Question about Asko Dishwashers
Asko dishwasher D5233 -- food particles left on glasses after wash
There are many fine particles left on my glasses and dishes after a wash. what do i do?
  • Asko Master
  • 3,247 Answers
Your best bet is to clean the wash arms and drain filters at the base of the dishwasher. If this makes no difference then it is likely the diverter valve is not functioning and causes the drain water to mix with wash/ rinse water.
http://www.repairclinic.com/PartDetail/Diverter-valve/8801389/1489040
See manual
http://www.ajmadison.com/ajmadison/itemdocs/Asko_5233_ADA.pdf
Posted on Apr 20, 2014
  • 12 Answers
SOURCE: dishwasher is leaving food particles everywhere
Dishwashers need cleaning too :) Take a look inside your dishwasher: Click here http://www.appliancepartspros.com/partsearch/model.aspx?model_id=41284 then click on PUMP AND MOTOR diagram on the left. Number 47 on that diagram is a filter. Make sure that filter is clean. Then, using a dishwasher cleaner (see below) run your dishwasher through the entire cycle on empty. This should help, post back if it doesn't. Dishwasher cleaners: 1. Vinegar - good cheap solution, if you don't mind the smell :). Dump a gallon inside an empty dishwasher tub and start up the regular wash cycle. 2. CLR - I've been told it works, but never tried myself 3. Dishwasher Magic - This stuff works pretty good. One bottle per use. http://www.appliancepartspros.com/accessories.aspx?part_id=2675393&cat=62&rdr=%2faccessories.aspx%3fcat%3d62 Hope this helps, APP tech http://www.AppliancePartsPros.com
Posted on Aug 08, 2006
SOURCE: Redeposits material on dishes
We had the same problem and we have managed to resolve it for the most part.  We have found that the detergent makes a huge difference.  Our experimentation found that Cascade Complete powder did the best job.  Also, our old glassware was wide at the bottom and narrow at the top which I suspect made it difficult for the spray arm to get water up there so we bought new glassware and that helped a lot too.  It still happens from time to time but it is pretty rare.
Posted on Oct 14, 2007
  • 9 Answers
SOURCE: Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Posted on Jan 26, 2009
  • 31 Answers
SOURCE: Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Posted on Mar 14, 2009
rylee_smith
  • 8619 Answers
SOURCE: FOOD PARTICLES ON DISHES
Hi
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Posted on Mar 26, 2009
I use siemens dishwasherand recently noticed some grit like substance left on my dishes etc after every wash
There should be a screen under the spray bar. Make sure that is clean. So "grit" is not recirculated in the wash cycle. Is "grit" showing up in your house water elsewhere? Check with clear water glass. Also consider testing with a competitive wash compound to see if there is any difference. A sample or from your friends.
Apr 14, 2015 | Siemens Dishwashers
How to remove large food particle trap in a electrolux dishwasher model # EWDW6505GBO
Good Morning Friend,
I understand you want to know how to remove large food particles that are trapped in your Electrolux dishwasher, model# EWDW6505GB0. First, I would suggest that you scrape away large pieces of food before putting any dish in your dishwasher.
Your dishwasher is equipped with a state of the art wash system. Periodically, the Glass Trap Filter and Large Food Particle Trap may need to be cleaned to maximize wash performance. The Glass Trap Filter is located in the center of the Large Food Particle Trap. The Glass Trap Filter is designed to collect pieces of broken glass, straws, bones and pits. To remove items in the Glass Trap Filter, grasp the handle, lift out, empty and replace. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Electrolux EWDW6505GS Fully Integrated...
Asko dishwasher filter at bottom of unit collects food waste - how do you clean?
Keep in mind that there are two filters:
Coarse filter
The coarse filter collects large food particles
which cannot pass the outflow pump.
Lift out and empty the coarse filter as
necessary. Don't forget to replace it!
Fine filter
The residue which collects on the fine filter is
automatically rinsed off with each wash. The
fine filter should still be cleaned once or
twice a year.
1. Remove the fine filter by first turning the
filter's tubular strainer anti-clockwise and
then lifting it straight up with the coarse filter.
2. Clean with a dish washing brush. Ensure
that the edges are properly sealed
Download the manual and go to cleaning page.
Jun 05, 2011 | Dishwashers
Our Asko dishwasher no longer cleans the top shelf of dishes properly. Fine white and black grit is left on the dishes after every wash, and if there is any food residue on the dishes it does not come off....
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Check also that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Feb 04, 2011 | Asko 24 in. D3350 Dishwasher
My Asko D1976 dishwasher is not cleaning dishes properly. There is a lot of clumped detergent left in the dispenser after wash cycles are complete, and many of the dishes have dried-on food left on them. ...
First of all, don't pre-rinse the dishes. Check the water temperature, it should be between 120 and 140 degrees. Be sure you are not partially blocking the dispenser door so that it isn't opening.
Sep 18, 2010 | Asko D1976 Built-in Dishwasher
The dishes/glasses on the top shelf are not getting clean
Here is a link to a procedure I put together to clean out your pump. A plugged up sump is the most common reason for poor washing on the upper rack.
Let me know if this helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 30, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishes and glasses are not coming out clean even inside of dishwasher has some residue left on it after washing
Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
Post your model number and I'll try to find a diagram which shows you your parts.
Apr 19, 2010 | Kenmore 15121 Built-in Dishwasher
Residue and small particles left in upper rack dishes and glasses. maytag mbh940aww dishwasher.Is there a filter to clean?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Yes there will also be a filter in the base of the unit to clean. This needs to be done regularly to avoid food getting into the working parts of the unit.
Jan 24, 2010 | Maytag Dishwashers
Unclean dishes food particles left on glasses
Most likely causes are:
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Hope this help. Good luck.
Sep 11, 2009 | Dishwashers
Food particles and what looks like sand consistently left on dishes after cycle is finished
Clean the filter.  It is at the bottom below the wash arm.  Remove the wash arm by lifting it off.  The filter is a round ring the can be lifter out and cleaned.
May 20, 2009 | Dishwashers
Dishwashers Logo
168 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
