...
Posted on Feb 16, 2009
94 Mercury Cougar 4.6L Int Lamps 10Amp fuse blows
replace the door jamb light button, it's probably bent therefore not pushing in when door is shut, and when door is shut it grounds out, and it wld'nt effect the dome light because it's in the circuit befor the dome if this is the case and you find it's bent or crimped try to bend it back out,
Aug 25, 2012 | 1994 Mercury Cougar
2004 camry ac light blinking and throws hot air. Suggestions?
My 2003 Toyota Camry AC often starts blowing hot air and the AC light starts blinking. I don't know why the following process works, but it does. Using the temp selector (left) reduce the temperature all the way down to Max Cold and then push the Auto button. It will start blowing out very cold air. After a little while push the temp selector to the desired temperature.
Apr 03, 2012 | Cars & Trucks
Akai rear projection tv suddenly stopped working.
This set with Akai is actually made by Samsung (they own and use the Akai name).
If lamp light etc and you have heard a cracking sound it may be the color wheel.
You can remove the lamp and look where it faces--look and the wheel can be seen----is it shattered or missing plastic pieces?
The wheel commonly fails in this fashion and is turning at over 12,000 rpm. The set will detect if the wheel is stopped or moving too slow and just what you describe will happen.
Wheel is widely available and You Tube has video instructions for replacing them by model number.
Questions?
Mar 28, 2012 | Akai PT5492S 54" Rear Projection...
Heard a loup pop when I turned the tv on; the timer/lamp/standby/temp lights on the power on button are now flashing; when I pushed the power button again the lamp light on the power button flashes and...
Color Wheel - Pull out the Lamp using a flash light look right into where Lamp was you should see the color wheel turn TV on watch to see if wheel is turning,From what you have said Problem will be the Color Wheel. Encompass Parts Distribution has them 1-800-638-3328
Sep 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Hitachi UltraVision VG825 Series 60 inch Projection TV What is the part number of the lamp that I need? And, just to be sure, this is the process of what I do and what happens when I try to turn the T.V....
the fizzing sound you hear is most likly the ballast atempting to start the lamp so thats a good sign that the lamp is bad and not the ballast part # is(UX21516)
Jan 25, 2010 | Televison & Video
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
PROJECTOR PROBLEM Casio XJ 31
it wasn't able to go through cooldown mode. turn it on, power down and let it go through cooldown. does the light come on at all?
May 31, 2009 | Casio XJ-S31 Projector
No picture or sound after replacing lamp
Possible bad color wheel...
Pull the lamp out & look inside where the lamp sends the light-
does the color wheel look defective? If so,replace it.
Or, the lamp ballast may be bad.After that,usually replace
complete engine.
Oct 19, 2007 | Samsung HL-R6167W 61" HDTV
Need answers
The fan may have went bad. If it's out of warranty you may open it up and try and blow some dust out of the fan to see it that may do the trick if not it may need to be replaced. Westexaudioelectronics.com
Oct 04, 2007 | Televison & Video
Panasonic PT-LB50U Multimedia Projector Logo
35 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
