Question about Singer Sewing Machines
Singer 631g I am not able to set the lower pattern selector in position G H I or J but manual shows it should be possible
  • Ulrich Falk Apr 22, 2014
    The lower handle cannot be put in position F G H I J
  • 35 Answers
Have you loosened both screws before trying to move them? Usually both have to be loosened to make adjustments. Have you been able to move them in the past, or is this a new-to-you machine? If they just won't move, they may be rusted or bent. Good luck!
Posted on May 25, 2014
3 Suggested Answers
  • 3 Answers
SOURCE: I have a singer 4830C. Is it possible to lower the
No, but it does come with a cover for them so you may do free-motion sewing.
Posted on Nov 12, 2010
SOURCE: manual for singer 631G
go to the website of sewusa.com & email them & see if they can
help you with a manual
Posted on Aug 04, 2012
I have a Singer 4552. The cord inside top of machine that moves when I turn the stitch pattern selector knob has a spring on the end. The spring came undone. What/where does the spring attach to?
Here is the link for your manual. You can either look for it online here or download the entire manual. Good luck. http://www.manualslib.com/manual/154097/Singer-4552.html#manual
Jun 30, 2015 | Singer Sewing Machines
How do you know what pattern you select
It will be helpful to you to download the user's manual from the Singer site--it is a free download.
To answer your question--after looking at the manual--it appears that if you look at the pattern selector, it should indicate which pattern is selected.
Jun 22, 2014 | Singer 6423 Sewing Machine
I can't move the upper stitch pattern selctor to the K position.
The machine has a series of cams inside and a cam follower which slides up and down the cam stack. The problem most likely is the cam follower is not moving back far enough to allow the lever to move. This can be adjusted but it is difficult to do if you are not familiar with sewing machine mechanics. please follow my link. I may be able to guide you.
Jan 25, 2014 | Singer Sewing Machines
I am missing a pattern selector module 'A' for my Singer sewing machine, model 8234
Well, there are a number of sites that have parts for older machines. Just doing a quick search, I found a copy of the user's manual at SINGER MAGIC 8134 8234 Sewing Machine Instruction Book User Manual . You might also check eBay; they generally have a wide range of parts and accessories for older machines.
Dec 28, 2013 | Singer Sewing Machines
Manual for singer 631G
Aug 03, 2012 | Singer Sewing Machines
I have a singer 5040c and it won't do a zigzag stitch - it just goes in a straight line.
My wife just had this a similar problem with her Singer Omega 36 where she could sew straight and select patterns but could not zig zag. If you open the top of the machine you can see where a little lever connects to the white plastic pattern module that gets inserted in the top. The reason for the problem was that the lever was not touching the bottom of the module properly. The notches on the module cause the needle to move from side to side creating a zig zag. The module needs to be inserted correctly, by this I mean fully and the correct way around or it does not reach the lever when it is in the A position. At first inspection it looks the module could be inserted any way around but there is a thin and a fat clip. You need to try both ways to see which on sits lower in the machine. You may now need to adjust the tension on the machine as the lever will nowe move differently inside the machine. This fixed my wifes problem.
Mar 23, 2010 | Singer 5050 Mechanical Sewing Machine
Inspiration 4205 stitch length won't change
Are you certain that the pattern selector is set for straight stitch and not buttonhole?
Turn the handwheel so that the needle is up and the take-up lever is in it's highest position. Then turn the pattern selector knob through all of the patterns back and forth a few times. Finally, select straight stitch and see if the length works. If not, need to take it to a repair person to determine the course of action.
Feb 21, 2010 | Singer Inspiration 4206
Making a buttonhole on a Necchi 3204 sewing machine
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
Nov 26, 2008 | Necchi 3537 Mechanical Sewing Machine
Singer Esteem I lost manual and need to know how to get it on the stretch setting. Thanks!
Also, you can go to Singer.com and download a manual for free, and then print it after you save it.
Jun 23, 2008 | Singer 3116 Simple
Sewing Machines Logo
141 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
