Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Where do you check the fluid levels for the hydrostatic drive on a pouland riding mower
  • 127 Answers
These are sealed units from the factory
Posted on Jun 26, 2009
Forward is slow
need to change hydrostatic fliud and filterthat will take care of it
Oct 02, 2014 | Husqvarna "YTH26V54 54"" Briggs And...
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=cub%20cadet%20hydrostatic%20fluid%20change
I hope that this can help. Tom
Aug 22, 2014 | Cub Cadet Garden
Craftsman riding lawnmower, model #917 259012 hydrostat stopped working
Check belts. Check transmission fluid level if possible. Check linkage between shifter and transmission. Check belt tensioners under unit above deck.
Jun 15, 2014 | Peg Perego My First Craftsman Tractor...
Running Eatons 700-011 hydrostatic transmission in Walker Ride-on Mower. Lose drive pressure and steering on one side when unit has been operating for 30 mins or so. Oil levels ok.
Hydraulic pressure regulator for that side could be going bad. Fluid pressure is being bypass from that circuit causing hydraulic pressure loss in drive and steering.
Sep 25, 2013 | Garden
Husqvarna 24hp VTwin Hydrostatic 48' cut riding lawn mower will not move either direction.
I would check the drive belt going to rear end if not that I would check fluid level in transmission.
Aug 04, 2013 | Husqvarna 24HP VTwin Hydrostatic 54" Cut...
My Husqvarna riding mower is just a few years old. It now has problems driving uphill. What would cause the mower to operate normally on flat surfaces, but make it struggle to go gradually up a slig
A hydrostatic transaxle could be low on fluid, or have leaky pump or motor. Check the fluid level. If it is not hydro, check belt from the engine to the transaxle for tightness or slippage.
Dec 19, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Husqvarna Riding mower wont reverse gth2350 riding mower
I think theres 2 flow paths forward and reverse try checking the fluid level you may have to lower the rear end out of the machine or most all ridders ive seen allow you to take the backing plate off and then block the rear tires off the ground the fluid level should be about and inch from the top of the threads... if yours has a resivor off to the side with a breather fill it to the bottom of the threads... now that the fluid is full and up on blocks or jack stands start the engine and at an idle put it all the way forward to flush the bubles out this has to be done in small chunks 5 minutes forward and then laiter go 10 back let sit for 20 minutes in between and check the fluid level a couple of times to see if it whent down from this... best of luck hope this helped
Oct 03, 2012 | Husqvarna "GTH24V52LS 52"" Kawasaki 726cc...
Left wheel has lost 75% forward/backward power.
fluid level but if its that new it should have a warr
Apr 26, 2012 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Riding mower accelerates extremely slow and seems to stop on inclines
hydrostatic transmission failure, get your wallet out as they cost almost as much as a new mower
Apr 12, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
Aug 23, 2009 | Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
443 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
