Question about Sony STR-DE915
I have a Sony STR DE915 amp. It will not power up. I checked the internal fuse (it's OK). Power button has dislodged and may be broken. Am looking for disassembly instructions (not schematic diagr
Unit worked a week ago, then would not start again. No change to system. No crossed wires. Unit is now partially dissembled, but I'm hesitant to pull boards off without knowing proper order or precautions. The power button has become dislodged and may be the problem.
    Problem Solver:
  • 17 Answers
Simple, if you are not confident in your ablility to fix the problem by dissasembling the boards then by all means, take it to a repair facility.
Posted on Apr 22, 2014
Testimonial: "I was able to get down to the power button, and repaired it. Unfortunately, the unit still doesn't power up. At this point, I'm not afraid to tear into the thing, but don't really know where to start looking."
  • Ray Simmons Apr 24, 2014
    If no fuses are blown coming off the power supply you need to check the power supply itself for the voltages needed to run the unit. you can still have a short or a missing voltage on your outputs shutting down the unit without blowing the fuse. It can get very in depth troubleshooting. You should take it to a technician who is good with sony products.
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Posted on Mar 13, 2008
tech48
  • 624 Answers
SOURCE: STR-DE525 Blown fuse
Not very likely that you can fix it yourself with little electronic skills. You fried the channel you had it connected to. It will require the replacement of a lot of parts in the amplifer circuit. When a channel blows it has several transistors, several resistors, sometimes a couple of diodes and capacitors, and sometimes with the sony amplifers a pre-amp driver IC that will need to be replaced. You will require a multi-meter to determain which parts must be replaced, a soldering iron, some solder, and some solder wick to remove the solder from any bad components that must be replaced.
Any time you connect more than 1 speaker to a channel you risk over-heating that channel and shorting out some components. There are no amplifiers that are designed for more than 1 speaker per channel. I have repaired many sony recievers, including the one you have on several occasions, in the 18 years of working as an audio repair technician. With 2 speakers on the same channel you will draw double the amount of current thru the amp circuit than it was designed for. With 3 speakers on the same channel you will draw triple the amount of current and so on, and so on. I am really surprised that it played for more than just a few seconds with that many speakers on one channel. It must have been in really great shape to start with. I am sorry you did not know this before your party, it would have saved you some money.
Now the good news!
It should be able to be repaired. If all the speakers you had connected were really all on just one channel, you should have only one channel bad. This is a nice receiver as I am sure you must know, since you own it. It is worth getting repaired. As I have stated, I fix these for a living and I would expect the repair cost to be around $125 to $150 if it was taken to the service center that I work at. I can not be certain what another shop would charge, but this is a pretty good estimate considering I do not have it right in front of me to troubleshoot. Some shops are more honest than others, and there is always the chance that there may be more damage than what I would anticipate, or even less damage than I would expect resulting in a cheaper repair.
If you want to take a crack at fixing it yourself I would be happy to guide you thru it, but you would need the proper tools as I stated above.
I hope that you have found this information helpful, and if so, a rating of "FixYa!" would be appropriate and very much appreciated. After all, it is the only reward we get for offering people like yourself this free information and help.
Let me know if you want to try and fix it yourself, or if you have any other questions I can help you with.
Dave
Posted on Sep 16, 2008
  • 5 Answers
SOURCE: sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Posted on Mar 19, 2009
  • 167 Answers
SOURCE: Sony STR-D715 Protect Mode
This is a common problem...
It is in fact a bad power-amp module.
I have repaired quite a few of these receivers by replacing it.
The module is inexpensive. I Googled the Part number and found several sources for it.
Posted on Oct 10, 2009
SOURCE: Sony STR-V333ES repeatedly clicks
You most likely have a short in one of your speaker wires (+ and - are touching somewhere) causing the receiver to enter a protect mode "Click!". Disconnect all speaker wires then connect and test each one at a time to find the culprit. I've seen this happen with speaker wire or a subwoofer cable that is too small of a gauge. Hope that helps.
Posted on Jan 07, 2010
No audio. Checked all the basics. Internal fuses are ok. Is this worth fixing?
Check power supply transformer, that could be last thing before deciding to throw it away.
-SS.
Oct 27, 2013 | Sony Stereo Am Fm Receiver Tuner Amplifier...
I have a SONY STR DE915 receiver home theater amp. After 14 years, it decides not to power up! Are there internal fuses? Can i replace the power supply myself?
There are internal fuses that you can check. This model was notoriously bad for amp problems. These amps would burn up a lot of components when they go out.
Oct 11, 2013 | Sony STR-DE915
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony tv doesn't turn on and there are no lights flashing. Fuse is still intact too. Any thoughts?
Hello
Your TVs internal power supply [usually STR controlled}, is in trouble. It does not outputs any of the internal secondary power voltages. As fuse haven't blown off, there may be some loose soldering around it. Please resolder all the solderings. Check the High Watt wirewound resistors too. Ok.
Oct 18, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No power on my Sony STR-DA555ES
i went to sony's webite and called direct and got a power supply for just under 200 dollars to my door better than paying 1500 for a new one i over loaded mine and plug to may things in the back of it but the part is available
Jan 07, 2010 | Sony STR-DA555ES
Hello, I need help with my sony str-de197 receiver. Then I hit power on button, there is a click sound inside the box, but nothing happens, there is nothing on display too. I have checked 2 fuse's, it's...
It sounds like the switch might be OK mechanically but not electrically. Have a look to see if you can check the connections on the switch. Perhaps there is a broken or loose or bad solder joint.
Oct 28, 2009 | Sony STR-DE197 Receiver
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
Sony Receiver Won't Power On
Did you have any Rca Cables running to a Tv or anything by accident cuz it could run thru those, Lighting is a powerfull substance, if it hit the house then it could of ran into the cable to the tv an went out, thats wierd this is the 1st time ever hearing this, try looking in side to see any burn markings, an take a wiff cuz you can tell if somthings fried by the smell of it, if it is then its most likly dead
Oct 20, 2008 | Sony STR-DE915
STR-DE915
if your preferring to protect light your either, pushing to much power, or a wire could be touching along the line. Check all your wiring even the ones behind the receiver that could be your problem
Mar 10, 2008 | Sony STR-DE915
128 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
