Question about GE Refrigerators
F228jbaa 63er0286 48216
Freezer and fridge randomly stop working...temperature fluxuation
    Sergeant:
  • 266 Answers
Is it plugged in tightly? You may need a new motherboard.
Posted on Apr 20, 2014
  • 1462 Answers
SOURCE: SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Posted on Mar 20, 2007
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
aborcass
  • 2651 Answers
SOURCE: does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Posted on Nov 21, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Posted on Jun 28, 2009
SOURCE: Fridge not making usual humming sound
I had a same problem, However the fan in the freezer seems stop and the freezer compartment is melting. Its a double door LG with 270 ltrs.
Posted on Apr 05, 2010
Fridges stops working randomly but the freezer works. Then the fridge starts working after a couple of days
When the fridge stops working, can you hear the fan operating inside the unit? It sounds like you have a failing evaporator fan motor. This fan motor circulated cold air from the freezer to the refrigerator.
Apr 19, 2015 | Refrigerators
Temperature light at back of fridge randomly goes from red/green and the temperature in the fridge does not appear to be stable?
on a fisher paykel I would call them direct, their help desk can walk you through some checks to see what the error is... if I needed service on this unit I would use who they suggest.. because if the servicer does not have access to the factory on FP HE IS GOING TO BE GUESSING WITH YOUR POCKETBOOK in hand... we work on FP everyday and we call often....... I hope this helps.... ken
Sep 29, 2014 | Fisher and Paykel Refrigerators
We have a f & p fridge freezer model E327B, that randomly beeps at us at odd times. I small light inside flashes indicating there is something wrong with the freezer but everything is still frozen. ...
Sorry, it would be better if you re-post this onto the fridge/freezer forum- this is for washing machines so you might not get an answer- other than this one ;-0)
Good luck,
John C
PS sounds like the temperature sensor might be misbehaving like ours did - but take no notice of me!
Apr 07, 2011 | Fisher and Paykel (IWL12)
Fridge freezer kept in cold garage. Freezer works from time to time but fridge stopped work. Could it be a thermostat problem or due to temperature of garage?
The problem is with the garage temperature. The temperature sensor for the refrigerator is in the fridge compartment, but the evap coils are in the freezer. Refrigerators were designed to work in an air conditioned space. When they are put into unheated spaces, it does not work well. The fridge thermostat typically is set to 40 deg F. If the outside temperature is close to that, then it does not turn on the compressor as much so the freezer will have a hard time staying below freezing.
There are garage refrigerator kits for people who put fridges in un heated garages in the winter. They just simple electric heaters that warm the fridge's thermostat to cause the compressor to run more often. This helps the fridge to maintain temperatures better in the freezer compartment. The same thing can be accomplished by putting a small wattage bulb in the refrigerator compartment. Just remember to remove it during the warm weather otherwise you will pay a large electricity bill in the summer months.
Dec 09, 2010 | Smeg FAB46X Top Freezer Refrigerator
Mar 11, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Jun 28, 2009 | Refrigerators
My fridge freezer made by samsung is on the blink
These fridges have an evaporator fan motor on both sides - the freezer and fridge side. The freezer can maintain it's temperature because that fan is working fine. I had the same problem, and replaced the evaporator fan motor on fridge side, and it solved the problem. Also, if your fan motor is not working well, or stops working, the evaporator is prone to ice build up, and will prevent proper cooling. You may want to open up panel on fridge side and see if that's the case. Taking a blow dryer to the evaporator and surrounding area (while fridge is off), or letting it sit for a few hours might solve the problem. Ultimately though, it appears as if these fan motors are prone to failure, and need to be replaced.
Dec 19, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Our beko frost free fridge freezer has stopped freezing. The fan is working and the freezer section cold but not cold enough. Thermostat is in the fridge - the fridge is icing up.
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Aug 12, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
