Question about GPS
I accidently reformatted my garmin nuvi 200 fat 32 from my computer when I unplugged it after it was all done and plugged it back in it starts and goes to loading map and then starts over again
  • 2 more comments
  • Terry Rigler Apr 20, 2014
    Also I have tried a hard reset and that did do anything for it and my computer can't find it too
    I also put a file on a SD card GARMIN and then inside the file i got a GUPDATE.GCD and put it in the folder and put the SD card in the garmin now when it starts it gose to loding maps and if I turn it off and back on ti looks like my garmin but there is a pop up and siad it can't find the maps and then restarts all over again
    Ther is no way for me to get back into the garmin my computer can't see it or the web update can't find it
    I need my computer to see it first and then the web update will see it too
    Problem Solver:
  • 13 Answers
Check gps own site n update firmware and try again
Posted on Apr 20, 2014
SOURCE: GARMIN NUVI 200 SAYS NO DETAILED MAPS FOUND THAT SUPPORT ROUTING
From the Garmin web site:
Question: What should I do if my Garmin nuvi / zumo displays the message “No Detailed Maps That Support Autorouting.”?
Answer: Please follow these steps to troubleshoot the error message:
Checking the unit:
  1. Hold your finger down on the screen until the message “No Detailed Maps That Support Autorouting” disappears.
  2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for “Getting your unlock codes”.If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
  3. Check the box next to the mapping product City Navigator and you should no longer get the “No Detailed Maps That Support Autorouting” message.
Posted on Jun 29, 2008
  • 8 Answers
SOURCE: nuvi turns off after loading maps
Try to charge the battery.
Posted on Jul 30, 2008
marcelbakker
  • 174 Answers
SOURCE: Won't stay on
Have you installed anything lately? Do you have any sd card installed? Usually this is the cause for it to crash. There is a reset on the bottom of the nuvi, when it locks up blank, press the reset button and see what happens...
Posted on Jul 08, 2008
I had the same problem. What you do is place your finger in the lower right corner where the green button would be and cut it on. When the prompt comes up, click yes. when the no detailed maps comes up again, hold down the green button again. You should then be able to upload the maps.
Posted on Mar 21, 2009
madguy1089
  • 21 Answers
SOURCE: Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Posted on May 27, 2009
When plugging into car outlet Garmin 200 goes into computer interface mode
You have to use a car charger with sufficient power capacity for your Nuvo 200.
I've used a mini USB car charger that came with my e-trex, but it works only some times when I do plug/unplugging during map loading (manipulating the computer mode setting). So, I bought a HTC mini USB care charger, and know the problem is solved. Another alternative is buy from Garmin Store, the type they recommend.
May 30, 2010 | Garmin nuvi 200 Car GPS Receiver
Tip
Garmin Nuvi 255W Favorites Backup and Restoration Procedure Models: Garmin...
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Would you like to back up a copy of your Garmin Nuvi 200 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
_________________________
Garmin Nuvi 255W Hard Reset Here.
Download Nuvi 255W Manuals here.
Garmin 255W WebUpdater here.
on Apr 18, 2010 | Garmin nuvi 255W GPS Receiver
Tip
Nuvi 255W Webupdate
Garmin Nuvi 255W Webupdate
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Garmin Nuvi 255W Favorites Backup here.
Can not find a USB slot in my Garmin Nuvi 200
I can help you update your Garmin Nuvi 200.
Here is a picture of where the USB cord plugs into your nuvi:
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 21, 2010 | Garmin nuvi 200W GPS Receiver
Have accidently wiped mapping from garmin sat nav
I can help you fix your Garmin Nuvi 200.
The error message you are receiving about maps is actually a sign of a firmware corruption problem, which just happens from time to time with electronic devices. Updating the firmware of your nuvi will replace the corrupt firmware.
Download and then run Garmin 200 WebUpdater to replace its firmware / system software. Occasionally a nuvi 200 will also need a Hard Reset (preceded by a favorites backup) to bring it back to 100% operation.
I hope that helps.
Apr 09, 2010 | Garmin nuvi 200W GPS Receiver
Tip
Garmin Nuvi 200W Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
I hope that helps.
Garmin Nuvi Hard Reset Here.
Download Nuvi 200W Manuals here.
Download Garmin WebUpdater here.
on Apr 18, 2010 | Garmin nuvi 200W GPS Receiver
Tip
Garmin Nuvi 200 Favorites Backup and Restoration Procedure Models: Garmin Nuvi...
I hope that helps.
Download Nuvi 200 Manuals here.
on Apr 17, 2010 | Garmin nuvi® 200 Car GPS Receiver
I bought my Garmin Nuvi 200 a couple of weeks ago but now it won't turn on even when I plug it into the charger. What can I do?
I can help you fix your Garmin Nuvi 200W.
Not being able to start up is a sign that the system software or firmware of your Nuvi has become corrupt.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Jan 15, 2010 | Garmin nuvi 200W GPS Receiver
My Garmin Nuvi (200 I think) freezes..
My recomendation is to use the original accesory for cigarete lighter. I'll give you an example: when I connect my Nuvi 200 to any other USB cable (computer or home charger) its behaviour is like you said - it "says" that is connected to a computer and remains in stand by. But when I connect it to cigarette lighter (but note - the original one) the nuvi 200 recognize it as a car power source and works. The battery symbol disappear from screen and it works perfectly. When I turn off the engine or simply unplug the device from cigarette lighter (not from nuvi !) it recognizez that and ask me if I want tu turn it off on remains on on own battery. If I make no option the nuvi will turn off automatically after some seconds. So it recognize perfectly the car adapter and its behaviour is adapted to a car.
Oct 08, 2008 | Garmin Nuvi 350 Car GPS Receiver
Tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
I hope that helps.
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
Garmin Nuvi 200W Favorites Backup here
on Apr 17, 2010 | Garmin nuvi 200W GPS Receiver
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
