Question about Baby Gear
I NEED RAIL GUIDE FOR CRIB
2UPPER AND 2 LOWER
  • 340 Answers
Hi! You can contact one of the highly-trained customer service represenatives at Products America and they should be able to assist you in finding the parts you need. Their numbers are 800-772-1041 or 800-205-9642. You can also check out one of their user-friendly websites at www.productsamerica.com or www.productsamerica.net.
Posted on Jun 19, 2009
Drop rail on crib will not "drop"... am i missing parts?
You lift and then there is a metel bar in center under the rail that you need to push in to lower the rail.
Feb 21, 2010 | JCPenney All-in-One Nursery Crib
Lost hardware for a Berg crib - # 65-19-64 3010 10/05. Need to find replacement hardware.
missing upper guide bushings, U channel, and lower guide pins from front rail of Berg convertible crib. Where can I find these items?
Jan 19, 2010 | Berg Baby Gear
Need Replacement Part # 4 X H Crib Lock for Delta Lov Crib Model 4720
OUR DELTA 5 IN 1 IS MISSING THE RAIL GUIDE 4 X H CRIV LOCK AND #10 DOWELS AND NO INSTRUCTIONAL GUIDE HELP??
MZ Q
Oct 16, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
LOWER LEFT TRACK - FOR RAIL TO RAISE AND LOWER.
I have a Delta 5 in 1 Crib and I am having a hard time keeping the side rail up on the left side...... Pin doesn't seem to be working! How can I fix this very soon due to my second lil one on his way soon?????
Jun 06, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Crib rail locks
with the indulgence of robotek....
Could you pls post an image/picture of the defective part (right crib lock)?
Perhaps you can also try here, here or here.
Hope this be of Additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Childesigns Carrollton Crib
Delta Luv Crib Replace. Parts - 4XG lower plastic guide & 4XM steel peg
I went to the website www.deltaenterprise.com. You will have to have the country of origin, model number and the date of manufacturer or you can not get the parts. The phone number is 800-816-5304. I do not have fast you will get the parts. I called and did not have the country of origin so I will have to wait.
Jan 09, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
jmsmith2003@msn.com
Sep 15, 2007 | Childesigns Carrollton Crib
Bassett crib sides falling down
You likely are missing the lower track assemblies. Part # CC (right) and DD (left). These screw into the lower inside legs on the side with the drop down rail to secure the rail from dropping off. See instructions, Step 1 and Step 2.
Call Bassett 1-276-629-6000 to obtain instructions and a parts list for model # 5926-0504 (look on the inside headboard - not the gold label).
Parts can be ordered from Products America 1-800-772-1041
May 29, 2007 | Bassett Parson Ridge Crib
Baby Gear Logo
76 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
