Question about Dell Dimension 3000 PC Desktop
Message is a blue screen and it says that recent installation of hardward/software has caused windows to shut down, go to advanced start up and go to safe mosde. the safe mode takes mw back to the same blue screen
  • 674 Answers
Check the program installed in your system.. there are a lot of cause of blue screen.. 1. a lot of virus,2. not properly installed ethier hardware or software. programs.. or setting.. then the system will be shut down automaticaly. or autorestart...
Posted on Jun 19, 2009
Laptop crashes several times a day then get message "caused Windows to shut down unexpectedly and restart". Microsoft Windows Error reporting states a serious problem and is "Stop Error or...
Hi and welcome to Fixya
Stop or blue screen error are caused by recent software installation or hardware modification. If you installed software recently, try to uninstall the software and observed the problem. If you modify something o the hardware. I recommend to revert the modification and observe the issue.
Let me know if you have questions.
Have a good one!
Feb 25, 2011 | Packard Bell Computers & Internet
We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this. If your computer stopped responding, restarted unexpectedly, or...
did you recently install a new hardware ?
did you recently install a new software?
if you answered yes to any of these questions above you need remove it.
therefore if you installed a new hardware safely shut down and remove cables and remove hardware.( if it is hardware the hardware is not compatible with windows)
if it a software boot in safe mood then uninstall software. ( to boot in safe mood, press F8 while computer in turned on )
Sep 27, 2010 | NEC VALUESTAR T (VT900/8D) PC Desktop
Blue screen of death. unable to download drivers. can not get to safe mode. cannot reload orperating system disks.
First off, note down all relevant information when you see a BSOD flash across the screen. This includes the error number and friendly name from the 'bugcheck' section of the stop error (see above), and any file names specified in the 'driver information' section.
If the BSOD comes up on the screen for a split-second before the PC restarts and wipes all the useful information away, we need to change some settings within WinXP. In most cases, it should be possible to stop your PC from automatically restarting when it develops a major error, allowing you enough time to jot down the BSOD error message. If you are using WindowsXP, right click on my computer > Properties > Select the 'Advanced' tab > and under 'startup and recovery' click the 'settings' button. This will open a new window, and under the 'System Failure' heading, uncheck 'Automatically restart.' Continuing on, attempt to restart the computer normally into Windows. If the BSOD occurred while booting Windows, you may be taken to a troubleshooting menu and will have to select 'attempt to start Windows normally.' If your computer starts correctly, continue using it and store the error information for later reference. If the BSOD reoccurs at random or irregular periods, see Section D below on troubleshooting intermittent stop errors.
If your system does not start correctly or the stop message happens again, reboot the system. When the POST (memory checking) screen comes up, press F8 repeatedly. This will bring you to the Windows advanced options menu.
In the Windows advanced options menu choose 'safe mode' to attempt to boot into Windows Safe mode. Safe mode loads Windows XP with a minimal set of drivers and no automatically loaded software. If faulty software or drivers are causing your BSOD problem, safe mode should load correctly. If safe mode loads correctly, refer to Section A below on 'troubleshooting software stop messages.'
If safe mode does not load correctly, and/or you get the same stop message upon attempting safe mode, it's time to try the 'restore last known good configuration' option in the advanced options menu.
Restart your computer, pressing 'F8' again to load the advanced options menu and select 'last known good configuration (your most recent settings that worked).' This uses Windows XP's built in system restore utility to restore the most recent save point, which should be the last time you installed any drivers or other software. If your system boots normally after this operation, hopefully your problem has been fixed.
If you are still receiving a Blue Screen Of Death after the above procedures, or if system restore was disabled on your system, note down any new information on the error and start thinking. Did you install any new hardware or software just before this problem occurred? The driver information section of the BSOD may help with this.
If you did install new hardware or software, and you think you know what it might be that is causing the problem, this gives you a big boost in resolving the situation.
