Question about Speedi-Products 6" Galvanized Umbrella Roof Vent Cap Ex-Rcgu 06
I am looking for a umbrella cap to cover my 15 inch attic exhaust fan
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Many people just use large black trash bags secured with duct tape or bungi cords. Black bags won't deteriorate as fast as the white ones with the UV rays of the sun and should last one full winter.
If you're concerned about the neighbors complaining about the lack of asthetics....I can't help you.
I never cover attic vents nor recommend them to be covered, because a properly vented attic all year long ensures moisture removal from the attic area and from the insulation. Also if you have shingled roofing, each nail point extending through the sheeting will condense moisture and drip into the insulation in a non vented attic space. This happens many times each winter when the air temp and the moisture content collide on the dew point scale. It does NOT happen daily.
The nails conduct the warmth to the outside, cool down and attract the moisture from the non vented air on their exposed length and slide down to the tip dripping into the insulation. Moisture detracts from the insulations ability to do its job, and that's to insulate the living space from abnormally cold or hot temperatures.
Posted on Dec 01, 2014
36 cc craftsman 16 inch saw replaced fuel lines fires up but wont stay running it excellerates for about 15 seconds
Check to see if exhaust is stopped up Clean or replace it then it should run good,If not replace fuel cap.Take fuel cap off and start.if runs and accelerates then replace fuel cap. If not the exhaust is stopped up with carbon clean it or replace.
Nov 01, 2014 | Garden
Replacement of timing belt on 2001 daiwoo legansa
This should give you a clue as to how to replace the timing belt on the camshaft pulleys.prev.gif next.gif Camshaft and Valve Lifters REMOVAL & INSTALLATION 1.6L Engine
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Relieve the fuel system pressure.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Timing belt
    • Crankcase ventilation tube from the valve cover
    • Spark plug cover bolts and the cover
    • Camshaft Position (CMP) sensor connector
    • Spark plug wires from the plugs
    • Valve cover nuts, washers, cover and gasket
    NOTE: Be very careful not to nick or scratch the camshafts.
  4. Hold the flats of the intake camshaft in position using an open ended wrench and remove the camshaft gear bolt. Remove the gear.
  5. Hold the flats of the exhaust camshaft in position using an open ended wrench and remove the camshaft gear bolt. Remove the gear.
  6. Mark the camshaft cap locations so that they may be returned to their original positions.
  7. Remove the camshaft cap bolts in the sequence illustrated.
  8. Remove the caps and the camshafts. Fig. 1: Loosen the camshaft cap bolts in this sequence using several passes - 1.6L engine 9307zg85.gif
    To install:
  9. Lubricate the camshafts and caps with engine oil.
  10. Install the caps and the camshafts in their original positions.
  11. Tighten the camshaft cap bolts in the sequence illustrated to 12 ft. lbs. (16 Nm). Fig. 2: Tighten the camshaft cap bolts in the sequence illustrated using several passes - 1.6L engine 9307zg84.gif
  12. Measure the camshaft endplay on both camshafts. The endplay should be 0.003-0.009 in. (0.10-0.25mm).
  13. Install the intake camshaft gear. Hold the flats of the intake camshaft in position using an open ended wrench and tighten the camshaft gear bolt to 49 ft. lbs. (67 Nm).
  14. Install the exhaust camshaft gear. Hold the flats of the exhaust camshaft in position using an open ended wrench and tighten the camshaft gear bolt to 49 ft. lbs. (67 Nm).
  15. Apply a small amount of gasket sealer to the corners of the front camshaft caps and to the top of the rear valve cover-to-cylinder head seal.
  16. Install or connect the following:
    • Valve cover, washers and nuts. Tighten the nuts to 89 inch lbs. (10 Nm).
    • Spark plug wires to the plugs
    • Spark plug cover and bolts. Tighten the bolts to 27 inch lbs. (3 Nm).
    • CMP sensor connector
    • Crankcase ventilation tube to the valve cover
    • Timing belt
2.0L and 2.2L Engines
    • Timing belt
  7. Remove the camshaft cap bolts in several passes of one half turn each in the sequence illustrated.
  8. Remove the seal ring from the camshafts. NOTE: Make sure the camshafts detaches evenly from the bearing seats in the front guide bearing.
