Question about Hayward Pool & Spa
Chlorinator h-40 power comes to the board,but lights are off and display is off.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Hayward Master
  • 1,448 Answers
Check to see if power transformer is working most of the display boards are 110 volt other functions are off the transformer most of the time 24volts
Posted on Jun 10, 2014
Zodiac ei series salt levels are fine cannot increase chlorine indicator light above 20%
need more info is this connected to a system if so you have to change it in the system if not on a system sounds like a bad control board
May 19, 2014 | Zodiac Nature 2 Cra30 Replacement...
Swimpure chlorine generator not working
Did you figure this out ? I have the same problem.
Sep 03, 2012 | Hayward Industrial Products SwimPure Salt...
Zodiac LM3 24S won't turn ON
Two Things come to mind, the board, or it could be that the life of the cell has expired.
The Pool Tech
Jul 13, 2009 | Zodiac Duo Clear System Chlorine...
Intex salt water chlorinator not producting chlorine
You can test if the 8110 is generating any chlorine by taking a water sample directly at the pool return. You can invert your container so it stays filled with air until you have it positioned in front of your return. Make sure your test chemicals are not expired and test the sample. You should get a high reading if the 8110 is producing any chlorine. If it is producing chlorine, you may want to make sure you have the correct level of Cyanuric Acid. In my pool, if the Cyanuric Acid level is low, the chlorine level drops to zero quite quickly.
If the sample indicated your 8110 is not producing any chlorine, I would check to see if you have approx. 24V DC between B+ and Gnd on the screw terminal strip on the main circuit board. The transformer supplies two voltages to the 8110. One voltage powers the electronics and the other powers the electrolytic circuit. So it is possible for part of the unit to work if one voltage has failed.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
ZODIAC DUOCLEAR 25K DOESN'T FUCTIONING WELL
I have the zodiac duoclear system and have used it for nearly two years. All in all, it's a very good system. I have had similiar issues on occassion. Have you tried the master reset button on the lower right hand face of the control board? I've been able to clear up the lights by resetting the system.
If the salt content in the pool is not correct, the system will not allow you to superchlorinate. Your salt level should be at 4000 ppm. The add salt light is programmed to come on if the system gets below 3600 ppm. When the system is below 4000 ppm, it is unable to generate the chlorine needed. The lower the salt, the less you can chlorinate. Might not be your problem, but I've run into this before too.
The lights for replacing your cartridge puzzle me. I'm making an assumption that your pool is probably dirty if you're trying to superchlorinate. The dirtier the water, the faster the electrode in the cartridge will get covered in scale from the current and conversion process. Try cleaning the new cartridge by placing it in a bucket with a 75% water and 25% muratic acid mix. Let it soak for a few minutes and gently swirl it around in the mixture. This will clean the contacts in the cartridge.
Keys with the Duoclear system: Salt content and clean the filters regularly. Don't know if this will solve your problem or not, but good luck.
Dec 30, 2008 | Zodiac Duo Clear System Chlorine...
Pool & Spa Logo
51 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
