Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Panasonic pt-53wx53g vertical output ic
I was told the problem with my panasonic pt-53wx53g could be fixed by replacing the vertical output ic. i am hoping someone knows the part number for this item so i can order it. thanks
  • tami_laporte Jun 19, 2009
    thank you so much. you made this incredibly easy for those of us that don't know anything!!
  • 10,594 Answers
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
Posted on Jun 19, 2009
PT-53WX53G still shutting off-3 blinks
have you checked the 2.2 ohm 2watt resistors? If the led blinks three times the resistors will almost always have at least one that will be blown and need replacement.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Tv still turning off blinking three times after hori ic replaced
Three blinks is short protection.
97% of the time it means one or more of the 2.2 ohm blue resistors around the two convergence IC's is OPEN.
There should be 8 or 10 of them: light blue in color and will have 2.2 printed on them ------look for any that are slightly discolored or white in the middle.
What happens here is if one opens====one of the two convergence chips got it----they can be tested in place like testing a fuse===no reading across any of them and it is gone-----set detects no voltage reaching the chips(Usually STK-392-110---black in color and on metal heat sinks with fins side by side.)
DO NOT JUST REPLACE THE RESISTOR IF YOU FIND ONE BAD=ONE OF THE CHIPS GOT IT.
I have start to finish, step by step instructions showing what is needed and the best way to replace the chips etc.
FIRST: LOOK TO SEE IF any OF THE RESISTORS ARE GONE. (BAD)
If you want the instructions let me know and I will post them here for you.
Regards, SD TECH
FYI= Whoever told you to replace the output transistor does clearly not know these sets very well as it will produce a 5 blink error code.
Jul 26, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Can I Fix a Color Seperation Problem Myself On My Television?
The convergence Ic's need to be replaced. This is not easily done unless you have a good soldering station and some technical experience.
Mar 30, 2009 | Televison & Video
Have a panasonic 47in. rear projection tv
youre vertical output may need resoldering. If that doesnt correct the problem you will need a new vertical output IC
Apr 27, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic Model PT-53WX53G
Your part numbers are STK392-110 you will need two of them . They are located on two large aluminum heats inks right next to each other 1 heat sink runs straight and the other one is right next to it on a angle. You can get replacements at the following link and they offer free tech support with instant messageing and also send step by step installation instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Apr 15, 2008 | Panasonic PT-53WX42 53" Rear Projection...
A question about the IC chips
Try vance baldwin, they have good prices and will sell to non service shops. Hope this helps
Apr 01, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic pt 53tw53 rear projection
Check the vertial output IC. either for defective solder or defective IC. This model has a feature if the vertical output IC fails for any reason the picture tubes blank out as a safety issue.Thereby giving no picture but audio still functions.
Mar 11, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Where can I get parts?
STK392-110=CONVERGENCE IC USE TWO FOR REPLACECEMENT PART= WWW.bdent.com Product Details: The STK392-110 is a convergence correction circuit IC for video projectors. It incorporates three output amplifiers in a single package, making possible the construction of CRT horizontal and vertical convergence correction output circuits for each of the RGB colors using ust two hybrid ICs. The output circuit use a class-B configuration, in comparison with the STK392-010, realizing a more compact package and lower cost. www.partstore.com
Apr 12, 2007 | Panasonic PT-56HX41 56" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
725 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
