Question about Avanti W7571 21 Portable Top Load Washer White
Washer not fully drained before spin cycle then get error message E-5
    Problem Solver:
  • 5 Answers
Somethink is blocking the pump , u need to take cover of see what it is?i say its money?
Posted on Apr 20, 2014
  • Brian
    Brian Apr 20, 2014
    I believe you are correct but those drain holes in drum are really small. Plus it's a almost new machine. I've only washed about 10 loads in it.
Error message SUD and F21 even after unclogging the filter
Push the pause/cancel button twice to clear your message. Then run through a rinse/spin cycle. Next try a normal load without any detergent. SUDS is usually from too much detergent. If this fails, checked the hose for kinks. Check connections and if all that fails, you will probably have to replace the pump. Good Luck!
Feb 04, 2014 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune washer machine won't spin or fully drain
    • 1 Open your home's breaker box and flip the circuit breaker switch to "On." If it is already set to "On," flip it to "Off" and then back to "On" to reset it. A power surge may have interrupted your wash cycle so the drain/spin cycle never actually started.
    • 2 Move the washer away from the wall and straighten the drain hose if it is twisted or turned in a way that makes it difficult for water to flow through it. Replace a kinked hose with a new hose.
    • Sponsored Links
    • 3 Push on the washer door to make sure it is fully closed. The washer will not drain or spin unless the door is closed tight. Press the "Start/Pause" button after you close the door.
    • 4 Wait for about 30 seconds after you press "Start/Pause." The washer will not operate until it has been able to fully lock the door and restart the drain process.
    • 5 Run the clothes through a complete cycle again, making sure you use cold water if there are a lot of suds in the washer. Too much soap in the washer can make it hard to drain. Use high-efficiency or low-sudsing detergents on subsequent uses.
Feb 15, 2013 | Washing Machines
My whirl pool duet sport keeps having an error message of f21 and 5d. i read that it means the water is not draining right. what can i do to fix this?
F21 means to a long drain.
Basically means that water is not pumping out quick enough. If all the drain lines have been checked for blockages and restrictions the manufacturer recommends the pump is replaced. Some times the impeller can become damaged or the motor which can cause the pump to work slower then it should causing this error code. If you took off the hose from the tub to the pump and found nothing then I doubt there is a blockage in the drum (it would have moved into the drain filter).
Sd or 5d error SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Hope this helps.
Aug 15, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Suds and then f35 error code shortly afterbstarting any wash cycle.
SUDS error = SUDS LOCK (OVERDOSE OF DETERGENT
F35 error = ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code Sd (or 5d)
It means Suds Lock(Overdose of Detergent Detected During The Wash Cycle).If suds are detected continuously by the pressure switch during the drain or spin phases,the washer will fill 4 litres of water and during 5 minutes the unit will rest without tumbling,the water will be drained and it will try to spin or drain again.
– Run the unit through a Rinse/Spin cycle.
– Run a Normal cycle without adding any detergent.
3. Check wire harness connections to the drain pump,pressure switch and Central Control Unit(CCU).
8. Verify CCU operation by running a Diagnostic Test.
Apr 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Machine will run through entire cycle and will not spin. It quits at the spin cycle. I checked the Black boot at the bottom. Removed and cleared out coins. Checked pump- it was turning freely. Reinstalled...
I had a similar problem and found out the "latch" on the washer door broke off. The machine won't run in spin cycle if the door is"open", but it would run through the wash cycle.
Feb 05, 2010 | Frigidaire Washing Machines
Washer won't finish the cycle because of imbalance during spin. It just shuts down, but I have time left over. I need to cancel the wash cycle in order to run the spin only cycle. ATF8000FG
I called a repairman since it had 5 more days under warranty. The problem was the drain tube from the washer into the drain was pushed too far down into the drain pipe. He did have an error message that it was taking to long to fill. Well no wonder, it was siphoning out the water as it drained.
Seems to have fixed the problem.
Nov 03, 2009 | Frigidaire ATF6000ES Front Load Washer
GE washer will not go to spin cycle or drain.
Possible lid switch not fully engaged. It will no drain or spin if lid switch is not fully engaged. I would also check the drain line for pluggage.
Oct 22, 2008 | Washing Machines
Avanti W7571 21 Portable Top Load Washer White Logo
63 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
No_ky
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
