Question about Blaupunkt Car Audio & Video
Amp protect mode - Blaupunkt Car Audio & Video
  • Ganesh Gaikwad
    Ganesh Gaikwad Apr 25, 2014
    I am having blaupunkt GTA 2 special mak II amplifier and having problem of voltage . Its work in high voltage of 15-16 and not working in 12 volt power . The other i like to know what is the number of zinner D2 and ZD1 diveter.
    kindly help me to fix the problem.
MY soundstream LiL Wonder 4.620 is only going in protection mode
Disconnect all speakers Meter power, remote, ground at amp, if all is good move on, if not check main fuses
Turn amp on; If in protect mode then your amp is toast Turn amp on, if not in protect mode then start reconnecting speakers one by one until your amp goes into protect mode, then you'll know which speaker is bad.
Sep 19, 2011 | Car Audio & Video
Amp goes to protection mode. if the fuse is too small?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. . Double check all connections. Good luck.
A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Jul 15, 2010 | Autotek MM125.2 Car Amp
My nitro bmw-486 amp is in protect mode how can I
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty De .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-bmw-486-amp-in-protect-mode-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
Feb 24, 2010 | Nitro BMW-486 Car Audio Amplifier
I HAVE A SONY RECIEVER SRT-DE597 6.1 CHANNEL AND I ITS ON PROTECTED MODE CAN YOU HELP ME UN PROTECTED
Amp output is damaged and needs repaired. Protect mode cannot be deactivated. When amp is repaired and operating normally protect mode will not be displayed.
Aug 29, 2009 | Sony STR-DE597 Receiver
Light
The red light indicates that your amplifier is in protect mode. Amps go into this mode if there is something wrong with the setup of the system to prevent fatal damage to the amplifier circuitry. This is bad thing since the amplifier will not function until the problem is solve and it can remove itself from protection mode.
Amplifiers can go into protect mode for many reasons but one of the most common is incorrect mounting. Is your amp sitting on the metal of your vehicle? Is it bolted down and screwed into the metal of the vehicle or your seat? The amp should never be touching any sort of metal. Only the ground should touching the metal of your vehicle.
Speaking of grounds, many people often neglect proper grounding which can cause an amp to go into protect mode. Do you have a solid ground? Is the wire less than 3 feet long and directly connected to a non-painted metal part of your vehicle? Is the ground wire the same gauge as your power wire?
These are just a few reasons why an amp can go into protect mode. You can find more information here. Or simply google for why your amp is in protect mode.
Aug 06, 2009 | MTX Thunder 81000D Car Audio Amplifier
Protection mode
It's normal for some amps to go into protect for a few seconds when initially powered up. If it remains in protect mode, it may have shorted output transistors. To eliminate other possible causes, read through the following troubleshooting page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Dec 11, 2008 | Phoenix Gold Titanium 800.1 Car Audio...
Car audio amp in protection mode
If you power up the amp with the RCAs plugged in, does it go into protection mode.
If you power up the amp with the RCAs plugged in, does the woofer pop?
Oct 26, 2008 | Pyle PLAD413 Car Audio Amplifier
DUB 2502 Protection Mode help
The most common reason for an amp to go into or remain in protect mode is shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Aug 07, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
My light on my amp is blinking at a steadty pace.
The amp appears to be in protect mode. The most common reason for an amp to go into or remain in protect mode is shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Aug 06, 2008 | Alpine MRV-T420 Car Audio Amplifier
Why does my amp stay in protect mode?
The most common reason an amplifier goes into or remains in protect mode is shorted output transistors. To eliminate other possible reasons for it to go into protect, read the following page.
Troubleshooting - Amp in Protect Mode
Aug 03, 2008 | DHD NTX-2139 Car Audio Amplifier
Car Audio & Video Logo
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
