Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi 55859 convergence--blue line won't line up
  • pappazon Jun 19, 2009
    Yes on the conver off---yes I have tried--yes the crosshairs move on both red & blue. Is this something a novice can fix? I live way out in the country so a shop will charge a lot of money to come out and I have no way to take it to them. Tks for your help.
    Genius:
  • 1,030 Answers
If i understand you right your blue convergence is off? and you have tried to go into the adjustment for the convergence? now do you crosshairs move up and down and left and right? on bpth red and blue. I see two possiblitys for this your convegence output ics commonly called stks or and you convergence ouput resistors. not a difficult repair for most shops and aroud 250 for parts and labor the ic run about 45 apeice
Posted on Jun 19, 2009
Getting double image,red, blue, can fix temporary with remote by lining up all the color. I have Mitsubishi model WS-55859 .
Model indicated uses a single Convergence IC----STK-393-110, ABOUT a 15 dollar part on Ebay.
A lot of these sets had problems where the pins break loose INSIDE THE CHIP--causes the kind of problem you are having.
Good news is I have start to finish, step by step instructions for this repair in this model----it can be a do it yourself job.
Most shops get well over 300 for this repair--if able to do it yourself, total parts cost will be under 30 dollars.
I can post the instructions here or if you have a email send to you-----they are free.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 02, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Blue lines and red and blue haze and can not adjust convergence
the blue lines could be retrace if theyre arced and thin.. that could be a bad blue crt or just need to turn down the screen control. If both issues were at the same time, might have a fluid leak and maybe look inside and see if any dripped down from the crts. here is my convergence tutorial:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 12, 2010 | Mitsubishi WS-55859 55" Rear Projection...
I have a mitsubishi ws 55859 that has a green blinking light. and the TV wont turn on. Don't know how to fix it
The convergence board or the verticle is bad. needs professional repairs can cost anywhere from $ 180 to 350. Check it out at www.fixurtvs.com.
Feb 22, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Red line isn't straight and there is red in background
if red is bent or curved could be a simple fuse on convergence board. possible defective red convergence ic.
Nov 11, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Red lens problem, red line isn't straight
possible fuse on convergence board. possible defective red convergence ic. "red lens" is fine. it is a electronic problem
Mitsubishi model ws-55859 tv is red and red
If it is WS-55859 and you go into the customer menu and find red or blue are skewed and will not adjust---you have a convergence problem.
This model uses a single STK-393-110 convergence chip--it and any of the protect resistors around it that are bad will need to be replaced and the set adjusted.
The chip can be purchased on Ebay for about 12 dollars plus shipping--total parts cost should be under 30 dollars!
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS MODEL.
They tell you everything you will need and how to do the repair---If you or someone you know can do it I can post or get the instructions to you.
If you cannot do it shop around your area--most shops are going to get 300 or MORE for this kind of repair and many will not do in in your home--Any good tech can do it in your home in about 1 hour--I know as I have done hundreds of them.
If you have questions or need help let me know--I am here to help people.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Mitsubishi WS55859, was getting 2 and 2 blink, replaced the pico fuses and convergence chip - 3 times, each fix worked better than the next but evenually failed - now have it working, trying to adjust...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Mitsubishi WS-55859 55" Rear Projection...
My mitsubishi WS-55859 picture is not as clear as it should be and there are horizontal lines across the middle 1/3 of the screen. I also notice a green ghosting on some images and some colors. Any ideas?...
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 13, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Blue curved line near top of screen and out of focus if hand is held over blue light it goes away
It sounds like the convergence circuit has failed for the blue. The repair should be done by a professional. Cost wise you are looking around 250.00 to 300.00.
Hope this helps,
Skyassoc
Jul 16, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Timer light flashes tv won`t turn on. mitsubishi model #55859
You have a bad DM board - the capacitors are bad and need to be replaced. I was able to replace them myself. There are no replacement parts available and many repairmen will charge hundreds of dollars and there is no guarantee they will fix it.
Jul 06, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
94 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
