Question about Sony DAVTZ140 DVD Home Theatre System 5.1 CH
Sony DAVTZ140 DVD Home Theater System locked
Can't eject disc
  • 254 Answers
SOURCE: DVD stuck in sony blueray player bdp s300
Step1There are a few ways to get your dvd/cd drive release itself. The first thing you should try is shut your equipment completely off for a couple of minutes allowing it to cool down. Once you turn it back on try to press the release button on your equipment. Step2If that does not work try to use a very thin flat tip screwdriver. Insert in on one of the sides of the dvd/cd drive and try to pull it out softly while pressing the eject button simultaneously. Do not force it out but give enough pressure while pressing the eject button. Step3More than likely inserting a screwdrive should release the dvd/cd drive. You can also try a butterknife as well just don't use to much force. Something else to check for is to make sure the power is acutally on for the device. If you are trying to open a drive that is not even on it will never open up for you.
Posted on Apr 03, 2009
SOURCE: Sony SLV-D360P player DVD won't eject, says "Lock"
Hold down the
Posted on Aug 27, 2009
SOURCE: my dvd locked in the
Open the door to the DVD.. You will see a white plastic wheel inside with "teeth"- like a gear. Use something small to turn the wheel to the right. When it feels like it won't go any further give it a little extra turn and the drawer should pop open. Make sure you are turning it to the right (clockwise)
Posted on Jan 18, 2011
SD Tech
  • 14553 Answers
SOURCE: Sony Ns575p wont eject DVD
Someone is going to have to open the unit to look to see if mechanism is jammed or out of alignment or if the disc is not in the proper position---either mechanism or a jam is most common here.
Posted on Oct 22, 2012
SOURCE: My Sony DVD Player DVP SR320 won't eject ... Locked is displayed in screen .. Kindly help ... the DVD inside runs well
Hold down the play button, it will take a bit but it turns of the child lock
Posted on Feb 27, 2013
How do I eject the Dvd
Press the eject button on the top right-hand of the keyboard. Be patient if the disc does not pop out immediately. Try pressing the button a few times or waiting a few seconds and then press the button again. If it doesn't eject, tilt the computer with the disc drive facing down and shake it gently as you press eject.[1]
Drag the disc icon into the trash. If the eject button isn't working, locate the disc icon on your computer's Desktop and drag it to the trash can. The trash can is located on the far right end of the Application Dock on the bottom of the computer screen.
Press and hold "Command" while simultaneously pressing "E."
Find the disc in the Finder. Open the Finder, located on the bottom left of the applications dock. Look on the left-hand side of the pop-up window under "Devices" for the name of the disc in your drive. Locate the eject button directly to the right of the disc name and click on it.
5
Eject the disc through an application if it is not in the Finder. In iTunes or DVD Player, click on the "Controls" drop-down menu located on the top toolbar and click "Eject Disc." You can also open iTunes and click on "Playlists" so that the left side bar pops up. Look for the CD icon with the appropriate name. Click the eject button directly to the left of the CD name.
Jul 11, 2015 | Televison & Video
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
How to eject disc
To eject a CD from your disc drive, follow these steps.
1. Go to My Computer.
2. Right-click your disc drive (e.g. DVD RW Drive (D:)
3. Select "Eject."
It should automatically eject your disk. If not, there may be a hardware problem where you might have to contact your manufacturer. Hope this helped.
Dec 04, 2013 | Computers & Internet
Ejectiing a disc
f you're told you can't eject a disk, try the following suggestions.
f you're trying to eject an external disk:
  • Choose Apple menu > Log Out, and then log in again. Try to eject the disk again.
  • If you still can't eject the disk, choose Apple menu > Shut Down. Disconnect the disk from your computer, and then start up your computer again.
    If you're trying to eject a CD or DVD:
    • Choose Apple menu > Log Out, and then log in again. Try to eject the disc again.
    • If you still can't eject the CD or DVD, choose Apple menu > Restart. While your computer restarts, hold down the mouse button or trackpad button until the disc is ejected.
      If you're trying to eject a network disk:
      Choose Apple menu > Log Out, and then log in again. The network disk should be gone.
Jun 11, 2012 | Apple Air Computers & Internet
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
Disc cant read the disc and will not eject the disc. I tried unplugging it and putting on and pushing eject. no good. what do you think bose 321 system
disc cant read the disc and will not eject the disc. I tried unplugging it and putting on and pushing eject. no good. what do you think bose 321 system ...
Oct 08, 2010 | Bose 3 2 1 GSX System
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Disc won't eject
Hi, to open thje the disc tray , look for a tooth pick , insert small hole in front panel push and back until disc tray out. , motor belt need to replace.
Jan 19, 2008 | Teac (DW-224E) DVD Drive
Disc Eject won't work after improperly inserting disc and since removing it.
I have an DZ-MV780 with the same problem. I found that the cover plate around the flash hot shoe only has a single screw. If you remove it and pull up the cover you gain access to the gear and lock mechanism. Hit eject and if necessary press on the white gears you see in front of the zoom switch. It should then cause the door mechanism to unlock and open.
Aug 24, 2006 | Hitachi DZ-MV580A DVD Camcorder
Sony DAVTZ140 DVD Home Theatre System 5.1 CH Logo
22 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
