Question about ASUS K8V-VM (K8V-VM GREEN) Motherboard
Restarts, then shows boot block compatible version
As soon as i switch on the pc.. it shows boot block compatible version ver.003..
somtimes XPloads.. if so system vl be proper for more than half an hour then again restarts and shows the same problem..
i had changed the cmos battery... stil it shows the same problem..
sir, kindly slove my problem
    Novelist:
    Champion:
  • 256 Answers
CMOS batteries last at least twenty years. Why is it that people get so enchanted with mother Board and BIOS. That area of a computer is the most delcate and you guys hit it with hammers and scredrivers. On the serious side, the clues you gave me seem to be that the registry has been tampered with. I think (and I have been wrong so many times) you need a re-installation of the windows. When you do this push the "R" on the second time and you will be charged with one windows install. I never paid any attention and I had to buy a new disk for windows... Thank you for your consideration and your choice to choose our service. My name is Constantin (arzconst is my internal nickname for Fixya.com).
Posted on Jun 19, 2009
I Faced Same problem. I found that CPU was bad. Try replacing the CPU.
Posted on Jul 02, 2009
00602-003 error
Your hard disk needs to be replaced!! E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed.. Once this is done you dilemma begins, Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the HDD from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the HDD and it will pup up ready to go.
Apr 22, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
Boot block campatible version ver.024
boo block campatilble version ver. 024 for asus Eee pc 900
Feb 04, 2013 | ASUS Eee Computers & Internet
Computer starts but doesn't beep, and comes up with a message saying book block compatible version ver 0.16
Check this site and read on how to fix boot block. It sounds like there is a problem with your bios and it needs repair or recovery.
http://www.ehow.com/how_2185633_fix-boot-block.html
Nov 16, 2012 | Computers & Internet
BAD BIOS CHECKSUM, STARTING BIOS RECOVERY...
I have seen this be a CMOS battery many times. Also, you can try flashing the BIOS if you continue to have troubles after replacing the battery. You should be able to find that information on the motherboard manufacturer's website.
May 05, 2011 | Computers & Internet
Asus k8v-vm mother board drivers
boot block compatible version ver 003
bad bios checksum, start recovery
is alone window seen in my computer
Dec 26, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Bios
Try to go to safe mode choose system restore. If you cant get through it. Unplug your power cable.Then its time to open your pc ground yourself with anti static pad b4 touching it to the computer. Take the cmos battery, return it after 30 seconds or more then put back battery again. Plug your pc turn it on. If is not working try to update your bios.
Jun 27, 2008 | Intel Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Bios failure
you may have a flat cmos battery, but first try reseting the bios by the cmos reset terminals, refer to the manual
Sep 14, 2007 | ASUS A8V-VM Motherboard
ASUS K8V-VM (K8V-VM GREEN) Motherboard Logo
1,359 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
