Question about Bosch TDA2445 Iron
My Steam iron has stopped doing steam no light coming on what is wrong
    Top Expert:
  • Bosch Master
  • 38,135 Answers
The iron may be clogged and unable to generate steam or, possibly, the heating element has failed.
Posted on Apr 20, 2014
SOURCE: I have a Bosch steam generator iron B25L
yes my bosch did the same but then it started working again only to pour vast amounts of water all over the clothes
Posted on Dec 20, 2009
heatman101
  • 43501 Answers
SOURCE: brown water spitting out of
Brown water and white scale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Posted on Mar 24, 2011
mark24354
  • 776 Answers
SOURCE: i have a Bosch b52l iron, when i turn on the steam
It could be the iron itself (it may have a short circuit in it) and the circuit breaker trips when the steam switch is turned on.
Option 1)
Another option is that the entire circuit that that circuit breaker is controlling is overloaded. What other outlets / applicances / lights are disabled when that circuit breaker trips? You may have to iron only when those other applicances on that circuit are not being used.
Option 2a) Your outlet may be damaged and causing your circuit breaker to trip when the high current STEAM setting is set.
- OR -
Option 2b) the circuit breaker is damaged and is tripping too easily. Only replace with a similarly sized circuit breaker (15 amp lis likely but is says right on the breaker).
Try the solutions in that order.
-Mark
Please rate me..
Posted on May 07, 2011
  • 47 Answers
SOURCE: I have a bosch TDS25 steam generator iron and when
if the iron is still getting hot and generating steam i would say the light has failed, however if nothing is happening you could change the fuse in the plug if you now how if not get some one who dose and if this dose not help then i think your iron has had it
Posted on Oct 01, 2011
ercupa190
  • 12223 Answers
SOURCE: Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Posted on Aug 01, 2012
My Tefal pro express inon does not steam the generator not making noise and red light comes on
Maybe the steam switch if broken or not fitted correctly dso you can open and inspect it
Sep 11, 2014 | Irons
What could be stopping the water in the holding tank not going in the steam tank on my Perfect Care Iron ?
most likely is mineral build up. drain out the water and replace with white vinegar, warm up the iron and allow it to sit until you see steam (several minutes to half an hour) if no steam, replace the iron.
Jun 18, 2014 | Irons
My steamer steams and then shuts off and it takes another two minutes to steam again....what is wrong?
the power light stays on but steam only comes out for 30 second.and it takes few minutes to steam again.
Oct 21, 2012 | Rowenta Commercial Garment Steamer - White
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2010 | Black & Decker Steam Xpress AS250 Iron...
Tefal Steam Generator Model 2911
NO THERMOSTART LIGHT,BUT THE WARNING LIGHT COMES ON
Jan 28, 2008 | Tefal Ultraglide 1549 Iron
Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Nov 15, 2007 | Irons
Bosch TDA2445 Iron Logo
748 people viewed this question
Top Bosch Irons Experts
Colin Stickland
Colin Stickland
Mark Chaney
Mark Chaney
matt
matt
Are you a Bosch Iron Expert? Answer questions, earn points and help others
