Question about Sta Rite Industries Shallow Well Jet Pumps, 1/2 Hp
Leakin water pump
Motor runs but water leaking from bottom of casing
  • 50 Answers
The water pump on a car has a bearing that blocks a hole when working. When the pump goes, it pulls the bearing from the hole and leaks. This is very common, and it was made this way for pin-pointing the issue. The water pump should be replaced.
Posted on Apr 20, 2014
How do i reset a Samsung DW80F800UWS with display showing "LE"
Oh, that stands for Leaking - Samsungs have a plastic bottom that catches leaked water which activates a leak detector, which puts up the LEakin message. Most often leaks occur around the drain pump or drain hose. To clear the error, you must remove the standing water under the leak detector; no key sequence will remove that error.
Jan 04, 2015 | Samsung DW80F800UWS/AA 24" Stainless Steel...
Just replaced my thermostat, water pump and I still have a coolant leak looks like coming from radiator. Not overheating but smoking from coolant hitting the motor.
try some RADSEAL to see if this stops the leakin g, depending on the severity of the leak this may only be a tempory remedy and a new rad will be needed
Nov 17, 2014 | Cars & Trucks
Water leakin from bottom of engine
The Most common leak on the 4.3 and 5.7 are from the Bypass Hose on TOP of the Intake Manifold. It is a Quick Disconnect Fitting that corrodes and then leaks and then drains down the back of the motor.
The next possibility is a Heater Hose
Depending on how bad the leak is... If you have been running Water or a Majority Water, the FREEZE PLUGS or EXPANSION PLUGS will corrode and the water eats the metal and BAM!!!! leak
If you can provide more information, but I would start there.
Apr 07, 2013 | Cars & Trucks
Water leakin behind the motor
could leak water pump that what you did.
Feb 28, 2013 | Cars & Trucks
Water pump leaking
if water pump is leaking then it needs replaced
Sep 03, 2012 | 1996 Chrysler LHS
My 1995 chevy corsica is leakin ani and there's no
The Issue is most likely you're water pump radiator, or you're head gasket, I suggest you take it to youre local auto repair shop to clarify what the issue is.
May 20, 2011 | 1995 Chevrolet Corsica
Dishwasher began leaking underneath when turned on. Humming as if trying to start, but nothing further exept water on floor
I don't know how old this dishwasher is but the symptom your describing sounds like the ceramic water seal on the bottom of the impeller assy but above the motor has failed. When the seal fails it allows water to run though the motor and then the bearings in the motor fail. Once water starts running though a dishwasher motor they are pretty much shot. The reason for this is that the leak starts out slow and it leaks for a long period before you ever see the water under the dishwasher. So by the time you see the leak water has been going through the pump / motor assy for weeks or months. By that time the service technicians only option is to replace the motor pump assy.
Kelly
Apr 14, 2010 | Bosch SHU5315UC Dishwasher
Panel lit and motor running but will not cylce
It's almost certainly the case that something has started leaking in the bottom of the dishwasher (a seal or hose) and has filled the bottom catch pan with water. There is a float in the pan which will trip the unit into a mode where the pump turns on to flush out all the water inside the unit to avoid overflowing the pan and causing much more damage (to the subfloor and anything on lower stories or basement). As long as you have the unit turned on, the pump will run to flush out water. Until the catch pan is purged or enough water dries up.
At any rate, somebody needs to look at why the catch pan is filling up with water.
Jun 01, 2009 | Asko D1776 Stainless Steel Built-in...
Coolant leankin in pump area
Using a small mirror (available at parts stores w/ a nice long handle, not expensive either) check to see if the leak is from a small 'weep' hole under the pump, at the center. If this is where the leak is, it is a sign that your water pump is on the way out, and should be replaced. This leak will get worse as time goes on, so keep an eye on the coolant level, as it may go down quickly. Let me know what u find.
Nov 19, 2008 | 1997 Volkswagen Golf
Roper ras8445KQO washer
arlenekc : The water pump needs replaced.
malibu66,: Replacing the pump is not difficult at all.
In the above cases, Tilt the machine back so you have access to the bottom. (It there is a soft bottom plate you will have to remove it.) The pump it located on the bottom of the motor and is held on by two clips. Remove the hoses ant then the clips. The pump should slide off the motor shaft. If the pump does not come off then you will have to break it off. DO NOT pry on the motor or shaft. Once the pump is off check the motor shaft for any rust or build-up. This will have to be removed before a new pump is installed.
Line the pump up to the motor shaft to get it in place and put the unit back together then check the operation.
LITTLEGIRL4 Open the lid and find the water flume where the water comes in. This flume gets out of position sometimes. Start filling the machine and watch the flume. If there is water dripping or running down the sides toward the rear then the flume is not in position or has been damaged.
Dec 25, 2007 | Roper RAS8445KQ Top Load Washer
Sta Rite Industries Shallow Well Jet Pumps, 1/2 Hp Logo
81 people viewed this question
Top Sta Rite Industries Garden Experts
Dennis Key
Dennis Key
john h
Are you a Sta Rite Industries Garden Expert? Answer questions, earn points and help others
