Gemini 7125 tnc cannot release immo - Televison & Video
I cant start my car because it has immobilised
factory IMMO or Aftermarket?
how do you know that, dash cluster lamp IMMO glows.
how? or just wont start and you assume it?
It is an option, i checked. on the new car.
due to battery disconnected?
or you did so to reset IMMO?
you need to check fuses first.
then scan the PCM first
disconnect battery longer.? say 1/2hr
do so at the NEG lug. for safety
IMMOs are reset them selves each key on, but
pulling battery can help. but the IMMO will need to discharge
its internal capacitors fully, thus the 1/2 hr delay.
there are tricks to discharge faster but, that varies.
Feb 12, 2015 | 2001 Suzuki Grand Vitara
How do i turn off the tnc indicator on the ts2000
per the manual the main band is the default for the built in terminal node controller you may have to change it manually by pressing the vfo A or B.
Oct 24, 2014 | Kenwood TS-2000
Where is the tnc head office located, and where are your products manufactured?
If TNC has a web-site, maybe 'www.tnc.net', enter 'tnc.net' onto the web-page at 'www.who.is', and you'll get the address of the owner of the 'tnc.net' web-site.
Feb 18, 2014 | SanDisk Electronics - Others
I want to delete my password from my Gemini tablet
You could do a hard restart but it will wipe all your data.
Turn off tablet.
Hold VolUP and POWER buttons until the Gemini logo appears.
A green robot with a red warning sign will appear.
Press and hold POWER, press VolUP once, release the POWER button. A menu will show on-screen.
With the VolUP and VolDOWN keys you can move up and down. Press POWER to select.
Select Factory Reset.
Then select YES.
Press POWER to restart.
Feb 12, 2014 | Computers & Internet
Why don't the AppsLib work
Watch this Video: http://www.youtube.com/watch?v=6BrWSC2uiAg
The model he's using is the 7022, but the same procedure works for the 7125. Download the APK files that are linked in the video description and then connect you 7125 to your computer to copy them over. Once you have them copied, use the APK Installer that came pre-installed on your 7125 to load them. Make sure you load them in the order given on the video! I loaded them in the wrong order the first time and had to do a factory reset because the Back button (silver circle) no longer functioned.
Once you do all this you will be able to load the typical Android Marketplace and ditch the AppLib that doesn't seem to work.
Dec 27, 2011 | Tablets & eReaders
I need drivers fo pci for ms 7125 please send
Hello the download site is here:
http://www.msi.com/service/search/?kw=ms%20%207125&type=product
http://www.msi.com/product/mb/K8N-Neo4-F--PCB-1-0-.html#/?div=Driver&os=All
If the driver not fit select another MB.
First select your windows system.
The drivers you may download needs to be unziped
before you install.
Good luck
Jan 02, 2011 | MSI : 7125-040 (K8N NEO4-F) Socket...
Maytag gemini MGR6772BDQ Spark Harness How do I remove the top to get access? Can I do it without removing the burners and instead release the gas lines to the vavle bar and oven?
what.......
just remove the four black screws that hold the top down they are above the door when closed
the top will flip up
the spark mod is right there
Sep 26, 2009 | Maytag MER6772 Gemini Electric Kitchen...
MS-7125 ver1 K8N Neo4 motherboard problem
Do you have the K8N-Neo4 motherboard? MS-7125 is the intern p/n for the K8N
If so, try this address, these are the most recent drivers for the motherboard.
http://global.msi.com.tw/index.php?func=searchresult&keywords=MS-7125&table=download
Hope this is the answer you're looking for
Nov 19, 2008 | MSI K8N Neo4-F Motherboard
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