  9. Remove the caps and the camshafts. Fig. 3: Remove the camshaft cap bolts in several passes of one half turn each in the sequence illustrated - 2.0L and 2.2L engines 9307zg38.gif
    To install:
  10. Lubricate the camshafts and caps with engine oil.
  11. Install the caps and the camshafts in their original positions.
  12. Tighten the camshaft cap bolts in the sequence illustrated to 71 inch lbs. (8 Nm). Fig. 4: Tighten the camshaft cap bolts in the sequence illustrated using several passes - 2.0L and 2.2L engines 9307zg37.gif
  13. Measure the camshaft endplay on both camshafts. The endplay should be 0.0015-0.0056 in. (0.040-0.144mm).
  14. Install the intake camshaft gear. Hold the flats of the intake camshaft in position using an open ended wrench and tighten the camshaft gear bolt to 37 ft. lbs. (50 Nm), retighten the bolt an additional 60 degree turn and finally an additional 15 degree turn.
  15. Install the exhaust camshaft gear. Hold the flats of the exhaust camshaft in position using an open ended wrench and tighten the camshaft gear bolt to 37 ft. lbs. (50 Nm), retighten the bolt an additional 60 degree turn and finally an additional 15 degree turn.
    • Valve cover, washers and nuts. Tighten the nuts to 71 inch lbs. (8 Nm).
    • Timing belt
Feb 04, 2011 | 2001 Daewoo Leganza
The bathroom exhaust fan in our bungalow is leaking this past week every few days , we are not handy folks and so we are wondering what type of professional do we call in to deal with this leak and...
Sounds like the issue is simply condensation inside the exhaust pipe where it passes through the un-heated attic space. If you use the shower and the exhaust fan, lots of humid air is passing over the inside surface of a very cold duct, then running back down to your bathroom ceiling. You could get any non-specialist handyman to wrap insulation around that duct in the attic. But you can mitigate the problem by running the fan for a few minutes before you start the shower (thereby pre-heating the duct before you give it a blast of moist air) , and leaving it run for 20 minutes afterwards (thereby drying out the duct after use). Regarding the discolored ceiling, the handyman can apply some stain-covering white primer too.
Jan 14, 2011 | Fantech Fans Exhaust Fan In-Line
Combo lite/vent fan/nite light affected by heat?
There's probably a thermal switch in the fixture which turns the fan on when the lights are on for a period of time and heat accumulates in the fixture. It sound like the heat from the attic is setting off the thermal switch. When the attic heat drops, the fixture works correctly.
This is a catch 22 situation, because if the upper housing in the attic is insulated from the attic heat, the insulation will prevent heat dissipation from the heat generated by the fixture's light bulbs. So, for safety reasons, the upper housing should not be insulated.
I'll need to work on this to come up with a fix.
Jul 19, 2009 | Broan-NuTone N-8663RP Combination Light...
Replace shower fan motor in a Broan model 678
I need to get the cover off of a BROAN fan and light kit. The two solutions listed did not provide me with sufficient information. Thanks!
Jun 19, 2009 | Broan-NuTone N-8663RP Combination Light...
Dayton Attic fan running backwards
First see if the switch has a reverse position. Sometimes you turn the fan assembly in the frame, sometimes you turn the whole frame around. Take the cover off the wiring compartment to see if there are instructions there. Also check on the name plate on the motor, there may be instructions there. Attic fans are usually engineered to blow out.
Aug 02, 2008 | Dayton (2C373) Fan
Broken mount attic exhaust fan
buy new blade or keep soaking shaft.collar with rust penetrant,
Jul 25, 2008 | Ventamatic Gable Mount Power Attic...
Attic fans
I just fixed a Broan-353 with a similar problem - the fan was short-cycling, turning on and off within a minute or less.
These fans have a thermostat which is designed to turn off 10 degrees below where it's set to turn on. Apparently, one failure mode is this temperature delta stops working I've had this happen twice, each time after about 3 years.
Replacement thermostats are available from Broan for about $30 http://parts.broan-nutone.com/broan/Shop It's a 10 minute repair if you have easy access to the fan.
May 23, 2008 | Broan-NuTone ATTIC FAN THERMOSTAT CONTROL
Speedi-Products 6" Galvanized Umbrella Roof Vent Cap Ex-Rcgu 06 Logo
790 people viewed this question
Top Speedi-Products Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Speedi-Products Hardware and Accessory Expert? Answer questions, earn points and help others
