Usually if your unit does not start, the high pressure switch has failed to return to normal position, this can be caused buy poorly constructed switch housing or faulty micro switch.you will need to take it out of its casing and locate the plastic housing that has two wires inside. inspect this for functionality repair or replace and test unit before re-assembling CAUTION avoid touching any wires that may be live when testing!
