Question about Dometic Refrigerators
Dometic rm2652 heating element is hot but no cold in refridgerator or freezer
    Top Expert:
  • Dometic Master
  • 6,465 Answers
Disconnect thermistor from back board let run overnite if cold replace thermistor if not replace cooling unit or fridge
Posted on May 27, 2016
SOURCE: Refridgerator and freezer is no longer cold
evaporator freezer fan motor has low voltage. Amana M # SCD22NW S # 9403120669. Could use some help. Thanks
Posted on Apr 09, 2008
erpaalai
  • 999 Answers
SOURCE: my rv fridge will build up ice and freeze food too cold
The thermister for the temp control is a likely culprit. Eric
Posted on Jul 07, 2009
  • 9 Answers
SOURCE: need directions to remove and replace 110 element in Dometic 2652
Get to the back of the fridge. On the right hand side, there is a metal tube about 4" in diameter which starts at the bottom and goes up. This is a piece of thin sheet metal, which holds insulation against the refrigerant line that goes up the right side of the fridge. The 110 volt heater is located inside of that, near the bottom. The heater sits inside of a small tube, welded to the refrigerant line, and is easily replaced. To get to it, remove any flat sheet metal parts that block your view of the 4" tube (you will need to have a clear view of the bottom of it.) Then you can see the heater. It is on the left side of your 4" tube, metal, about 5/16" in diameter, has 2 wires attached, and sticks out an inch or so to the left. Trace the wires back to where they are connected on your fridge, and remove them, (probably with a small straight blade screwdriver.) It may be necessary to remove another cover or 2 to get to that connection, so remember where all your cover plates came from. Digital cameras are great ;-) . Then, on your 4" tube, unsnap and open the "door" (the metal piece which is a couple if inches wide and 7" or so high,) Grab a hold of your old heater, and pull it up. It probably wont come up all the way so you can lift it completely out, so you will have to unsnap some of your 4" tube above the door. When you remove the old heater, note its position relative to the insulation and refrigerant tube, 'cause the new one goes right back in the same spot. Pull the old one out, and put the new one in. You will know you have it installed correctly when it is snug in its own little tube (you wont be able to see that part,) and there is no side to side play. Then reverse the directions, and put everything back together again. When you re-attach the 2 wires to your unit, don't worry about getting it wrong, it doesn't matter which wire goes with what connector.
Posted on Jul 26, 2009
SOURCE: DOMETIC RM 1350 FRIDGE GET HOT AND COLD
Ok, I realize I'm a little late on chiming in here, is this unit located in a slideout, and/or the top outside vent is in the wall not a roof located vent?
If so then the issue is that there are fans that are necessary to circulate air thru the hot coils. And there is probably a malfuntioning thermostat to turn these fans on/off. I had this issue with same fridge in a Gulfstream motorhome, and the temporary fix was to pull the faston connectors off the thermostat and tied them together with a 12V fuse, and taped it up with electrical tape to keep it from shorting on fridge chassis and parts. Replace the thermostat at your conveniance, as these fans are now running whenever fridge is on, and will run your batteries down if not plugged into shore power.
Posted on Aug 24, 2009
  • 10 Answers
SOURCE: trying to purchase a heating element for a Dometic Dm2652
Try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673. there not a dealer just a service department, they might be able to help.
Posted on Feb 16, 2010
Freezer gets cold frig is hot. I replaced theromister.did no good
If your Dometic refrigerator is a tri-power model (12V, 120V, lp gas), check all modes. It is not uncommon for these units to fail to cool adequately in 12V mode, as that mode is only for KEEPING things cold while on the road.
If the failure exists only in 120V mode, replace the 120V heating element. If the failure exists only in lp gas mode, replace the burner and make sure that the jet is clean.
If the refrigerator does not get cold in ANY mode, verify that the door seal is making good contact all the way around and, if it is, you'll need to replace the coil assembly. (They are available on eBay and Amazon at a fairly reasonable price.)
May 20, 2015 | Dometic RM2652 Refrigerator
My freezer seems to work fine on the AC but the fridge will not get cool any idea what the problem might be Dometic model RM2652
Move your temperature control (slider) down. If it is close to the freezer it does not get the signal that it is warmer.
Sep 18, 2014 | Dometic RM2652 Refrigerator
disconnect thermistor let run overnite if ok replace thermistor if not cold bad cooling unit
Apr 20, 2014 | Dometic Refrigerators
My Dometic RM2652 fridge suddenly quit cooling. No amonia smell, no yellow residue around cooling unit. Gas ignites, lites work.
what is the yellow residue around heating element? my fridge just isnt working right and sometimes stops all together, the freezer worked until lastnight but fridge hasnt cooled right for a week or so.
Aug 03, 2012 | Dometic RM2652 Refrigerator
My Dometic RM2652 in my camper isn't getting cool enough when it's set on electricity. It feels cool, but not cold. The ice in my freezer turned to water, but it was still cold. The refrigerator section is...
Sounds like maybe your element for Heating when on hydro may be faulty. A voltage check at spades on board connected to element will confirm. If power to element but no heat felt at element should confirm it's faulty. Remember, if stack is already hot from propane, element will also feel hot, so it has to be out or fridge cooled down at back first.(off)
Apr 20, 2011 | Dometic RM2652 Refrigerator
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
Dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Jul 23, 2010 | Dometic RM2652 Refrigerator
Fridge works on gas...but not on AC
Your heater should measure 44 ohms, give or take 10%.
95 Ohms is way off. The RM2310 uses a 92 ohm heating element, perhaps you installed / were sold the wrong heating element?
Jul 15, 2010 | Dometic RM2652 Refrigerator
Dometic RM2652 will not run on electricity only Propane
Most likely your heating element burned out or else the circuit board is bad. To test the heating element unplug it from the circuit board (j6 and j7 usually gold colored) take the two heating element wires and using an ohm meter make sure there is no resistance between them, if there is resistance the heating element is bad, Or can just put a plug onto the heating element and plug it into a 110 wall outlet and see if it gets hot. If it is not the heating element it is most likely the main circuit board. (between 1993-1996 dometic used a yellow epoxy filled circuit board that went out pretty quickly) if you have the yellow filled circuit board rather than the green one it is most likly the circuit board
Dec 18, 2008 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
19 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
