Question about Car Audio & Video
My amp safty light comes on win triying to bridge wht do i need to do
  • 3,904 Answers
Make sure to check for a switch that you need to flip for going into bridged mode. Check that you have the proper gauge wire. Make sure to check the fuse. It is easy to short these out if you tried to make the connection with it powered.
Posted on Apr 20, 2014
Code Number106715391739256
Nothing is ever free. Read the terms and conditions.
Nov 18, 2013 | Computers & Internet
300W Pyramid PA305 protection light
What is the speaker load in Ohms that you are running? Or what exactly is hooked up to it? are you bridging it? The protection light will come on if the load is too much for the amp to handel. If the load (in Ohms) is less than the rated load that it can run, it will stop the output to keep the amp from self destructing. The amp will sense that the demand for power will be too high for the amps circuitry which will either make the amp get so hot that it will burn up the copper on the board or more likely burn up the power mosfetts that power the speakers. If the Ohms are within range then it will allow power to flow through the circuit until the rails that the mosfetts are bound to until they get so hot that it will go into thermal protection. So if your amp has both thermal and overload protection lights and the overload is light then the load is probably too much for the amp. if it's bridged in mono the you can only have 1 speaker setup hooked up it if it's a 2 channel amp. a 4 channel amp bridged in mono for both front and rear channels will be able to have 2 speakers rated a 4 ohms each hooked up to the amp 1 set per bridged output or channel.
Try it running in stereo with only 1 speaker per channel and see if it will produce sound. If not then you have an amp that has internal problems and will need to be serviced. Check your warranty to see if you are covered.
Apr 02, 2013 | Pyramid PA305 150 Watt PA Amplifier Car...
95 Regal Custom, ABS code #95 brake switch circuit and no brake lights. Replaced SLS still no change.
Check the brake light switch (location pedal) unplug the switch & bridge the wires & if the brake lights come on the switch is faulty. all you are doing by bridgeing the wires is bypassing the switch. What is SLS?
Oct 10, 2012 | Buick Regal Cars & Trucks
My back up lights don't work
Its probably the switch located on the gear box. You can disconect the switch & bridge the wires if the lights come on the switch is faulty. Make sure you disconect & bridge the right switch
Jun 27, 2012 | 1999 Plymouth Grand Voyager
Hi, I opened a junction box that operates 3 lights,from 3 diferant swicthes, there are red, white &blk plus ground i need to tap off of that & instal a gfi & vanity light w/s witch can you tell...
You need to find the hot leg and the nuetral leg . Hot is black and neutral is white . You need to make sure you have 120 volts between these wires cause some of the blacks could be switch leggs for the lights you talked about . Tie your recep. To those wht to wht and blk to blk .
Jan 24, 2012 | Hampton Bay 44 In. Bistro, Copper Kitchen...
1993 ford thunderbird stereo installation guide/ wiring guide
bat.-lt.gr/ppl; grnd-blk; ign-yel/blk; lights-lt.blu/red & org/blk; grnd-blk/org; L.F.-org/lt.grn & lt.blu/wht; L.R.-pnk/lt.grn & tan/ylw; R.F.-wht/lt.grn & dk.grn/org; R.R.-pnk/lt.blu & brn/pnk
Nov 07, 2009 | 1993 Ford Thunderbird
Kole amp in protect mode?
Are you setting the bridge switch for both left and right or are you trying to run both subs off of one set of terminals? If you running the subs off one set of terminals you are effectively running the amp below 2ohms and thus the amp is not 2ohm stable and you will destroy it.
Some amps actually all ready run a bridged output for left/right operation, this could also be the reason why the protection circuit is kicking on.
Either way it's a component mismatch and you either need a stronger amp or different subwoofer setup.
Mar 09, 2009 | Kole audio Nitric XP2-2000 Car Amp
Bridge subwoofers
Without looking up the individual specs of your speaker and amp, I'll offer a few basics when it comes to bridging an amp.
Most important...find out what impedance (ohm) that your amp can handle bridged!! If you go below this rating, you will run the risk and most likely eventually overheat and short circuit the amp. You must also know the impedance of your sub (which can come in a variety) to be able to match them. Depending on this impedance match-up, it may be less beneficial to bridge the speaker to this amp. For example if there is an impedance mismatch you'll either get less power from the amp or short circuit the amp. If you know these I can help you come up with the best solution.
If you know bridging is the best option, then you'll have to know which terminals on the amp to use in order to bridge. This is how it normally works. On a 2 channel amp...you would normally take the positive from one channel to the positive on the speaker, and the negative from the OTHER channel to the negative on the speaker...and this is how you bridge the amp. The other two channels would remain UNCONNECTED. BUT!!! you have to make sure you use the correct 2 channels...it varies from manufacturer. But take heed not overload the amp...and not to overpower the sub. There are a few different ways that you can configure the subs if you find it beneficial to bridge your amp, these would take long to explain and would depend on the impedance of your subs and specs of your amp...these wiring configurations is how you match the impedance of the speakers input to the amps output (and is very important to do correctly) Look up "parallel and series" wiring configurations. Let me know if this helps, or if you need further help. Find out the impedance of your subs and the specs of your amp and i'll be able to assist you more. Hope this helps.
Mar 27, 2008 | Car Audio & Video
Protection light
You cannot parallel two subs AND run them on the Bridge. You must have at LEAST a 4 ohm load on the bridge, and 2 4 ohm subs in parallel equals TWO OHMS. BAD!!! Move each sub to it's own channel or your amp will soon fry.
Sep 10, 2007 | Sony XM-2002GTR Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
