Question about Boss Rc 50
Beggining of loop missing on FIRST playback only, on Boss RC-50.
My problem arose during a simple test of my new rc-50. While recording one basic loop on a blank phrase and patch, it is missing the first split second on the first playback. The strange thing is on the second playback and so on, it does not miss the first split second. It is enough to make it sound like I played out of time the first time around, like I hit the pedal too soon. But, evidently I didn't as hey presto, the missed bit is back the second and subsequent times the loop is repeated. Also, when I try the same test on my trusty old rc-20 there is no problem.
I am an experienced looper, and have eventually managed to contact boss uk customer support. They suggest installing a software update so that I can change the "sound priority mode" to "priority given to sound". Rather than "priority given to rhythme".
How you do this, on a machine with updated software, so I am told, is to hold down either phrase 1 or 2 BUTTON, while turning the unit on. The change should then show in the lcd display. Can anyone with updated software verify this? Or are they having me on?
BTW, I am using no quantize or so on to mess the loops up. As I have been doing it for years succesfully by stamping in time on my old pedal. Nothing in the manual seems to solve this.
  • Dan Hickin Oct 07, 2015
    I forgot all about this, it must be very old! However I have something to add. I have continued to use the RC 50 as it's ability to pre-arm loops is a very useful feature for fast loop building, rather then what you hear from many when it takes them an age just to get a basic verse section down etc. If anyone is interested, I can elaborate - it involves using external switches too. As for the split second of silence when laying down the first loop - one way around this is to pre-record silence on the loop at the desired tempo and overdub on top of it. Is used with the guide sent via the sub out only to headphones, you could let one measure play through then hit overdub on the 1 beat and start recording your first loop. Not ideal I know. I just put up with the silence issue but try to mask it with my playing these days, either trying to play a little bit over the silence (playing the very start of the loop again on first repeat) or, on some pieces, a dramatic slide down the guitar neck can distract from the silence. For some of the techniques above, take a look at my youtube channel. It is loopcyclemusic. I am on FB under that name too. My pieces show how you can build multi loop pieces of music fast with different sections in a piece and lots of variation.
Ok, solved this problem by visiting roland U.S. site as the help offered in this country is useless. The instructions given by email would not have worked even after the update was installed. Luckily, there are instructions that come with the download. If you have same problem as me go to http://www.rolandus.com/products/productdetails.php?ProductId=772&tab=downloads&skip=true
and update the opperating system on the RC-50 to RC-50 System Update Version 1.01.
Then hold loop sync and phrase 2 button (think it was phrase 2) to change it to sound priority mode. Then it will play back correctly what you recorded on the first loop, rather than missing the first beat.
Am v.happy I have found this, as after much searching I can't find any other loopers out there that offer 3 seperate loop tracks and the ability to switch between them effectively. Plus, it's a very convenient size, better than a load of rackmounted stuff to haul around.
However.....
Another problem..
When hitting the reverse switch ( I assigned both external footswitch and the onboard Tempo pedal to reverse) the change is not instanteaneous. There is a second or so delay before it plays in reverse. Not a problem for most, I suppose, but I have a piece that switches rythmicaly between playing forward and reverse which means hitting a pedal in time and reverse/forwards changing immediately. I think they could do with another software update to solve this. Now I have to keep room in my enormous pedal board for the old rc-20, as that does the reverse as it should - when you hit the flippin switch!
Posted on Jun 20, 2009
  • essene Jul 13, 2011
    i have same problem with danhickin.
    i read ur solution, i updated 1.01 and press loop sync and phrase 2 button.
    but nothing happend.!!
    1. press loop sync button phrase2 button same time?
    2. u mean `small` phrase 2 button? right? (not the big one for foot..)
    3. if it works any sign on lcd will appear?
    give me more detailed information plz.
    thx.
  • alniko May 25, 2013
    Did you solve this problem? Mine doesn't change either, and I really don't know why...
    New Friend:
Mine don't change eather, I've done all the instructions, but nothing happens. Please, somebody, help
Posted on Nov 19, 2014
Tip
RC looper and DR880 syncing.
RC-50 & DR-880 Setup
Rather than using the RC-50 to change patches on the DR-880, I have connected an FS-6 footswitch to both the RC-50 & DR-880. This gives me control of both units, I can select up & down through the patches easily.
