Question about Karcher 2500 PSI Pressure Washer
What engine oil do i use in a 25 hp briggs and stratton eng
    Habit-Forming:
  • 80 Answers
DEPENDS ON THE WEATHER IN YOUR AREA. I USE 10W30 OR YOU CAN USE A STRAIGHT 30 WEIGHT
Posted on Jun 14, 2014
I need a oil seal for a 15.5 briggs and stratton engine
try locating a bearing warehouse, they have listings for all size seals.
Apr 07, 2013 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 18 hp motor oil white
White oil in any motor indicates the oil has mixed with water . Drain the oil change the filter and find out how the water got in.
Oct 01, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Engine turns over but doesn't fire.
check it for spark then check if it is getting fuel cuz that might be the problem
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Starting problem after setting for ten days or more
Take the spark plugs out when this occurs and try to pull it through--does it expel fuel or oil? This should tell you whether you have a flooding fuel problem, or maybe the crankcase is overfull of oil causing it to leak into the combustion chamber through worn valve seals or piston rings. Hope this helps!
May 27, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
What kind of oil does the 22 hp briggs stratton take
from briggs site:
For optimum performance, you should change the oil in your small engine after the first five hours of use and then annually, or every 50 hours of use (whichever comes first).
  • Use Briggs & Stratton SAE 30W Oil above 40°F (4°C) for all of our engines.
  • Check oil level regularly.
  • Air-cooled engines burn about an ounce of oil per cylinder, per hour.
  • Fill to mark on dipstick. DO NOT OVERFILL.
Apr 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My 25 hp briggs is smoking and leaking oil. it
if the engine is ran quite a lot evey year the valves muct be adjusted. If not it will cause a head gasket leak which it sounds you have
Apr 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Stratton Briggs Stratton Intek V - Twin Engine 21 hp oil had white foam in it
The oil is contaminated with water. Change oil and filter, if it has one.
Jun 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Karcher 2500 PSI Pressure Washer Logo
55 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
