Question about RCA RC142 AM/FM USB Charging Clock Radio
Battery back-up doesn,t work - RCA RC142 AM/FM USB Charging Clock Radio
  • Lonnie Williams Apr 21, 2014
    I tried a new battery but it still didn't work, I didn't get a instruction manual with the clock so I have to get my son to figure out how to set the clock, he's one of those that can do that stuff out. I don't suppose you guys can send me one in the mail { 2620 Ruidosa Ave. Apt. 162 Dallas Texas 75228 }
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Try here http://www.voxxintlcorp.com/docs/common/RC142/RC142_OM.pdf http://www.voxxintlcorp.com/docs/common/RC142/RC142_OM.pdf
Posted on May 09, 2014
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
It doesn't power on
Your camera can be defected. If you buy new batteries, and it still doesn't work, than you'll probably want to send it back to the manufacturer. First, call them and tell them your problem, and if that doesn't work, than you might want to carefully examine your camera, to check if everything is in the correct place, and their all working correctly.
Jun 11, 2012 | Canon PowerShot A560 Digital Camera
The laptop doesn't start but the charger works.
Take out the battery and connect the charger.
Then try to turn on the computer.
If it works, there is no problem with your computer.
After that insert the battery, plug in your adapter and try turning on once more.
If it doesn't work, you need to get a new battery.
Oct 01, 2011 | Toshiba Satellite Pro L300 Notebook
Replaced battery & pcv valve now speedomter
Under the battery tray is a common ground point. It'll have several black wires going to a connector that is bolted to the frame. Remove this bolt, clean the area up, and bolt it back in place. If the speedometer doesn't work after this, then you probably need a vehicle speed sensor VSS.
Sep 13, 2011 | 1998 Ford Escort
I just switched my phone i called metro pcs they said if it dosnt work to manually restart it but i dont know how
Turn the phone off. Remove the battery. Wait 30 seconds or more ... Put the battery back in. Turn it back on. If it works - GREAT. If it doesn't work, call Metro PSC back and tell them you did what they said to do and it still doesn't work.
If the phone is already off or will not turn off ... remove the battery ... wait 30 seconds or more ... put the battery back in ... turn on the phone. See above for further details.
Thank you jor you rinterest in FixYa.com
Sep 05, 2011 | Computers & Internet
My TI-84 calculator isn't working. When I press the "ON" button, sometimes it would respond, but most of the time it doesn't. The screen just remains blank. I've changed my batteries...
try taking out the triple A batteries and leaving the calculator to sit with them out for a minute or so, replace them and check if it's fixed. If that doesn't work you can do the same, but take out the small button back up battery as well. If you're still not having luck you should call ti cares (800-842-2737) they're usually helpful.
Aug 09, 2011 | Texas Instruments TI-84 Plus Calculator
My motoriola defy phone wont charge it has been at 0% charge all morning.
Hello and welcome to FixYa;
Take out battery, clean off the battery and gently clean off the terminals. Put battery back in and try to charge again with your charger. If this doesn't help;
Try another charger to the phone such as a car charger if you have one. If the battery still will not charge;
you may need to get another battery. I suggest you go into your local service provider first, have them use one of their spare batteries that fit into your phone model and see if the battery will start charging.
If it doesn't, you need to have your phone itself looked at instead of the battery.
Try these steps before you spend money on replacing parts needlessly.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
May 30, 2011 | Cell Phones
Sharp pda yo-370 will not turn on
okay this is what you gotta do unscrew the back of your PDA and you will see your two batteries and some stickers, in between the batteries there is a rectangle. take your screw driver and push the little bars inside the rectangle back. this will unlock your screen. if it still doesn't work hold the on button and press reset this will delete everything but also turn it on. if it still doesn't work throw PDA at wall, save up money, and get an IPad.
Apr 03, 2010 | Sharp YO-270P
RCA RC142 AM/FM USB Charging Clock Radio Logo
50 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
