Question about Speedi-Products 6" Galvanized Umbrella Roof Vent Cap Ex-Rcgu 06
I am looking for an umbrella cap to cover my 15 in diameter roof roof exhaust fan
My Lakewood stand fan broke right in two. The
Is it still under warranty, or does your store or credit card carry/extend the warranty?
See if the manufacturer has parts.
What diameter, inside and outside? Might a patio umbrella stand work? I often see those at the curb on trash day - if the metal scrappers don't get them first!
I'm still not sure how it would have broken in two. Most aluminum bends and might get kinked, but not break on its own.
Sep 27, 2014 | Dryers
How do I remove the cover to replace the light bulbs on a Round Nautilus brand bathroom exhaust fan from the 1980's.
Most exhaust fan covers use a spring steel wire in a V shaped configuration. The bottom of the V is attached to the cover. There is a slot in the fan housing and by pinching the tops of the V togetherand insert them in the slots the spring pressure pulls the cover up tight to the ceiling.Carefully pulling the cover down enough to reach over the cover and pinch thewires together should allow the cover to be removed. Hope this helps.
. Bob
Aug 09, 2014 | Broan nutone Broan/nautilus Bathroom...
I am looking for a umbrella cap to cover my 15 inch attic exhaust fan
Many people just use large black trash bags secured with duct tape or bungi cords. Black bags won't deteriorate as fast as the white ones with the UV rays of the sun and should last one full winter.
If you're concerned about the neighbors complaining about the lack of asthetics....I can't help you.
I never cover attic vents nor recommend them to be covered, because a properly vented attic all year long ensures moisture removal from the attic area and from the insulation. Also if you have shingled roofing, each nail point extending through the sheeting will condense moisture and drip into the insulation in a non vented attic space. This happens many times each winter when the air temp and the moisture content collide on the dew point scale. It does NOT happen daily.
The nails conduct the warmth to the outside, cool down and attract the moisture from the non vented air on their exposed length and slide down to the tip dripping into the insulation. Moisture detracts from the insulations ability to do its job, and that's to insulate the living space from abnormally cold or hot temperatures.
Apr 20, 2014 | Speedi-Products 6" Galvanized Umbrella...
Where is fan on coleman roof air
have to remove cover on roof to access
Nov 21, 2013 | Coleman Mach 15 Air Conditioner
The bathroom exhaust fan in our bungalow is leaking this past week every few days , we are not handy folks and so we are wondering what type of professional do we call in to deal with this leak and...
Sounds like the issue is simply condensation inside the exhaust pipe where it passes through the un-heated attic space. If you use the shower and the exhaust fan, lots of humid air is passing over the inside surface of a very cold duct, then running back down to your bathroom ceiling. You could get any non-specialist handyman to wrap insulation around that duct in the attic. But you can mitigate the problem by running the fan for a few minutes before you start the shower (thereby pre-heating the duct before you give it a blast of moist air) , and leaving it run for 20 minutes afterwards (thereby drying out the duct after use). Regarding the discolored ceiling, the handyman can apply some stain-covering white primer too.
Jan 14, 2011 | Fantech Fans Exhaust Fan In-Line
Compressor makes noise, but fans won't run
I'm guessing the hum you hear is the fan motor. After sitting for a time, I've had many that develop like a dead spot in the fan motor. Here's what to try. Shut power off to AC. Get someone up on the roof with about a 2 ft.,long fairly strong stick, or rod , about 1/4 inch or so in diameter. Have them carefully poke it through the openings in the cover and spin the fan blades at the back end of it. May be a little stiff at first, so don't break blades on fan, but get stick under one & lift to spin it, or over it & push it downward. Spin it 2 or 3 times all the way around. Turn power back on. Now stand back & try fan mode again. 99% of the time that will do it, but if not, take screws off around cover on roof & remove cover & give fan a bunch of good spins by hand, then turn power back on & try it. Keep me posted on results please ?
Jul 12, 2009 | Dometic Rooftop RV Air Conditioner
Patio umbrella tilt locking hinge broke
Need a fix for my patio umbrella the wind snpped the push button tilt mechanism.
