Question about Logitech X-540 5.1 CH Home Theater System
Fix wired remote for Logitech X-540
The wired remote is broken and it is wired into the sub-woofer.
  • 5 Answers
SOURCE: Sub Woofer Not Working
Make sure it is plugged in and the volume is up. Also make sure you don't have your sound muted. Do any sounds come out of your computer? Go to the control panel and click sounds and do a test.
Posted on Dec 25, 2007
  • 56 Answers
SOURCE: connecting Logitech X-540
you have to buy an External 5.1 sound card .. i suggest you buy the creative external sound blaster live .. high quality with lower cost
you can find it here :
http://asia.creative.com/products/product.asp?category=244&subcategory=718&product=10702&nav=1
Posted on Dec 28, 2007
SOURCE: wired remote cable extension
Most monitor cables have only 14 of the pins connected, but if you get a fully wired svga extention cable it does work fine.
Steve
Posted on May 13, 2008
  • 3 Answers
SOURCE: How to disassemble Logitech Z-340 sub-woofer
The speaker bezel can be removed in only two ways:
1) Somehow remove the grille in order to get a the screws which hold the bezel onto the cabinet. I tried to do this and couldn't get it to budge. Once I got the thing open I observed that Logitech used a LOT of glue to hold this thing together.
2) Drill holes THROUGH the grill above each of the 8 screws large enough so you can loosen the screws.
Once you get it open, you'll be shocked to discover what you thought was the subwoofer cone is actually A ROUND PIECE OF CARDBOARD fastened to the foam. The 4" driver is behind this fastened to a board halfway back pointing into the chamber containing the electronics.
You can get to the power transformer, but good luck removing it. The screws are nearly impossible to unfasten; more glue but more importantly incredibly awful access to the nut and screw (yes, a screw, not a bolt).
I wouldn't pay 5 bucks for this system. Luckily, I didn't.
Posted on Feb 01, 2009
SOURCE: I need a replacement for my logitech z-2300 speaker wired remote control. How and where can I get one?
As strange as it sounds, I am also looking to purchase a broken remote for the z-2300. Please email if you have one, jayarcher13@yahoo.com, thank you!!
J
Posted on Jun 05, 2010
The subwoofer has a rattle noise, how do i fix it?
Hi Larry. From your description, it sounds like the voice coil of the woofer is damaged due to possibly overdriving the speaker, mainly playing the system very loud for an extended period. I would replace the woofer element. The woofer should be held in place with 4 screws. When removed, there will be 2 wires on spade connecters. Disconnect these and replace with the new woofer. Hope this helps you out.
Jan 30, 2011 | Logitech Z-540 Speaker
I have the X-540 Speaker system set to 5.1 surround sound. By testing it on Windows Vista Home Premium x64 I have concluded the center speaker does not work when all others do including the sub...
Have you tried adjusting the matrix settings on the speakers. Try pressing the matrix button on the control box and see if that resolves the issue for you.
Robert from Blitware
Jun 17, 2010 | Logitech X-540 Computer Speakers
Could you tell me what plug in ports i need for X540 or 530- on my desktop
You need three ports in order to use all the speakers 5.1 sound. They are all headphone jacks but they are front speakers, rear speakers, and sub/center
http://www.newegg.com/Product/ImageGallery.aspx?CurImage=36-121-006-S04&SCList=36-121-006-S01%2c36-121-006-S02%2c36-121-006-S03%2c36-121-006-S04%2c36-121-006-S05%2c36-121-006-S06%2c36-121-006-S07%2c36-121-006-S08%2c36-121-006-S09%2c36-121-006-S10%2c36-121-006-S11&S7ImageFlag=2&Item=N82E16836121006&Depa=0&WaterMark=1&Description=Logitech%20X-540%2070%20watts%205.1%20Speakers
8th pic
Apr 06, 2010 | Logitech X-530 Computer Speakers
To the two people with problems. This sounds a bit odd, but do you still have the broken remotes? I'm looking for a broken one. I'd pay shipping and throw a few bucks your way if you could send it to me.
AIM: gonzoleben
Email: andywitzz [at] gmail [dot] com
Thanks!
-Andrew
Apr 14, 2009 | Logitech Z-2300 Computer Speakers
Sub-woofer malfunction
if the amp is going bad repair or replace, the sub you would probably have to replace, this would be the best fix. but check the amp also.good-luck!
Jul 12, 2008 | Logitech Z-5500 Computer Speakers
Panasonic Sub Woofer
I Have the sub woofer SB wa 340, but I need the remote control if posible bussines send me the information 7862873227
Jun 23, 2008 | Panasonic SC-HT690 System
Fuzzy & crackly
its the problem with the ac adapter which you are using might be your adapter is not working properly the adapter consists of step down transformer which is not very much durable some times so change the adapter and see if u dont have any adapter to connect just the direct wire to the supply then the adapter will be inside of woofer or the speakers change that adapter check this it works
Mar 30, 2008 | Logitech X-540 Computer Speakers
Wired remote cable extension
Steve
Mar 23, 2008 | Logitech Z-2300 Computer Speakers
No sound
To my knowledge, a Logitech X-540 does not need a driver to operate. However, it is the sound card in the PC that would need drivers. Further, the sound card should be capable of 5.1 surround sound system and should have three (3) sound output which includes. All of these would have individual jacks to match the different plugs of the X-540 (green, black and orange plugs). The X-540 in turn would output the 3 inputs to front pair, rear pair, center and sub woofer. The green goes to the front L/R, the black to the rear L/R and the orange to the center/sub.
Perhaps you can post back with the brand/model of your PC , and your soundcard or motherboard. Knowing your OS would also be helpful.
Hope this be of help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Feb 03, 2008 | Logitech X-540 Computer Speakers
Connecting Logitech X-540
Dec 28, 2007 | Logitech X-540 Computer Speakers
Logitech X-540 5.1 CH Home Theater System Logo
75 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
Andrew Taylor
Andrew Taylor
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
