Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
Produce drawer freezes produce in back left corner. all things have been moved from vent to allow air flow. still freezing Viking 42 side by side
  • 50 Answers
Call viking sounds like you have a air flow problem from the freezer side.
Posted on May 04, 2014
3 Suggested Answers
  • 833 Answers
SOURCE: produce freezes
You've probably set your temp in the main box too low.  It should be about 40 F or 4 C.  Don't leave produce on the bottom of the fridge.  Cold air sinks.  Make sure any 'cold vents' are closed in that bin.
Posted on Nov 12, 2008
philbran
  • 242 Answers
SOURCE: I have a 48' Viking side-by-side refridgerator.
adjust 1 setting 1 number/bar at a time waiting 24 hours each adjustment to see results.
Phil
Posted on Jun 10, 2009
My vegetables keep freezing in the fridge, how do i get the fridge at the right temp?
Remove the vegetable/ produce/ meat draws and shelving that support them. Look along the rear wall or the left inside wall for vents that are feeding or directing cold air to the draws. First try to shut or close these vents down. Or you can tape over them to restrict the flow . The normal refrig temp is between 37 to 40 deg.
Jan 20, 2013 | Viking VCSB423 Side by Side Refrigerator
Condensation. On top off refigerator
You will need to replace the damper on the unit. It is allowing to much cold air into the refrigerator section. Here is the part to order.
Nov 27, 2012 | KitchenAid / Architect Series II...
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Fridge too cold
all food in refrig freezing?
Jul 09, 2010 | Viking 42 in Built In Professional...
My refrigerator produce drawers are freezing all of my produce. I have adjusted to low to high humidity on the drawers and it doesn't make a difference. What is wrong?
Make sure the fan in the freezer is running to circulate the air through the fridge. The cold air will settle to the bottom if it's not. Make sure the vents from the freezer to the fridge are open. There's one at the top and bottom.
Make sure the dampers to the vents open and close when you adjust the temp.
Feb 10, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
LG LRFD25850 French Door Fridge set at 37-40 c keeps freezing produce at back or in large bottom drawer
Pull the drawers put and cover the cold air vent (small hole at back wall) with tape ...problem solved!
Jan 08, 2010 | LG LRFD25850 French Door Refrigerator
Produce in fridge freeze
hI back at you. Oklahoma USA here and hot. You having cooler weather there? Im not femilure with your climate but the produce drawer should have an air damper that closes off to prevent freezing. This damper may not be closing or the refg may be set to cut off an air movment fan motor and the control is faulty. If the knob you turn dosnt stop a hum when you turn it all one way or the other after 2 to 6 minutes the fan is running all the time and now yuou look for the air damper. On some models there is a motorized damper. Ice could be holding the damper open not allowing it to "dampen" freezer air off. Look in the refg compartment with the crisper trays removed and look for a hole between the freezer and refrigerator side. Could be round or square or rectangle. work the control ans see if air flow slowes or increases. Inspect with a mirror fro Ice or other blockage of the damper door.
Let em know how this works out.
Jun 19, 2009 | Maytag MSD2656G Side by Side Refrigerator
Produde tray is freeezing produce
They make a damper kit for the produce compartment to slow down air flow, if you want to go cheap, remove the drawers and look on the back wall, if there is a vent on the BACK wall, cover it with tape, never cover the vent on the lower left, that is your cold air return
Jun 13, 2009 | Maytag MZD2766GES Side by Side...
Produce freezes
Nov 12, 2008 | Viking VCBB363L Bottom Freezer...
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
99 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Joseph Hoffmann
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
