Question about LG Heating & Cooling
LG aircon operation light flashes 8 times and then shifts to timer light flashes 4times and then back again to operation light but aircon is not operating.
    Problem Solver:
  • 13 Answers
Jz on the aircon manuly on inside the front door.lift the front on the indoor unit there the on/off button,jz press it.don't use remote it can help u
Posted on Apr 20, 2014
Testimonial: "i've done that,still the same. it says in the faulty codes manual, the problem is the dual sensor is unplugged. this faults indicates that the compressor discharge sensor and the condenser air temperature sensors are both unplugged. Both of these sensors are connected to a single unit connector on the outdoor unit PCB plug it in and the fault will go away. But I don't where is the PCB really should i now call my contractor?"
SOURCE: Fujitsu Heat Pump - problems
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Posted on Aug 08, 2008
SOURCE: i have a Fujitsu ASTA24LCC
Check your filters. Manual says they need to be cleaned every two weeks under normal operation (and in my case more often during renovations). It seems it may not take much to limit air flow enough for the indoor unit to trip out. Hope this helps.
Posted on Aug 24, 2008
  • 3 Answers
SOURCE: TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Posted on Apr 18, 2010
hvac1960
  • 2133 Answers
SOURCE: Operation and timer light flash
Please cancel your timer setting by reset the power. And also remove battery from your remote and reset it. Now start your unit.
Posted on Dec 14, 2010
SOURCE: Operation light and timer light blink 5 times?
If it's winter, you may need to get rid of ice built-up inside that's keeping the fan from turning. Turn the power off AT THE FUSE BOX, open the top of the unit by removing the 4 screws, pour boiling water onto any ice at the bottom until melting, dry with hair dryer a bit, then turn unit back on.
Posted on Feb 02, 2011
What does error message mean on Fujitsu inverter aircon model ASTA30LCC. red operation light flashes on 5 times with green timer light flashing on twice. Can someone please tell me what the fault is?
This is an "Outdoor unit control error" - specifically, a "Current trip error". There is a problem with one or more of the outdoor boards and you will need a tech to diagnose.
Jul 18, 2016 | Fujitsu Heating & Cooling
LG aircon flashes blinking 8 times and the shifts to timer led flashes blinking light 4 times
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.Air Bulance AC Cleaning Repair Services
Apr 23, 2014 | LG Heating & Cooling
LG aircon operation flashes blinking light 8 times and then shifts to timer light flashes blinking light 4 times
Sounds like a 48 code. (There is no 84 to my knowledge).
Outdoor unit coil outlet (liquid line) thermistor has disconnected or has shorted out.
call a LICENSED hvac repairman
Apr 21, 2014 | LG LS-L1210CL Mini Split Air Conditioner
Panasonic inverter aircon R410 A goes to timer all the time
You have to use the remote in service mode to find the error code. Hold the 'check' button in with a paperclip for about 5 seconds and "--" will be displayed on the remote. Press timer up or down will change the error code displayed. When you hear the main unit start beeping quickly for about 4 seconds, that is your error.
Nov 03, 2017 | Panasonic Heating & Cooling
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
Timer green light flashing when turned on but aircon isn't workn
reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Jan 31, 2009 | Heating & Cooling
Fault with 241C Aircon
This happen when you use the inverter for a long time and start getting old and over heat...try to power down the units and keep it for about an hour and then starft them again and try to install a small fan to keep them cool.
May 14, 2008 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
206 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
