Question about Bosch Dishwashers
Bosch sgi4005au/20 water overflow - Bosch Dishwashers
2 Suggested Answers
SOURCE: BOSCH SMS4472GB/20 DISHWASHER water leaking
Remove the side and top panels of the machine.
On the left hand side you will see a clear plastic panel full of tubes and small tanks. This is the metering tank. At the bottom left of this unit, is a black pipe held on with a clip. There will almost definately be a blockage between this point and the sump. You can either buy and fit a new pipe or do what I did with mine, which was to remove it and clean it with hot water and a bottle brush. Seems to work like new again now.
You'll have to get the machine onto it's right side to remove the lower end of the black pipe from the sump. I drained as much excess water as possible out of the machine by sitting it on bricks, tilting it to the left and catching the water in a dish as it came out of the float hole. Some will also come out of the funny plastic tube which runs across the top of the machine - I carefully removed this first and caught this water in a pan.
Drain the waste pipe and disconnect the water supply.
Replace the right side casing on to protect the feed to the upper spray unit and put the machine on it's right hand side. Once the machine is on its right hand side, fin the water inlet valve and carefully remove its bracket from the chasis of the machine. You will need cross head and a torx screwdrivers - one for each screw. Once this is loosened, push some of the water supply pipe into the machine so you can move the bracket to the right a little to gaine access to the waste pipe. Remove this by removing the two gold coloured screws. This should now give you easy access to the sump end of the black pipe which lead from the metering tank. Remove this and clean it out. Pop all the parts back, stand you machine upright. Reconnect the watre supply and the waste and give it a rinse cycle to test - number 1 on the dial.
Hope this helps. My apologies if any of the take apart is not completely accurate - I don't want to turn my machine over again to check!
Mark
Posted on Apr 12, 2010
My Bosch classixx washing machine is overflowing
Bad water pressure switch or bad water inlet valve? does it have or leak water in the tub when not in use? ( inlet valve) sometimes the pressure switch tube has a hole or blockage in it and will not have the pressure needed to open diaphram and go into wash cycle and it may overflow
Mar 09, 2015 | Bosch Washing Machines
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
I have the bosch shv46c03 diswahsher. We had a tech out that said the overflow pump was running and or broken. It is running because it preventing water overflow damage. TEch says he needs to remove...
Hello, welcome to FixYa.
I agree with you, I cannot see how any repair to a Bosch diswaher would justify or require it to leave your site let alone going to a repair shop. These (as any other manufacturer) are designed to be serviced in the home. To address the problem I would need more detail and clarification. Is the issue that the drain pump runs constant ? Does the tub get drained of water ? Let me know as much as you can and I should be able to assist you...depending on your mechanical abilities/comprehension. Please verify the model is indeed a Bosch SHV46C03. Thank you.
Regards,
Macmarkus :)
Jul 19, 2011 | Bosch SHV46C03 Built-in Dishwasher
Aqua star runs on and was running water to out side I guess it would be the overflow ( tankless). Had to turn the water off
Problem is not clear
Before calling service technician, open following link for Bosch troubleshooting resources including contact information for Bosch:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jun 09, 2011 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
My combi boiler wont pressurize the gauge isnt moving and water is coming out of the overflow pipe.. whats wrong
hi have you tried bleeding the rads this should solve the problem somewhat ,you will need to ajust the overflow in the water tank also but make sure to bleed the rads goodluck
Mar 19, 2011 | Bosch Water Heaters
Have a SHY56A05UC and pump is working during cycle but when done water keeps coming in and eventuly overflows any help would be great..
Welcome to FixYa.
Based on your description, "when done water keeps coming in and eventually overflows any help would be great"... the issue is likely with the inlet/water valve being stuck "open".
To remedy this you will need to replace the valve, not surprising for Bosch unfortunately.
i.e.
As long as your model number is indeed correct, this info below will be accurate.
I say not surprising because this part has been an issue for the B/S/H/ built machines in the past and as a result the original part number 189553 now substitutes to 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it is pretty straight forward. Here`s how...
1) undo the water line.
2) the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in you should be good to go.
Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Sep 30, 2010 | Bosch Dishwashers
Somehow, she added water to raise the amount of water in a bosch front end loader and it overflows when adgitating. how can I manually remove water?
take the drain hose at the back and lower it so its beneath the water level in the drum--the water should flow out--or else open the filter at the front--but thats a bit messy
Nov 16, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Dish washer, Water leaks out of right front corner during first
it sounds like your machine is over filling. the gasket is not supposed to be under water. check the overflow float inside. it looks like a little hat or cone. it should move freely up and down. if it is stuck down, your machine will fill up too far and then leak. good luck
Oct 30, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
22 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
