Question about Garden
Murray mower shut down does not work
When the run bar is released the mower continues to run
  • Garden Master
  • 2,478 Answers
Cable broke or come loose at carb.
Posted on Apr 20, 2014
5 Suggested Answers
  • 14 Answers
SOURCE: murray riding mower dies when i release the clutch
could be the seat switch i had tht problem before i bypassed the switch and waalaaaa
Posted on Apr 27, 2009
SOURCE: Riding mower having problems starting then runs roughly
I have a Scotts _ John Deere law mower tractor model S2048-S2554 Serial number 020-001, the engine runs but sounds like it is going to die or it needs air --- it runs unnevenly
Posted on Jul 20, 2009
SOURCE: I have a 15.5 HP Sears Craftsman 42
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Posted on May 17, 2010
Testimonial: "VERY THOROUGH - THANKS"
aquaman987
  • 927 Answers
SOURCE: when i release the brake
Check your seat switch. If there is someone in the seat, the brake can be released and/or the blades can be engaged. If you can do neither, the seat switch is not opening.
Let us know,
Your Fixya Tech, Gary
Posted on Aug 15, 2011
Mower cranks and runs fine but when I release brake pedal, it dies. I have check all safety switches and they all have continuity when they are suppose to
Sounds like your seat switch isn't working. Operator presence (seat switch activated) is required when the brake is released & pro is engaged or your engine will shut down.
Feb 14, 2016 | Garden
My mower starts fine but will not shut off when I release the safety bar. What should I check or change. It is a year and a half old machine. It did work for few mows before the problem started.
You need to adjust the safety bar cable. When you hold it down it starts but when you release in is not coming back all the way, so it runs. Make sure the lever is clear of dirt and give it a shot of WD40 and move the bar handle up and down to work it in. Most likely something is in there keeping it from going all the way back. If that not it let the cable wire out (longer) about an 1/8 inch.
Hope this helps. Mike
Jul 06, 2015 | Garden
Why does engine stop when clutch released or blades engaged?
Make sure have a good battery when you start the blades on any lawnmower it need lots of power to get it going
Jul 17, 2014 | Murray Garden
Murray lawn mower
Sounds like a fuel problem. Clean the carb good using fine wire and be sure to clean all of the small passages. Fresh gas and a new new fuel line can do wonders.
Jul 11, 2014 | Garden
42 murray mower deck TROUBLESHOOTINGmanual
It sound like pto or safety switch may be shorted. Hope this helps.
Jul 31, 2013 | Garden
Murray 42" 20hp stops running
there are safety switches that can shut it off i would disconnect the coil wire from the harness its a small wire if it doen't shut off with that wire off its on the mower side causing the problem the other thing to check is to remove the upper engine cover and see if a mouse chewed threw the wires under there
Aug 05, 2012 | Garden
Murray 21hp/46
Sounds like a micro switch issue shutting the engine down, start by checking the seat switch, make sure the connecter is pushed well in.
Mar 12, 2012 | Murray Garden
Murray 22in throttle-free push mower
Throttle cable probably needs adjustment. If not adjusted properly it wont go to the shut off position. There is a clamp that should be on side of the engine, loosen the screw on the clamp, then move the cable-try pushing it forward or backward, but not more than 1/4 inch at a time, tighten after each adjustment. Engine is shut off while adjusting, once tightened crank the mower and see if that improves it. You will just have to try each direction until you find which way it needs to go.
Sep 10, 2009 | Oregon Scientific Gator Mulcher 3-N-1...
Murray rider quit abruptly.
were you mowing at the time? if you didn't disengage the blades, the engine will not start, everything will seem "dead". if that's not it, check for a blown fuse
Aug 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Apr 21, 2009 | Garden
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
