Question about LG Studioworks 45 14" CRT Monitor
Wanted default factory settings
Sir, my zenith monitor z775cp's settings is disturbed by me accidentally while increasing the brightness. monitor is not displaying picture correctly like before .it's display tilted left side and turned little bit .the pincushion parallelogram and corner all the settings are disturbed i have spent lot of ours in this now it is little bit close to default setting but not perfect. Please can you tell me the default factory setting of this monitor setting
  • 26 Answers
SOURCE: dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Posted on Jun 19, 2007
SOURCE: LG Studioworks 700E
have a technician open the monitor..quite easy. Then solder the joints that connect the vga cable to the board at the crt. Solder also the main components of the crt board. good luck,
Posted on Mar 12, 2009
  • 7 Answers
SOURCE: Cannot play rise of nations it says monitor display mode is set
Right click the desktop, click "Properties", go to the "Settings" tab and under "Color quality" choose "Highest (32 bit)"
Posted on May 28, 2009
  • 173 Answers
SOURCE: How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
Posted on Jun 13, 2009
anjana03
  • 361 Answers
SOURCE: LG - L192 WS LCD Monitor displays blue color
it isnot softwere problem. we can not solve in home. lcd graphi can be reset.which we can get in net it can be solved by expert. once atime i get it in web side, t
Posted on Jun 15, 2009
Brightness set to all the down
There should be a menu button on the monitor. Press this button, it has it's own brightness settings. Press the "factory settings" button; monitor should return to normal brightness.
Sep 19, 2013 | Dell Dimension™ B110 PC Desktop
Monitor default settings
Just play around with it, till you get what you like.
Sep 13, 2013 | Dell Inspiron Computers & Internet
Sir iave an IBM desktop and the monitor windows
Press Fn+F5 to decrease brigtness Fn+F6 to increase brightness
Try this please.
Jul 05, 2010 | IBM E74 17" CRT Monitor
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Hansol710p 17"Monitor color adjustment problem
wich is factory colour profile from hansol 710p ? thanks in advance p.s. jovica.tasic@hotmail.com
Jul 25, 2009 | Hansol 710 P Monitor
Brightness adjustment
controling chip is gone, needs repair.
Nov 28, 2008 | Hyundai ImageQuest V995 19" CRT Monitor
Colors have gone wrong
There could be 3 reasons for this...
1. If color settings are changed from the computer...
try to reset to defaults
2. if colors are changed from monitor..
try to reset to factory defaults
3. If the Monitor cable is loose..
try differnt monitor if available with the same cable which is used to connect monitor and computer, or try using different cable on same monitor and computer.....
Nov 02, 2008 | Dell E176FP 17" LCD Monitor
Zenith CRT monitor- Z775CP
hay ..my zenith crt monitor does not show any photo with its true colour.. photos are somewhat black not the right brightnes is seen.
can u help me....
Jul 04, 2008 | Zenith L13V36 13" Flat Panel LCD Monitor
LG Studioworks 45 14" CRT Monitor Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
