Question about Troy-Bilt Troy - Bilt 020316 Pressure Washers
Pressure washer motor bogs for a second
Motor bogs for a second over and over, pressure may be higher than normal
When mixing cookie dough my kitchenaid mixer bogs down when the dough gets thicker .. replaced the brushes already and runs better but still bogs down .. does it need a new motor?
When using the dough hook the speed should be no higher than 2. That said, there is a limit as to how thick a dough the Artisan mixer can handle and you may well have reached that. Under these circumstances it is normal for the motor to slow down.
If the stress becomes too great, the worm (follower) gear will fail protecting the motor from burning out.
The Service Manual covering your model can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Mar 05, 2017 | KitchenAid Food Mixers
What is an uploader
I think you mean an UN Loader this is a valve that redirects (bypasses) the pressureized water back into the intake when you release the trigger When it is not working the machine continues to build pressure and will bog down
hope this helps
the ed
Oct 08, 2015 | Northstar Garden
My Husky Pressure Washer bogs the motor down immediately upon start.
Rebuilding the pump is not easy. Did you use the right seal drivers? Lube the seals when you installed them? Use a torque wrench? But a valve in backwards?
May 04, 2013 | Garden
Lights 2 and 7 and constant beeping
Error code 66 is water pressure sensor.
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Dec 06, 2012 | Fisher and Paykel GWL11 Top Load Washer
Gmc 94 sonoma
When was the last time the fuel filter was chg.? If thats not an issue best to get a fuel pressure test.
Apr 11, 2009 | 1994 GMC Sonoma
Pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
Apr 05, 2009 | Garden
On a generac pressure washer that works fine.
Oil level in pump and motor OK? Spark plug not fouled? Has it sat for a while - carb dirty? Running (loaded) throttle rpm not high enough?
Mar 27, 2009 | Briggs & Stratton Power Products 1539...
Troy-Bilt Troy - Bilt 020316 Pressure Washers Logo
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