Use a dual TRS connector and 2 stereo "y" cables connected to ports 1,2 & 3.4 on both units.
Once connected, you will need to assign the control function for each control port. I assigned Patch Decrease to CLT 1,2 & Patch Increase to CLT 3,4 on both units.
I then connected a MIDI cable from the RC--u control of start/stop & tempo via the RC-50 footswitches.
on Feb 25, 2015 | Roland Boss RC50 Loop station (with )
Rc-50 recording silent wav files
Perhaps your computer's sound card is unable to play back at the bit rate and kHz you are recording at on your (mobile?) recorder. I'm not familiar with the RC-50 but if you are recording at 24 bit for example and your computer's sound card is only able to play back at 16 bit it may not reprosuce any sound. Usually you will get an error saying so. Have you tried different playback software?
Mar 22, 2014 | Boss Rc 50
My RC-50 suddenly won't power on.
Has the unit ever had another ac adapter plugged into it?
Mar 04, 2013 | Boss Rc 50
Can i add more memory to the rc50 loop pedal
You can make a backup on your pc and load back Default settings or restore to default settings. Normally you should have I quote ' with up to 49 minutes of mono recording time (or 24 minutes in stereo), the RC-50 can function as a song recorder as well as a looper'
I have the RC300 which has 3 hrs recording time. But when i reach the limit. I make a backup and load back in a initial default setup which I have downloaded somewhere. But you can also restore to default from the unit itself. Hope this helps
Apr 14, 2017 | Boss Rc 50
I was trying to transfer data from the RC-50 to my computer and pulled out the USB cable by mistake from the computer and now the RC-50 says Data Damaged. I think I may have put the file in the trash in...
Usually in any type of situation when data is being transferred and the connection is prematurely lost there is data lost and or file corruption.
My suggestion:
Connect the Boss Rc 50 to your computer and backup its entire contents to your computer if possible.
Next perform a Hard Reset: While simultaneously holding down the "PLAY MODE" and "LOOP SYNC" buttons, turn the power on. Everything should be restored to factory settings.
If your backup was successful, then you can transfer desired files (one at time) to determine if the are usable. If a file causes errors or malfunction, then most likely it is corrupt.
Hope this helps
Apr 05, 2011 | Boss Rc 50
I cleared one folder called WAVE with my computer and now there´s a messege on screen "data damage". the folder contains the preseted sounds inside. i need help.
Here's a hunch:
When the RC-50 was hooked up, your computer had access to the internal memory. The WAVE directory is where the wave data is stored. The RC-50 must have noticed that the wave data for patches that were supposed to have data was in fact gone.
So, you can probably just do a factory reset:
With the power off, while holding both single/multi and loop-sync, power the RC-50 up until it greets you with SYSTEM/PATCH use the PARAMETER buttons to go back and forth. In your case, you can probably leave "SYSTEM" alone and just select PATCH. Once you've selected which section of the RC-50 you want to reset, hit the WRITE button.
Aug 13, 2010 | Boss Rc 50
How To Turn Drum Beat Off
From what I remember from my recent tinkering you press the guide select button. Then either use the patch/value know and parameter buttons, OR it may be the guide level knob to switch the volume down until it is off. I believe I then saved the patch to preserve the setting and keep that irritating guide at bay! It really should be more intuitive, ideally knod turned to zero = OFF. But no. Ah well, hope you get it sorted. I have a problem too, maybe you have same one? It may be the unit itself. Search - Beggining of loop missing on FIRST playback - if you get a chance. Let me know if yours does it too?
Mar 06, 2009 | Boss Rc 50
Guide on RC-50 won't turn off
First, you need to select one of the patches called "init patch", it won't have a drumbeat on it. Then, turn the guide on again, then all the way off. Even if the knob's in the off position when you go to the patch, it'll turn itself on again by default. There's a light there that says "beat quantize" that you want to be off, or it'll cut your loop to the length of whatever beat it's set to. If you want to change the default, turn the beat quantize off, then press "write" and write the new patch. Hope that helps.
Dec 01, 2008 | Boss Rc 50
Boss Rc 50 Logo
1,076 people viewed this question
Top Boss Music Experts
Michial Gueffroy
shaun taylor
Robert Graf
Are you a Boss Music Expert? Answer questions, earn points and help others
