Question about Refrigerators
In the morning, i would find about a cup of water that is coming out from under the freezer...
  • 957 Answers
If your fridge has an ice maker then check that when it fills with water if it overflows. if it is then u most likely have a problem with the water inlet valve. It is allowing to much water in the ice maker. It is an easy job to replace. U will find it on back of the unit where the water line hooks up.
Posted on Apr 21, 2014
4 Suggested Answers
  • 112 Answers
SOURCE: Ice forming bottom of freezer leaking out the door
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
Posted on Oct 18, 2008
  • 2694 Answers
SOURCE: whirlpool refrig - i'm finding water under the
there is a drain in the freezer so when the fridge defrosts the water drains down to the pan in the bottom of fridge,your drain is blocked,you need to take off the inside freezer back wall,melt out the ice with a hair dryer and then unblock the drain,i use a steamer to do this,they cost around 50 bucks,the drain line is plastic so you don't want to go sticking anything down the line that can damage it,slime builds up in the line or food particles go down the drain and then ice builds up in the line,the steamer cuts through this and sanitizes the line,if the drain goes strait you can install a heater probe,it's just a piece of metal that you rap around the heater and stick the other end down the drain hole so it won't freeze up again,when you think the line is clear,pour hot water down the drain to make sure it's clear,be careful when melting out the ice with hair dryer,to much heat can damage the styrofoam,make sure the air vents are melted out,they are the holes in the styrofoam,you might have to melt it out from inside the refridgerator section heating the area up on the ceiling,also make sure the control is shut off to the freezer,you don't want the fan to be blowing,good luck
Posted on Jan 28, 2010
heatman101
  • 43501 Answers
SOURCE: water is pooling under vegetable
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 19, 2010
I bought a new water selinoid Valve, hucked it up and the water does not stop at the door. I'm sure I have the lines screwed up BUT what it the correct way, Got a water line diagram??
The problem may not be the value , look under the front of the fridge remove long cover on bottom, you should see the water line that goes into the freezer door and a connector. Disconnect the water line, should be a quick connect and have a cup ready to check the water line and value, place water line from under fridge into the cup and press the switch on freezer door asking for water if water comes out of the water line then the value is opening and you have a frozen line in the door. Please get back with more info, good luck.
Dec 22, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore upright freezer and had it checked. The problem was that it want keep food frozen. The repairman put freon in it and said that was the problem. So put cup of water in there overnight and...
If this is a frost free freezer,the evaporator coils could be frozen over with ice,due to a bad defrost system part.
The freezer fan motor may not be working.
There could be a refrigerant restriction in the lines.
The compressor could be bad.
The refrigerant leak could be large and the refrigerant leaks out quickly.
Sep 19, 2010 | Frigidaire Freezers
Water is pooling under vegetable bin at bottom of refrigeraqtor. Seems water is coming from insude refrigerator under freezer shoot. Placer plastic cup under it and it has collected water that froze....
heatman101
Aug 19, 2010 | Whirlpool Refrigerators
Water accumulated under crisoer drawers and leaking onto floor.
That water is coming from your freezer during the defrost cycle. Normally there is a drain in your freezer that goes to a cup in your refrigerator and through the back of your refrigerator through a drain tube which extends down to a drip pan. If this tube gets plugged up, water will overflow in the cup and leak at the back wall of your refrigerator and through the holes that lead to the crisper's floor area. If you can remove the cup and using a wire dislodge anything blocking the drain, clean the cup of any debris and check your freezer drain for any obstruction causing water backing up and leaking !
Sep 26, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Leaks water from the bottom
Under warranty. Cuisinart will resolve. Thank you.
Dec 08, 2008 | Cuisinart DCC-2200 14-Cup Coffee Maker
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
REFRIGERATOR dRAIN stopped up
SOME REFRIGERATORS HAVE A CUP IN THE BACK OF THE FRESH FOOD COMPARTMENT THAT CATCHES THE WATER AS IT COMES FROM THE FREEZER AND SENDS IT DOWN THE DRAIN TUBE INTO THE DRAIN PAN. IF THE DRAIN TUBE OR CUP GETS A RESTRICTION IN IT, IT WILL OVERFLOW AND BRING WATER INTO THE REFRIGERATOR. CHECK THE CUP AND DRAIN TUBE FOR RESTRICTION.
SOME REFRIGERATORS HAVE THE DRAIN TUBE BUILTIN TO THE WALLS OF THE REFRIGERATOR, BUT THE HOLE IN THE FREEZER IS SMALL AND FREEZES OVER. WHEN THE DEFROST CYCLE COMES ON, THERE IS A BUILDUP OF ICE THAT CAUSES THE WATER TO FALL DOWN THROUGH THE AIR DUCT INTO THE FRESH FOOD COMPARTMENT. YOU WILL HAVE TO REMOVE THE BACK WALL OF THE FREEZER AND SEE IF AN ICE BUILDUP UNDER THE COILS IS PRESENT. THEN, REMOVE THE ICE, CLEAR THE DRAIN HOLE, AND SEE IF WATER WILL PASS THROUGH THE DRAIN. A FIX TO PREVENT FREEZEOVER FROM REOCCURING, IS TAKE A PIECE OF BARE COPPER WIRE AND WRAP AROUND THE DEFROST HEATER AND PASS IT DOWN THE DRAIN HOLE (ABOUT FIVE INCHES WILL DO).
WHEN THE DEFROST HEATER COMES ON, IT WILL PASS HEAT DOWN THE WIRE TO KEEP THE DRAIN HOLE FROM FREEZING UP.
Apr 16, 2008 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
