Question about Home
Outlets in bedroom aren't working - Home
  • 3,904 Answers
Check the breaker box. Also check your GFI plug ins an make sure they did not pop. It will be in the bathroom but the bedroom may be on the same circuit. Push the red rest button. If neither of those things work then I would replace the circuit breaker at the box. First ensure with a meter that you have power at all points.
Posted on Apr 20, 2014
Front bedroom outlets not working all other lights outlets and appliances are working 2016 jayco 32bhds
take it to a jayco retail outlet where there are technicians available with schematic diagrams
possible a circuit is off from water ingress into that section of the unit
May 04, 2016 | RVs
Tv in bedroom not working but tv in living room working any suggestions
I am assuming it does not turn on. Did you try a different outlet that you know is working? If you know the outlet is working and the tv does not turn on or tries to turn on but does not then I believe the tv's power board has failed. If you use a remote, is the remote working? How old is the tv?
Jan 05, 2016 | Televison & Video
No power in back bedroom
Locate your circuit panel, and check your fuses/circuit breakers.
Maybe breaker tripped?
To reset, remember: All the way to OFF position first, then flip towards ON.
Jun 09, 2015 | Televison & Video
No power to one outlet in bedroom.breakers are ok.
I would think that if the other outlets that are on the same circuit are still working, then I think I would try replacing the outlet in question.
Nov 15, 2014 | Leviton 15A Decora Electrical Outlet Light...
Circuit breaker is fine but still no power on one bedroom. PG&E said it might be a bad plug/outlet.
Turn off the circuit breaker and locate the plugs that are on that circuit. There is a good chance that the problem is between the closest working and faulty outlet. Starting with what appears to be the last working outlet on the circuit, check that all the wires are secure in all the fixtures and outlets.
If that does not fix the problem, a varmint may have chewed through a wire inside the wall. If you do not have experience with home wiring, you should get an electrician.
Feb 26, 2013 | Electrical Supplies
I have 110 voltage to all circuit breakers but no power to outlets in 2 bedrooms .
Check at the output side of the breakers with a voltmeter. Make sure that a white neutral wire didn't get hooked to a breaker. You may need to pull the outlets in the bedrooms to see if they are wired correctly. Good luck!
Sep 25, 2010 | Federal Industries 15 Amp Federal Pacific...
I have a circuit breaker that is intermittent
It is unlikely that those temperatures would cause the circuit breaker to shut off and come back on intermittently. (If the breaker trips it has to be reset manually.) It is possible that the breaker is defective internally or that there is a loose connection in the wiring. If you are not knowledgeable about electrical work you should have an electrician check it out for you.
Nov 25, 2009 | Electrical Supplies
My front assessary power outlet stopped working. What fuse corresponds to this outlet?
our outlets on one side of our bedroom is not working. We have replace outlets, checked the wire nuts. What else can we do?? Help
Oct 24, 2009 | 2005 Chevrolet Uplander
Home Logo
24 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
