Question about Belkin F5D8631-4 Router (F5D8631au4A)
Can not connect ps3
Hi i own a belkin 54g router my internet connection works but i cannot conect my ps3 to the playstation network i contact them end they told me that i have to ghange my ip adress and the port but i dont know how.......so if you please tell me how to do it thank you
    Genius:
  • 1,269 Answers
You need to do portforwarding. You can visit this site www.portforward.com and that will show you what to do. You can also try to call Belkin support and they will help you open ports for PS3
Posted on Jun 22, 2009
Bad Belkin 54g Connection Problems!
reboot your modem then reboot the router that should fix it
Jun 26, 2010 | Belkin (F5D7230-4) Router (587009)
I a using cable net and not the dsl line.the net on my pc is working but when i try to connect ps3 wirelessly it show 100% signal from belkin but the internet connection fails.i have tried different...
check the wireless settings of the router .
Make sure that you are typing the correct network key if your network is secured.
May be you will need to open the ports on the router.
Click Here for more information
Jan 04, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
No wireless internet - problem with belkin router
From one of the "wired" computers, connect to the router's built-in web-server, and run the "Wireless Networking Setup Wizard", in order to configure your wireless network, choosing an 'SSID' and a "password" for your network.
Dec 28, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
My psn is timed out????
check the IP configuration of the playstation to make sure it is similar to what you have on yoru PC
Aug 13, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Ps3 game
you will need to enable internet connection sharing. Some laptops have the ability to create a network.
The easiest way to do this is to create a wireless network, and have your ps3 join that network and essentially use the internet through your laptop.
Hope this helps,
Nathan.
Apr 14, 2009 | Belkin N1 Vision Router
Playstation Network timed out
try moving ur ps3 closer 2 ur router dat should make da connection stronger. but another thing is wen da internet router is used by too many appliances certain ones for example ur ps3's internet becomes weaker. i hope dis helped=)
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 networking problem with belkin n1 router
To REDUCE NAT ON PS3 /Xbox
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the PS3/Xbox
Step 7: Get the IP Address of the PS3/Xbox
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the PS3/Xbox in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Jan 05, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin 54g Wireless
please try this
tep 1:
Make sure that your wireless Internet is turned on and working properly.
Step 2:
Turn on the Playstation 3 game console.
Step 3:
Access the "Network Settings" screen under the "Settings" screen in the main menu.
Step 4:
Select the "Internet Connection" tab and select "yes" when the system displays a new screen.
Step 5:
Select "easy" on the new screen that pops up asking what type of installation you want to use.
Step 6:
Select "wireless" when it asks you what type of Internet connection you have.
Step 7:
Select "scan" on the next screen so that the system searches for all available Internet connections in the area.
Step 8:
Select your home Internet when the screen pops up displaying the available Internet options.
Step 9:
Save your settings on the next screen.
Step 10:
Test the connection to make sure that it works properly.
Make sure your wireless Internet connection is at full strength.
Hope it helps!
Nov 05, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Trouble connecting new laptop to the internet
when you put the mouse over the network icon in your taskbar, it will say access: Local & Internet or local only.
if Local & internet you have a connection to the internet, if local only then open internet explorer, tools, internet options, connections and check that there is no default connection, it should be never dial a conection thats ticked or greyed out.
Aug 31, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin router and ps3
Hi Srini here ,
There could be a problem with the wireless configuration on ur belkin router.
Go ahead and type the following in the command prompt of ur computer.
ipconfig
:-This will list out the ip address and the default gateway of the computer
:-Make a note of Default Gate way.
:-Type the default gate way address in to the address bar of the internet explorer.
:-It will take u to the router configuration page.
:-it might ask u to enter router password.(Enter it)
:-In the router page u could see wireless settings options on the lefthand side of ur router confiuration page.
:-Make it appropriate accordingly
:-if u do not know what to do with wireless settings ..then send me ur product details ..will tell u further querries..
Most of the time the wireless device do not connect to router due to wrong "Wireless network key"
:Make sure you have same wireless netwrok settings in the devices as in the wireless router.
:-Send me ur product details and ur setting details like
ISP(Internet Service Provider):-
Brand Name of the modem:-
Model no. of the belkin router:-
If u would like to resolve ur problem soon then send me all details..
Apr 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Open Questions:
Belkin F5D8631-4 Router (F5D8631au4A) Logo
177 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
