Question about Garden
Starter pins Husqvarna 160cc starter pins came off how to replace with new pins
    Champion:
  • 225 Answers
Which engine make and model??
Posted on May 31, 2014
2 Suggested Answers
SOURCE: lawn mower husqvarna problem
I have an XT721F self-propelled, auto choke Husqvarna mower. The first time I used it this season it ran for a short time and then just quit on me. I have since emptied out all of the gas and have replaced it with high octane 91, and have also added Seafoam to clean out any other issues. I mowed two weeks ago with no problems and went to mow again today and only made it through 2/3 of my back yard and the mower stalled out on me again. What's going on?
Posted on Jun 28, 2011
Have fire coming out exhaust& backfire. How do I remove the flywheel? how do you time it?
More or less, check your rings... sounds to me as if your rings are going...
Fire will also come from exhaust if too much starter fluid is sprayed..
Use carburetor cleaner instead
Nov 03, 2015 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
How to change cord victa corvette 160cc 2stroke electronic ignition
On assuming its fitted with a victa 2 stroke engine in which case unscrew the 3 cross head screws on the top plastic cover and remove it. You should then see the top of the engine and the recoil starter. Undo and remove the 3 bolts holding the starter to the engine. Remove the starter housing gently as there will be a large o ring under the stater. Once the starter is off you can undo the centre bolt and remove the recoil pulley and spring. When refitting starter smear a little oil on the large o ring to stop it from being damaged
Oct 11, 2014 | Garden
Starter pins
the pins are spring loaded if they fell out then the pully is bad when you get the pully starter you get rope and new pins pay attention how you take it out you have to put it back the same way you took it out
Apr 20, 2014 | Garden
Starter pins came off
remove your starter and with your model and serial number contact your local dealer for parts
Starter cable housing assembly
you need the model type and code off the engine only in order to find that part. that is also a murrey
Oct 11, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
We have a husqvarna 2148 replace starter.
Im not sure which engine you have but most starter bolts are at the top end of the starter and bolt right to the side of the block. You have to remove the engine shroud on top first on some engines.If you have the briggs engine that is a twin cylinder and the cylinders are opposed to each other the two bolts to remove the starter are under the flywheel,if you remove the side cover on the side of the engine the starter is on you can see the one bolt head,the other one is in farther under the flywheel and can be removed with an open end wrench,it will take some patience but it can be done.
Aug 02, 2009 | Husqvarna Garden
Found a part loose in my husqvarna chain saw
The "Illustrated parts lists" for your saw are here:
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=350&types=I
Try to identify the loose pin on the drawings. If unable to identify where it came I suggest your visit your local Husky dealer. Please advise me where it belonged once it is repaired. TIA
Lou
Apr 18, 2009 | Husqvarna Garden
Husqvarna LT2042
the soneloid switch sends power to starter . check power on red wire on starter when key on full .if no power must be soneloid switch problem even though it clicks
Oct 18, 2008 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
