Question about TEIN Honda 2001-2005 Civic EM2/ES1, 2Dr/4Dr *Note for 2002-2003 Models Super Street Damper Kit OEM Upper Mount, DSA22-KUSS2
Automatic transmission not working but engine starts smoothly. But the check engine light is on.
Putting to d shift does not feel that the car is on gear, and the running idle.
  • 3,904 Answers
You have one of several problems ranging from 150 to 2500 in your transmission. The sooner you get it in to a pro on this one the cheaper it will be.
Posted on Apr 20, 2014
Ford escort w/automatic transmission - shift stick not smooth anymore
first check the gear oil or replace it before you change the automatic gear completely
Dec 04, 2013 | 2003 Chevrolet Impala
Can thermostat stuck open on 2001 vw beetle affect automatic transmission performance?
No the thermostat would not have any thing to do with it not shifting properly,
Dec 04, 2012 | 2001 Volkswagen New Beetle
Shifting in higher gears
For Automatic transmission problem,Check the list of help links below.click the link below:----Automatic transmission troubleshooting:----
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Transmission shifting problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This will help.
Thanks.
Feb 09, 2012 | 2000 Isuzu Rodeo
The shift doesnt go into gear one and is very hard to put it in park. It feels as if it is getting stuck. How can I fix it that the shift will shift gears smoothly?
have your transmission oil replace, drain the old oil and put some gear cleanser about a liter or two then start the engine for about 5 sec., then drain again for the dirt to come out before putting your new oil...
Aug 17, 2010 | 2000 Chevrolet Venture
Shifting problem when starting off from a start
Hi, the problem may be simple. Try to check the automatic transmission fluid and filter for it may be burned and needs fluid change. A smooth run will be noticeable after doing this.
Mar 01, 2010 | 2003 Jeep Liberty
Yes i have a 96 cadillac deville i just bought i cant feel it shifting.It goes right into gear and goes down the road but dont feel it shifting.
Try manually shifting it and see if you can feel it shifting.You should be able to.Then just drive it in drive light normal and see if you can feel it.Usually you will get a check engine light or have the transmission codes checked if you do feel it.Sometimes these transmissions are very smooth.Hope this helps.
Dec 19, 2009 | 1996 Cadillac DeVille
Check engine light on, auto transmission shifts gears abruptly
It should still be under warrenty Take it to the shop for repairs It is a transmisson problem but many things can cause the transmisson not to shift correctly. Call your service department and ask if you should drive it in or have it towed and do not drive till you have it figured out. If you have a warrenty and continue to drive it will void your warrenty.
Sep 29, 2009 | 2006 Toyota Corolla
No reverse
the trans needs to come out and be rebuilt
Jan 17, 2009 | 1998 Jeep Cherokee
Transmission drags upon take off
I would undo all of it / unplug all of it and see what happens.
Sep 10, 2008 | 2005 Nissan Titan
TEIN Honda 2001-2005 Civic EM2/ES1, 2Dr/4Dr *Note for 2002-2003 Models Super Street Damper Kit OEM Upper Mount, DSA22-KUSS2 Logo
53 people viewed this question
Top TEIN Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a TEIN Luggage and Travel Expert? Answer questions, earn points and help others
