Question about Camping, Backpacking & Hiking
When I wen to open my walking pole it came out beyond where it should
Trouble starting
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Apr 19, 2014 | Remington Electric Chain Saw
Coleman trecking pole
That is not a car or truck.
Apr 29, 2013 | Cars & Trucks
I'm looking for a Nordic walking pole, which one should I get?
The Leki Smart Traveller Alu Nordic Walking Pole is the best Nordic pole you can get today. It is quite expensive in comparison to other Nordic poles but it is totally worth it.
Sep 04, 2012 | Coleman Camping, Backpacking & Hiking
What is a Nordic walking pole?
Nordic walking poles are a modified version of trekking poles and them gradually becoming popular in the U.S.
What is an anti-shock pole?
The anti-shock poles offer internal springs that absorb the shock when you walk downhill. In most anti-shock poles you can turn off the anti-shock feature whenever you like. The anti-shock feature is recommended if you have weak or damaged ankles, knees or hips.
What types of hiking poles are there?
There are five main types of hiking poles, the standard poles, the anti-shock poles, the compact poles, the hiking staff, and the Nordic walking poles.
Will I spend less energy using a hiking pole?
No, hiking poles will not decrease your overall energy expenditure since you'll be using your arms more than you would when walking without poles although they help distribute your energy usage in a way that can help your hiking endurance.
What are the parts of a hiking pole?
I came across an image that depicts each segment of a hiking poll for you:
You may also want to check out this video for set-up instructions:
http://www.keenfit.com/about-poles/walking-pole-parts-video.asp
What are some other names for a hiking pole?
The can be called walkingstick/pole/cane, trekking stick/pole/cane or hiking stick/pole/cane.
Jul 10, 2012 | Camping, Backpacking & Hiking
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    Camping, Backpacking & Hiking Logo
    490 people viewed this question
    Top Camping, Backpacking & Hiking Experts
    Tom Chichester
    ray gallant
    Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
