Question about Garden
Assemble part for la145. M112982 and gx20497 - Garden
La145 mower deck will not engage when knob pulled up
Check wires going from harness to pto clutch. If broken repair and try it. Check to make sure the clutch is plugged it from harness.
Sep 03, 2013 | John Deere Garden
John deere LA145 manual
When I start the engine the mower blades start to turn. The blades turn as long as the engine is running. The PTO does not stop the blades from turning even when I stand up off the seat or when I go in reverse. What should I look for to fix this problem. I have a LA145 mower, 48" cut, bought in 2010. Thanks for your time & help.
Aug 02, 2012 | Garden
Color wiring diagram for 100 Series John Deere
Jun 04, 2012 | Garden
I need a diagram for la145 for the deck belt
Hiand welcome to FixYa, I am Kelly
This is the deck routing diagram:
http://jdpc.deere.com/pimages/MP39/MP39302________UN29JAN07.gif
There are 3 models of the LA145. Hopefully this is the correct diagram. The deck belt routing appears to be the same on all 3 models.
Thanks for choosing FixYa,
Kelly
Apr 13, 2011 | John Deere 22HP VTwin 48" Riding Mower
Have a John Deere tractor LA145 Yesterday while mowing the mower blade suddenly stopped working. Turned on and off several times with no luck All pulleys and belts seem to be intact. There was nothing...
Either you need a seat switch or the reverse switch has failed.If the deck will engage while you are pushing down the forward pedal then the rio or reverse switch is not working or it's out of adjustment.If you can not get the deck to engage at all then the problem is likely the seat switch.
May 04, 2010 | Garden
John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
Jan 19, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