Mar 31, 2009 | Garden
Torque specs for the cylinder head
2004 ENGINE
Engine Mechanical - 1.6L (L91) - Aveo
SPECIFICATIONS
FASTENER TIGHTENING SPECIFICATIONS
Fastener Tightening Specifications
Application
Specification
Metric English
A/C Compressor Mounting Bolts 27 N.m 20 lb ft
A/C Compressor Mounting Bracket Bolts 50 N.m 37 lb ft
Air Filter Housing Bolts 12 N.m 106 lb in
Alternator Adjusting Bolt 20 N.m 15 lb ft
Alternator Adjusting Bracket Retaining Bolt 20 N.m 15 lb ft
Auxiliary Catalytic Converter-to-Exhaust Manifold
Nuts and Bracket Bolts
40 N.m 30 lb ft
Camshaft Cap Bolts 16 N.m 12 lb ft
Camshaft Gear Bolt 67.5 N.m 49 lb ft
Camshaft Pressure Plate Bolts 10 N.m 89 lb in
Connecting Rod Bearing Cap Bolts 25 N.m+30°+15° 18 lb ft+30°+15°
Coolant Pump Retaining Bolts 10 N.m 89 lb in
Coolant Temperature Sensor 20 N.m 15 lb ft
Crankshaft Bearing Cap Bolts 50 N.m+45°+15° 37 lb ft+45°+15°
Crankshaft Position Sensor Retaining Bolt 10 N.m 89 lb in
Crankshaft Pulley Bolt 95 N.m+30°+15° 70 lb ft+30°+15°
Cylinder Head Bolts - Camshaft Support Housing
and Cylinder Head Mounting Bolts
25 N.m+60°+60°
+60°+15°
18 lb ft+60°+60°
+60°+10°
Electronic Ignition System Ignition Coil Mounting
Bolts
10 N.m 89 lb in
Engine Mount Bracket Retaining Bolt 65 N.m 48 lb ft
Engine Mount Bracket-to-Engine Mount Retaining
Bolts
60 N.m 44 lb ft
Engine Mount Retaining Nuts 40 N.m 30 lb ft
Exhaust Flexible Pipe Bracket Bolts 40 N.m 30 lb ft
Exhaust Gas Recirculation Valve Adapter Bolts 25 N.m 18 lb ft
Exhaust Manifold Heat Shield Bolts 15 N.m 11 lb ft
Exhaust Manifold Nuts 25 N.m 18 lb ft
Flexible Plate Bolts 60 N.m 44 lb ft
Flexible Plate Inspection Cover Bolts 10 N.m 89 lb in
Flywheel Bolts 35 N.m+30°+15° 26 lb ft+30°+15°
Flywheel Inspection Cover Bolts 12 N.m 106 lb in
Front Muffler-to-Main Catalytic Converter Nuts 30 N.m 22 lb ft
Fuel Rail Retaining Bolts 25 N.m 18 lb ft
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 1 of 330
http://www.eautorepair.net/app/PrintItems.asp?S0=2097152&S1=0&SG=%7BEEDCF... 3/30/2009
ENGINE MECHANICAL SPECIFICATIONS
Engine Mechanical Specifications
Intake Manifold Retaining Nuts 25 N.m 18 lb ft
Intake Manifold Support Bracket Lower Bolt-to-
Engine Block 40 N.m 30 lb ft
Intake Manifold Support Bracket Upper Bolts 25 N.m 18 lb ft
Lower Timing Belt Cover Bolts 10 N.m 89 lb in
Oil Pan Retaining Bolts 10 N.m 89 lb in
Oil Pressure Switch 40 N.m 30 lb ft
Oil Pump Retaining Bolts 10 N.m 89 lb in
Oil Pump/Pickup Tube and Support Bracket Bolts 10 N.m 89 lb in
Oil Pump Safety Relief Valve Bolt 36 N.m 22 lb ft
Oil Pump Rear Cover Bolts 6 N.m 53 lb in
Power Steering Pump Mounting Bolts 25 N.m 18 lb ft
Power Steering Pump Pulley Bolts 25 N.m 18 lb ft
Rear Timing Belt Cover Bolts 10 N.m 89 lb in
Spark Plug Cover Bolts 3 N.m 27 lb in
Spark Plugs 25 N.m 18 lb ft
Thermostat Housing Mounting Bolts 20 N.m 15 lb ft
Throttle Cable Bracket Bolts 8 N.m 71 lb in
Timing Belt Automatic Tensioner Bolt 25 N.m 18 lb ft
Timing Belt Idler Pulley Bolt 40 N.m 30 lb in
Transaxle Bell Housing Bolts 75 N.m 55 lb ft
Transaxle Brace Bolts 40 N.m 30 lb ft
Transaxle Torque Converter Bolts 65 N.m 48 lb ft
Upper Timing Belt Cover Bolts 10 N.m 89 lb in
Valve Cover Bolts 10 N.m 89 lb in
Application
Specification
Metric English
General Data
 Engine Type 4 Cylinder - In-Line
 Displacement 1598 cm3 97.51 in3
 Bore Stroke 79.0x81.5 mm 3.1x3.21 in
 Compression Ratio 9.5:1
 Firing Order 1-3-4-2
 Maximum Power - At 6200 RPM 77 kw/103.3 hp
 Maximum Torque - At 3400 RPM 145 N.m 106.9 lb ft
Cylinder Bore
 Diameter 79 mm 3.1 in
 Out of Round - Maximum 0.0065 mm 0.00025 in
 Taper - Maximum 0.0065 mm 0.00025 in
Piston
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 2 of 330
Jan 07, 2009 | 2004 Chevrolet Aveo
Speedi-Products 6" Galvanized Umbrella Roof Vent Cap Ex-Rcgu 06 Logo
443 people viewed this question
Top Speedi-Products Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Speedi-Products Hardware and Accessory Expert? Answer questions, earn points and help others
