Question about Vacuums
Carpet Cleaner won't squirt
It's sucking but not sending out water - water and soap are filled
  • 3,904 Answers
For some reason it sounds like the pump is not priming. You can probably manually doing this by disconnecting the out going hose at the pump, pouring in a little water, reconnecting the hose and then trying.
Posted on Apr 20, 2014
  • 27 Answers
SOURCE: Reginna Steemer Carpet Cleaner- older model- will not suck
Check for clog in motor intake. Take off the tank and look up into the motor. There will be a round tube with a plastic grate.
Posted on Feb 23, 2008
SOURCE: hoover will not suck carpet shampooer
the most common problem is the recovery tank. Most often the square piece of plastic that attaches to the side of the recovery tank is not snapped in-- it comes loose when you dump the tank. Take off the lid, pull the clear plastic sqare (about 4 inches by 5 ) that is attached on the OUTSIDE of the recovery tank and snap it back into place.
2nd make sure the rubber rim is clean and free of debris
3rd attach the lid with the hinges on the back first then snap down the lid
4th make sure the yellow float is down on the bottom (this is inside the filter inside the recovery tank)
5th put the recovery tank in the machine FRONT FIRST (where the two round peices of plastic are)then back, snap the sides back to lock the tank in place.
If these things dont work....make sure your not clogged with debris on the top (but I am sure you would have seen this before doing all the rest!)
Posted on Jul 21, 2009
Wonder Wizar
  • 62 Answers
SOURCE: hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Posted on Apr 12, 2010
  • 144 Answers
SOURCE: My Carpet cleaner isn't sucking up the dirty
Fairly common problem... inside the dirty water container there is a red flap that has a filter, clean it off and you are good to go.
Zashiban
Posted on Jun 23, 2010
SOURCE: My bissell carpet cleaner will not suck up the
what could be the problem
Posted on Jul 10, 2010
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
I have a Delonghi Multi Vac M31 and have never used the wet part...I would like to clean my carpet using the wet vacuum...can you please tell me how I can do this? Many thanks
A good place to start is the owner's manual. If you don't have one, you can google the make and model of your multi-vac to get another copy.
Most wet-vacs work off the same principle. Pre-vacuum the carpet to make sure there is not normal surface dirt and dust. Next Squirt on hot soapy water, scrub it in - then suck up the dirt and collect the dirty water.
So after vacuuming the area to be wet-vacuumed and you are lucky enough to have a separate reservoir on the wet-vac unit - add pre-mixed carpet cleaner into hot tap water (with carpet cleaner mixed into it by the ratios described on the carpet cleaner soap bottle) to the multi-vac water reservoir (from a quick look, the Delonghi doesn't have one) . With the settings for wet vac (per the owners manual), squeeze the trigger for applying the carpet cleaner. Typically, you will go slower than normal vacuuming. Give it a chance to soak in and dissolve/lift the grim and dirt. Come back slowly to pull the dirty water out of the carpet.
There are multi-wet vacs (like the M31) that don't have a reservoir for the carpet cleaner. In that case, you need to pre-mix a couple of gallons of carpet clean in a separate container or bucket. Next spray or sprinkle carpet cleaner onto/into the carpet. Try to scrub the cleaner into the carpet to really get at the dirt and lift it. Next is to vacuum up the wet stuff.
Some carpet cleaners do not contain an anti-foaming agent. I recommend you either add an anti-foaming agent or buy a carpet clean product that already contains it - otherwise, it tends to be a big mess that takes a lot more time.
I hope these tips help.
Nov 07, 2014 | Vacuums
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
Cleaner wont release or **** up water off the floor
There are a few different problems this could be. Usually when someone says it won't extract water off the floor it is because it is not squirting any water. If it is not doing either then you have more than one problem. You can try to pour some water from a cup onto the floor to see if it is extracting water from the carpet. water not squirting could be clogged jets. Look underneath at the red jets and make sure they're not covered with hair or dirt. You can remove and clean them. It could be the pump is not working properly. On some Bissel units the pump has a cogged belt that turns the brushroll. If sometihing gets caught in the brushroll it can strip the teeth off of the pulley on the end of the pump which means you have to buy a whole new pump. Another problem I occasionally see on this unit is the pump gets full of soap suds and will not pump water. Sometimes I can get it working agian by removing the lines and flushing out all the suds.
