Question about Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc Honda GCV160 Gas Powered 3-In-1 FWD Self Propelled Lawn Mower With High Rear Wheels
Drive belt comes out - Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc Honda GCV160 Gas Powered 3-In-1 FWD Self Propelled Lawn Mower With High Rear Wheels
  • 711 Answers
There is an adjustment to tighten up the drive belt tensioner pulley. You should be able too see it after you remove the safety shield. Tighten adjustment nut to snug belt.
Posted on Apr 22, 2014
Tensioner belt keeps slipping off front pully
Everett, Do you mean drive belt keeps coming off front pulley?
Possible causes, accumulated dirt/debris above deck or on trans axle, damage,stretched,wrong size belt, belt tensioner seized/missing spring if equipped, belt retainers/guides/keepers damaged /missing/ adjusted to far from pulley, damaged/worn pulleys, loose engine, belt way out of alignment,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Are the Causes of Belt Coming Off Riding Mower
Drive belt keeps coming off when shift into reverse
Need help with mower deck belt keeps coming off Craftsman LT2000...
belt keeps popping off
Jul 20, 2016 | Garden
What belt comes with whirlpool kit # 4392067?
If you have a whirlpool dryer with the lint filter that comes out of the top cover you would need belt #341241, Whirlpool Dryer Drive Belt 341241
That kit looks like a front-lint package...probably contains a #66157 belt. Whirlpool Dryer Drive Belt 661570V
Jul 06, 2016 | Whirlpool Dryers
Why does cub cadet lt 1024 drive belt keep coming off belt
Once the drive belt comes off once - it's probably stretched and twisted and won't stay on. You'll need a new belt - be sure to get one that's Kevlar so you won't be replacing as often.
May 03, 2014 | Cub Cadet Garden
On my washer the belt come off
You will need to use a socket set to loosen the belt tension bolt. Then place the belt over the drive wheels.
Now tighten the belt tensioning bolt, while applying force to the belt to tighten it around the drive wheels.
take care!
damnor01
Apr 28, 2012 | Maytag Washing Machines
Seat belt lights come on when driving down the road
sensor on the seat belt fastener bad. Wiggle it to make it go off with the seat belt locked in place or change the sensor.
Dec 26, 2011 | 2006 Chrysler PT Cruiser
I have an eziloader 6kg dryer, the drum does not spin but the heater element turns on. How do I check if the belt has come off?
can you turn the drum reasonably easy whilst the machine is empty and off . If you can than the drum has no load and the belt is either broken or has come off the drive pulley or the drum . Disconect power cord from socket and remove back off machine ..You know should be able to access drive belt and either replace belt onto drum and drive motor or purchase and fit new belt . It is a good idea to replace a belt that has slipped off and is not broken - belts stretch and its likely to come off again . If this is one with a sealed back then turn it on side and remove base to reach belt .
Aug 13, 2011 | Dryers
A loud noise around the area of the timing belt cover at regular idle. Disappears when driving, then reappears when at idle again.
Dear SIr,
As you saying noise wont come in driving and only comes in idle , it means noise will not come if RPM is high by norma in idle l, try this one start the car don't drive it just raise RPM(rotation per minute of only engine not vehicle speed) in neutral gear , if noise disappear that mean it a problem of drive belt . If drive belt is got less tension then also it can occur or belt is damage, replace belt problem will solve, (for reference drive belt it drive alternator,powersteering pump,A/C compressor that is made by rubber).Thanks if any problem ask me.
Yogesh.
Nov 02, 2010 | 1998 Kia Sportage
How do I change an alternator belt on a '99 hyundai accent?
Call your local National Guard Armory, Fire Station, State College auto program or High School Auto Shop and ask if they have somebody that would come put it on for you. Ask you pastor who the "auto guy" in the church is, if you don't have a church call the biggest church closest to you and ask the receptionist if they have an "auto guy" that would help you. The local senior center or VFW hall have "auto guys" . If you were within 50 miles of 83501 I'd come do it for you.
Removal & Installation Raise and support the vehicle.
    Remove the engine splash shield.
  1. Rotate the drive belt tensioner clockwise to release the drive belt tension.
  2. Remove the drive belt from the alternator.
  3. Slowly release the drive belt tensioner.
  4. Remove the drive belt from the accessory drive pulleys.
To install:
  1. Install the drive belt to the accessory drive pulley.
  2. Rotate the drive belt tensioner clockwise.
  3. Install the drive belt to the alternator.
  4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
  5. Slowly release the drive belt tensioner
  6. Install the engine splash shield.
  7. Lower the vehicle.
It's O.K. to ask for some help.
Jun 09, 2009 | 1999 Hyundai Accent
How do you replace the drive belt on Whirlpool dryer?
What is the model number of the dryer.
Nov 14, 2008 | Dryers
Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc Honda GCV160 Gas Powered 3-In-1 FWD Self Propelled Lawn Mower With High Rear Wheels Logo
164 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
