Question about Gateway M465-E Notebook
Gateway M465-e - only get cursor on screen
When I power up - only the cursor is on the screen. Initially, I could get to the BIOS check screen when holding down "F10" button. I then ran recover disk and now only get a cursor on the screen. ANy ideas ? thanks
4 Suggested Answers
  • 60 Answers
SOURCE: No Audio Device on Gateway notebook M465-E- Need Sound Card?
Go to device manager, sound / video. and your sound card will be in there. Oh and right click on my computer and select properties, Hardware. if you didnt know.
Posted on Aug 04, 2009
Geekman
  • 32281 Answers
SOURCE: Have a gateway M465-E with power issues. Low
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Posted on Nov 26, 2009
Testimonial: "Thank you...tried all the above and determined to be a power adapter problem. "
mariolands
  • 2296 Answers
SOURCE: gateway m465-e touchpad is not
To fix your touchpad, read the information from this link.
Posted on Feb 11, 2011
Gateway M465-E Notebook hangs after booting
try removing and testing each memory separately
or try fix start up
Dec 16, 2013 | Gateway M465-E Notebook
Reset bios password
You must type your password to make changes to your bios settings or access your hard drive.
Dec 07, 2013 | Gateway M465-E Notebook
Gateway m465-e touchpad is not working; cursor is slowly moving
Feb 03, 2011 | Gateway M465-E Notebook
Bought a Gateway model M465-E on Ebay only to find out the bios is pass-worded so I cant load Win XP because of The infamous "no hard drive error because of the Sata Driver,and i cant get to the...
I'm sorry but I don't know how to reset your BIOS. But to get around your problem, you should be able to enter the boot menu to boot to the optical drive to install your OS.
In order to access the boot options on this notebook computer, press the F10 key while the Gateway screen is displayed during the startup process. This opens a Boot menu with the option to start the computer to any of the available drives. Use the UP ARROW and DOWN ARROW keys to select a menu option, and then press the ENTER key to start to the selected device.
To "boot" (start) to a CD, DVD, or a floppy disk, the media must be in the drive when starting the computer.
Dec 21, 2010 | Gateway M465-E Notebook
I have a gateway M465-E it power up but it has no battery indicator when charging or just on also i have no screen light up i have a spare known good back half of the same model when i connect it to the...
Hi Good day!!! Did you try checking the RAM of your laptop? try to remove it clean it same as the memory slot and then re insert it see if your display will light up.. if still not reply to me
Nov 09, 2010 | Gateway M465-E Notebook
Gateway M465-e laptop won't detect hard drive for XP install
The Gateway M465-e is only compatible the SATA hard disk drives. If the drive you are using is not a SATA drive, then it will not be able to work with your hard drive.
Dec 18, 2009 | Gateway Computers & Internet
Gateway M465-e Wont Start
Is your laptop receiving charge from the power supply. If not your power supply is bad. If yes.. The power mosfet of your laptop need to replace including a fuse.
Jul 26, 2009 | Gateway Computers & Internet
My cursor freezes and the screen goes blank. The
Try to update your machine's BIOS. Download it from the internet (search for the Gateway drivers - bios).
Jul 01, 2009 | Gateway M-6843 Notebook
Unable to reset BIOS
Grab a DVMM and test the coin cell it may be bad either that if your MOBO is eating coin cells like candy the board is bad. try to locate a jumper and a pair of needle nose pliers, and check the documentation there should be a jumper that turns on and off the BIOS battery some may advise to go JP1 to JP 2 or some other config to discharge a BIOS .
hope this helps. IT Grad Electronics School
Apr 16, 2009 | Computers & Internet
Gateway M465-e
replace the cmos battery
Mar 18, 2009 | Gateway M465-E Notebook
Gateway M465-E Notebook Logo
21 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
