Question about Whirlpool DU810SWPU 24" Full Console Dishwasher with 4 Cycles, 1 Option, Large Tub Capacity and Quiet Wash Sound Package: Black
Dishwasher leaking water while filling
  • 957 Answers
When does it start to leak? I mean how much water goes in before the leak starts. I have a problem every once in awhile with mine leaking when the float in the bottom of the washer gets stuck and does not shut off the water. The way to check this is to locate the float, it is near the front left side, and push it up and down a few times to make sure it is not stuck. Try the washer again. If that is not the problem u could have a leak from the drain under the dishwasher. Sometimes the plastic can crack and cause a leak. Also check the discharge line and make sure it is not the problem.
Posted on Apr 20, 2014
Water overflow then no water
It may be a sticking float switch. The float switch controls the level of water in the dishwasher and if it is sticking on or off it could cause them problems you have
part numbers 263834 and 263185.
Hope this helps
Jan 02, 2014 | Bosch 23 in. SHU3302UC Built-in Dishwasher
LG drains and fills at same time.
This is caused by the " the flood" circuit at the bottom of the dishwasher that detects some water leak. Once this circuit detects any water on the bottom of the washer, it immediately switches the pump out circuit on. It consists of a polystyrene float coupled to a micro switch. You need to dry the bottom and then check for leaks (hose or hose clamp).
Jul 03, 2013 | LG LDS4821ST Stainless Steel 24 in....
My Hot Point Dishwasher is leaking water. It was
Hi
Check for any kind of leaks around lower spray arm or soap door. Replace the arm if any cracks are found. Also make sure that door latches firmly, and the gasket is not cut.
The leak can also happen due to a broken fill valve. To check, take off the access panel from the front of the dishwasher so you can reach the fill valve attached to the metal bracket. Use a multimeter to check the continuity across the two black terminals at the top of the fill valve. If it reads 120 V, replace the fill valve. Make sure the thin filter screen between the bracket and fill valve is not blocked by debris.
Please post back for any further assistance.
Daniel
Jul 23, 2010 | Hotpoint 24 in. HDA3400G Built-in...
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Dishwasher is leaking and backing up with water
Sounds like the door gasket is leaking allowing water to come out
Apr 29, 2009 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwasher will not take in water
On bosch dishwasher if the base senses a water leak the unit will not fill & the drain pump will come on. I recommend checking for water in the base & locating the source of the leak if you see water in the base. Other possibilities; fill switch, water level switch or water valve. There is no reset for this problem.
Mar 08, 2009 | Bosch Dishwashers
Leak from dishwasher fill funnel
Hi . the air gap is required by law, to have it there.to stop water in the tub, to end up in your water system, which would never happen. try setting the pressure down, and use the dishwasher. it should work fine . turn down taps ,till it stops leaking . should be ok
Oct 06, 2008 | Kenmore 15129 Built-in Dishwasher
Dishwasher filles up with water between running it. I have to run the drain cycle at least once or twice daily. I have shut off the water valve to it for now.
sounds like the water valve is leaking.If there is some dirt in the valve it will cause it to not fully seal and shut off. If the hapens water will leak by. Replace the inlet valve and your dishwasher will not fill when its not in use
Jul 16, 2007 | Whirlpool 24 in. DU920PW Built-In...
Whirlpool dishwasher leaks everywhere
your tub seal needs to be replaced. you might have damaged it when you moved it
Jan 25, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Kenmore Dishwasher 665.1671590 Leaking water at fill funnel.
Step1
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Step
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Step
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Step
5
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Jun 08, 2006 | Kenmore 15129 Built-in Dishwasher
Whirlpool DU810SWPU 24" Full Console Dishwasher with 4 Cycles, 1 Option, Large Tub Capacity and Quiet Wash Sound Package: Black Logo
76 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
