Question about McCall 7-7045T Commercial Refrigerator
McCall 7-7045T light will not come on. Changed the light bulb already.
  • Dennis
    Dennis Apr 23, 2014
    Thanks, got it working
  • 884 Answers
Check the switch inside the door
Posted on Apr 22, 2014
Parking brake light keeps going off, even when I changed the fuse twice
If you mean the brake lights, then check the bulb sockets for corrosion. Battery cleaner works for this. If the tabs are black, they are arcing. Use a paper clip and bend the tabs towards the bulb.
Sep 04, 2015 | 2005 Volkswagen Jetta
I have a McCall 4-4070FC i need to find out how to turn on the Lights and Door Heaters?
Your light switch is white generally around frame... As for door heater it will be on as soon as you plug unit it. You can feel around door jam to see if heating... Should be warm not scalding hot. McCall was sold to manitowoc and some parts are no longer available. If you're able to do repair yourself try case parts.
Nov 30, 2014 | McCall Freezers
2006 F350 super duty 6.0 diesel no back up lights all other lights work I have changed fuses and relay what next?
Check to make sure the bulb sockets are tight and free of corrosion. Moisture will often get inside. If this is not the culprit, grab a multimeter and make sure you have a good ground.
Mar 28, 2014 | 2004 Ford F-350 Super Duty
Specs of tev for mccall freezer
you need model number and serial number . refrigerant type and possibly the compressor model number to determine the txv type and capacity
Nov 26, 2012 | McCall Refrigeration Commercial Freezer...
My tail light wont go on but I changed the bulbs and the fuses.
Sounds like a wiring issue. Possibly a bad ground. Need to take that to someone and have it checked.
Sep 24, 2012 | Nissan Hardbody Cars & Trucks
Back up lights not working and already tried replacing the bulbs. Thanks.
If u have already changed the bulbs and its not working means that your censer switch located with the gear box is bad or the wires on the switch are broken pls check
Jan 31, 2011 | 1997 Pontiac Grand Prix
On my f250 super duty, the left low beam head light does not work - high beam OK. Already changed bulb
my 2000 f250 did the same thing. i did what you did also. changed bulbs everything else, but had to bring it in to have the wireing harness changed and that seamed to do it. Check the connection (plug) that goes into the light. mine was over heating and causeing the bulb to burn.
Sep 20, 2010 | 2000 Ford F250 Super Duty Crew Cabs
My passenger head light went dim and i changed it to a brand new bulb already and it is still low
You got a bad ground connection somewhere.
You have a voltage drop,where you shouldn't have,and as a result the bulb is dim.
Check the bulb socket/connector and related wiring, to that head light
May 21, 2010 | Cars & Trucks
Hello im having a problem with a 1999 grand jeep cherokee. one of the top back light when one brakes it light offs. i have already tried new bulbs, and new fusus.. when i turn the lights on, both back top...
thats a missing ground on that light socket thats not working properly .. it can also be caused by a defective bulb even if new (not in your case since you have already changed the bulb)
Feb 19, 2010 | 1999 Jeep Grand Cherokee
McCall 7-7045T Commercial Refrigerator Logo
83 people viewed this question
Top McCall Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a McCall Refrigerator Expert? Answer questions, earn points and help others