Otherwise, proceed to the advanced troubleshooting sections below. Chances are your error is hardware or system file based and will require more effort to repair.
Specific Repair Instructions
If you have a reoccurring Blue Screen Of Death or crashing problem, and can't use Windows effectively because of it, it's time to look at more specific methods of troubleshooting your problem. Depending on the results of the basic troubleshooting steps above, you should have a good idea of whether the problem that is causing the stop messages is related to software or drivers you have installed, or is a hardware or system file issue.
Essentially, if you can't boot into Windows XP safe mode because of crashes or Blue Screens Of Death, you likely either have a hardware error or one or more essential system files is corrupted or missing. If you can boot into Windows XP safe mode, but get constant or frequent BSOD's when running XP normally, you have a software or device driver problem.
Make sure that if you added any RAM to your computer which is a common cause for BSOD that you added the correct RAM for your computer and that it is equally distributed in the ports meaning each port for the RAM has the equal amount of RAM on each side (eg, one stick 1GB, and the other has 1GB, etc).
Jan 03, 2010 | Dell Dimension 2400 PC Desktop
My thinkpad got stuck up while booting & i am getting blue screen. No further processing.
Is there any error message that you can see?What does it say?Or,is it just a blue screen and you can't see nothing? Blue screen can be caused by any hardware,software,poorly written device drivers recently installed and accidently shutting down of PC. If you can't see anything then take out the battery and press the power button for about 60secs.Startup without the battery first using the adapter and then see.If you still see the same blue screen then try the other options:
I want you to press F8,at startup, to bring up the advanced boot option and select "last known good configuration". Go to the BIOS setting pressing the DEL key at startup and select Load setup defaults [you might find that option in EXIT ]. Try removing any extra hardware attached like scanner,printer,pen drives etc.Later attach them again one by one and switching off and on the PC just to make sure which hardware is gone kaput. If you are able to startup the computer,use the SYSTEM RESTORE function to go back to previous date when your pc was working fine.This is to make sure you don't end up getting a blue screen at startup,again. The last option would be installing Windows OS. You can try and change the RAM sticks,if you have two then remove one n then start,do the same with the other RAM.
Jul 20, 2009 | Lenovo ThinkPad T61 Notebook
Can i change experts
Please select the Safe Mode option. If you no longer have that option whenever you turn your computer on. you can press on F8 after power-on. If you are able to boot in Safe Mode, please try to do a system restore (Start-All Programs-Accessories-System Tools-System Restore). Choose a restore point with a date known to be a time when you never experienced this problem. If you are not able to boot using any of the advanced boot options, you will need to do a full system recovery (reinstall the OS). Hope this helps. Thank you.
Sep 22, 2008 | Toshiba Satellite M30X-S181ST Laptop
You can try to select safe mode and do a system restore (Start-all programs-accessories-system tools-system restore) choosing the date when your laptop was working properly. If you are using Vista, you would see if you had a Windows Update or other such software changes. It is like undoing that but there would be no changes with your personal data. If your laptop works faster after that, please do not have the same software or update again. Hope this helps. Thank you.
Sep 22, 2008 | Toshiba Tecra M1 PC Laptops
Blue Sreen Error
I strongly suspect bad ram when any computer displays that message.
Apr 25, 2008 | Compaq Evo N610C Notebook
Safe mode business
safe mode automatically comes up when you didn't shut down properly. Just select boot as normal or last known good configuration then you are good to go.
uninstall any new hardware or software you have recently installed to cause the problem in the first place. If you haven't installed anything then windows should just start normally.
good luck
smeags.
Jan 22, 2008 | Computers & Internet
Windows XP: Blue Screen of Death
Hi are you connecting the usb devices b4 or after windows has started? what version of windows r u running?
Do the usb devices come with their own driversand software?
Dec 18, 2007 | Dell INSPIRON 6000 CENTRINO...
Dell Dimension 3000 PC Desktop Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
