Question about Refrigerators
The bottom chamber on my amanti de vino pfwc18 wine chiller is not cooling
The interior and back side fans all turn. The upper chamber works fine.
3 Suggested Answers
SOURCE: Haier Dual Zone Wine Chiller - One Fan wont run
I have the same problem. When I first discovered this, both fans had stopped working and the temp for both zones was over 80. So much for the wine that had been stored there. After leaving the unit unplugged for a few days, the fan for the lower section started working again but the upper fan is still overheating. Haier customer service says too bad, so sad (I discovered this problem in the 13th month of ownership). I'm sure it is not worthwhile to fix this so it is going out with the trash and I'll look for a different brand for the next wine cellar that I purchase. Any ideas?
Posted on Jul 13, 2010
  • 6 Answers
SOURCE: Avanti wine chiller model WC681BG not cooling after replacing cooling fan.
Unplug the fridge first.
Then try looking at the capacitor on the main board. If it is gooy or weird in any way - I'd try changing it.
John
Posted on Nov 25, 2012
Amanti de Vino pf-wc18. where can I get a fan?
http://us.wow.com/search?s_pt=aolsem&s_it=aolsem&s_chn=14&q=wine%20cooler%20parts
here is a list of options. Remember to check with BBB (independently not through some site link). before sending payment or using credit card with unknown websites.
Nov 29, 2015 | Furniture
There is hoarfrost in the top of the upper level and water at the bottom. What can we do? Is it better to turn off the appliance and let it de-ice? Did you hear about this problem before? Thank yo
I have had a similar problem with a commercial fridge that uses a fan to move the cold air around. The cooling elements get frozen and so no cold air is distributed by the fan.
It seems to happen when there is a weather change, maybe something to do with humidity?
Try turning it off for a day (put towels down) and then it should be fine.
Nov 15, 2014 | Koolatron 45 Bottle Dual Zone Wine Cellar...
Wine cooler does not stay cool
Do only if you are properly trained on live circuits.. Do at your own risk. Check the compressor's capacitor and the relay. Is the compressor getting juice?
Nov 23, 2013 | Avanti Refrigerators
The temperature will not adjust. none of the refrigerators are getting cold but fans are running
Sounds like you may have a compressor issue to me. if the fans are running that tells me the tstat is calling for cooling and the fans are running so they are fine. The comp is not producing cooling for some reason. Can you see the comp and tell if its running or not?
Aug 14, 2013 | Husky HUS-CN15 Wine Chiller
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in the...
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
Mar 02, 2012 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Top fan is not working
The HVTS18DABB wine chiller is truely a piece of **** when it comes to their fans. I have had top fans in the top chiller fail. Solution: Don't buy the replacement part as it will only fail again. Instead, go to your local computer parts store and purchase a high quality 120mm computer fan with a good motor and bearings. On the old fan, snip the wire harness as close as possible to the fan body. On the new fan, remove the connectors that come on the fan. Attach the red wires and the black wire and wrap each with electrical tape. Trim back the yellow wire and tape the end, isn't needed. Remount the fan and you are good to go. i plan on replacing the bottom fan soon with a quality PC fan as well.
Feb 19, 2011 | Haier HVTS18DABB Wine Cooler
Mar 01, 2009 | Refrigerators
Electrostatic chiller doesn't chill anymore
Hi!!! you seem to have a problem with your seal system .go to back and check your compressor and fan condensing motor make sure that they are on if yes..then you have a restriction or a freon leak..Good luckk...
Jan 04, 2009 | Kenmore 564.13355.100 Wine Cooler
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