Jul 18, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My Carpet cleaner isn't sucking up the dirty water. Squirting out the clean water and cleaner just fine. What's wrong?
Zashiban
Jun 23, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Cant squirt water, nothing is coming up from the carpet
Try filling soap solution tank with hot water and make sure that the red filter in the pickup tank is not clogged, and always run hot water in solution tank after cleaning carpet. steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
A friend loaned me her Bissell Proheat Turbo carpet cleaner and I don't know how to use it - any help?
I like these cleaners.
First vacuum your carpet very thoroughly.
Depress the lever to tilt back the handle.
Grab the tank from the base. Remove the lid.
Fill the bladder with hot tap water. Replace the lid, and place tank back into the base. Put the handle back upright until it locks into place.
Take the soap container on the side and fill it with the Bissel soap solution. Place your dial on floor cleaner, and select either soap or heavy traffic.
Turn on the machine and the heater. Take your machine to the far end of the room and depress the handle put the machine in the corner depress the trigger and you will see a little spinning thing on the machine starting to spin - this means that the solution is blending and the spray is wetting the carpet. Pull the machine slowly back towards you about three feet and then let go of the trigger and pull the machine a couple more inches. When you stop the trigger will release. Push the machine forward and repeat the pull pass this time without depressing the trigger. For the next pass - overlap each and every pass (I do each pass at the half way point). Do this along the back wall. When you depress the trigger and that spinning dial does not spin - you are either out of water or out of soap. Go over the entire room with this technique.
Now this next step is VERY important. You have to do the whole room process AGAIN - this time with NO SOAP. I have used these machines for years and trust me - if you don't go over it again - your carpet will be a magnet for dirt. This time empty out your soap cup and rinse it out and refill it with WHITE VINEGAR. Again fill your tank with hot water. Re-do the entire room as if you are shampooing the carpet.
Let the carpet dry overnight - the next morning I would recommend applying scotchguard carpet protector (you can get the cans at H.D. or Lowes. Yes the Bissell solution has scotchguard, BUT when I apply the scotchguard again - the carpet stays so much cleaner so much longer.
Do it right the first time and don't cut corners and you will have the cleanest carpet on the block. It's a long process to do it right, but the end result is worth it.
OR if you want to save money and use something more environmentally friendly - fill with white vinegar. This will work just as good and leave your carpet less sticky from the soap and your carpet will stay cleaner longer.
Mar 19, 2010 | Bissell 1699 ProHeat Clear View Upright...
Dirt Devil Featherlite carpet shampooer won't release solution
Had the same problem only after 2 uses, called the 1 800# said that soap may have "gummed" up the line did everything they said but didn't work. Would cost more in service repair if I could find a authorized dealer to fix than I paid for the machine. Would not recommend this machine to anyone.
Jun 10, 2009 | Dirt Devil CE6100 Featherlite Upright...
My bissell powerbrush won't **** up the water
had same problem - carpet soaked with dirty water and very little, if any, cleaning fluid used. Easily remedied. Removed water resevoir and found that the rectangular shaped washer at the top of the front cover (the bit you had unscrewed to give a good clean) had become dislodged. It has small lugs on either size which lock on to the plastic opening when pushed down firmly. Resevoir then sits on top and makes full connection, also ensure that grey locking handle is fully pushed down.
Seemed to me that the water wasn't being sucked up as there was air getting in and this has down the trick. Sorry if this is difficult to follow but all will become clear when you look for the black washer! Good luck
Mar 18, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Need to get water out of my carpet
There is a lever to switch from "clean" to "tools". On the tools setting, it doesn't suck up water.
Sep 03, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
