Question about Whirlpool 21.7 cu. ft. Side-by-Side Refrigerator ED22PQXF
The icemaker doesn't work and both freezer and fridge compartments are warm on top, cold at bottom The top part of freezer and fridge are warm
mikedurland
  • 481 Answers
SOURCE: freezer working fine, but no cold air to fridge
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control unit
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
docjohn174
  • 943 Answers
SOURCE: Leaking Whirlpool fridge
Thanks for the question When this happens if the evaporator is all frosted up you have a derost problem could be your timer or your defrost thermostat which is located on the coils of the evaporator you can check this with a volt meter these meters are cheap you dont need a very expensive for ahout 20 dollars or the defrost timer one of the two is your problem thanks for the question The appliancedoc
Posted on Sep 11, 2008
  • 531 Answers
SOURCE: Top shelf of freezer is warm. Icemaker not working.
check your defrost
Posted on Apr 01, 2009
tomsat69
  • 214 Answers
SOURCE: lights on but fridge not working on Fisher and Paykel N500B
There could be a few reason 1 you may have a faulty temp control switch try taping it to see if it kicks on.If that does not work remove the compressor start switch shake it to hear any noise like pieces burnt in it.If not try advancing your defrost timer to see it kicks on also.If those do not work you may have an elecrical problem.
Posted on May 10, 2009
heatman101
  • 43501 Answers
SOURCE: Bottom Freezer is cold top Refrigerator not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 04, 2010
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
My sub zero refridgerator (freezer on bottom fridge on top) is cold on the bottom of fridge and warm on the top of the fridge. Any idea what is causing this. Items are also damp in fridge. We just vacumed...
the evaporator coil inside the freezer compartment is iced over and can't transfer cold air in thes condition,remove panel inside freezer on back side of freezer compartment and thaw it out with a hair dryer,then check the defrost heating element for continuity,if its open replace it,if its good, ,check the defrost control that powers the defrost heater
Jul 15, 2010 | Sub-Zero 611 / O Bottom Freezer...
Fridge warm at top cold at bottom
If the fan is no coming on inside the freezer this will need to be fixed soon. Both fans upper and lower must run while compressor runs. Inside the fresh food compartment close the damper on bottom left side next to the paned drawer. If this does not help send more cold air to the top let me know as there could be something else causing the dampers not to open and close properly.
Thanks, Sea Breeze
May 28, 2009 | GE Refrigerators
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
GE g2220iephww Refrigerator too warm at top, too cold at bottom.
If you are manually defrosting by turning the refrigerator off or unplugging to defrost, then you've got one of the following -
1) Defrost heater has failed
2) Defrost sensor has failed
3) Defrost timer/refrigerator control has failed.
As ice builds on the evaporator, if not defrosted properly, the accumulated ice restricts airflow through the evaporator, which reduces air flow and air velocities through the box. Lower velocity allows the cold air to fall to the bottom of the box, warmer air to the top of the box.
Dec 26, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Fridge too warm
first, verify that the fan is running in the freezer compartment. second check that there is no airflow blockage between freezer compartment and refrigerator compartment. if that does'nt solve the issue verify the defrost system is working.
Mar 28, 2008 | Refrigerators
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Mar 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
15 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
